    1.5k Posts 477 Posters 4.1m Views 477 Watching
    • RedFoxyR
      RedFoxy
      @pilou said:
      Just the sides of the main box and the parameters were 2mm and 2 sides.
      Prefer to work in Scale *100 and at the end Scale /100
      At this Scale (mm)Sketchup don't like very tiny segments, surfaces...
      Thank you for the suggestion but that was never an issue for me... worked completely fine in 2014. 😢
        AcesHigh
        RedFoxy, do you still have 2014 installed?
        You can just open 2015 and 2014. Open your file first in 2015. Then in 2014 (it will say it will have to open as read only). Then round corner the objects you want in 2014 and copy to the main file in 2015 (saving once in a while in 2015).
          define
          Hello Fredo,
          can't thank you enough for all your plugins!!! Donate folks!! At the end of the day
          we will have to open our refrigerators door - isn't it?
          I have a question:
          When inspecting the icons for 'RoundCorner' I stumbled upon one which is labeled 'CustomProfile'.
          It however don't seem to be implemented. Did you work on this as well?
          ...absolutely amazed by your work and with maximum respect
          Klaus
          • fredo6F
            Klaus,
            Custom profiles (based on a quarter definition of profile) is something that I have included in the code, but I would need to build a kind of GUI to activate it in the script.
            see http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=20485%26amp;start=30#p172163
            • PixeroP
              Pixero
              Please do. 😉
              Another small request.
              Would it be possible to make the scripts create quads only? As it is now it also creates triangles.
                How would you expect the result would be in quads for that example you posted?
                • fredo6F
                  I think it is rather something like this:
                  Coincidentally, I was just giving an other look at RoundCorner using subdivisions techniques, essentially to generalize usage to complex situations where a pure geometrical construction is not possible.
                  • pbacotP
                    Would it be something like this?
                    EDIT --oh no, the other faces get ruined for quads--I tried applying texture and just realized this and came back to find your post below, Fredo!
                      [attachment=0:2nffscfk]<!-- ia0 -->Quad round corner.png<!-- ia0 -->[/attachment:2nffscfk]
                      Yea, that type of rounding would be great!
                      • fredo6F
                        @thomthom said:
                        I am not so familar with subdivision. But I think you are, as you work on your SubDivide plugin!
                        • fredo6F
                          [attachment=4:1tjc0skc]<!-- ia4 -->triangles.JPG<!-- ia4 -->[/attachment:1tjc0skc]
                          Another possibility is the double rounding
                          Basically you proceed in 2 steps:
                          1. Round the vertical edge by an offset A (here A = 0.2m)
                            [attachment=3:1tjc0skc]<!-- ia3 -->Double Rounding 1.png<!-- ia3 -->[/attachment:1tjc0skc][attachment=0:1tjc0skc]<!-- ia0 -->Double Rounding 11.png<!-- ia0 -->[/attachment:1tjc0skc]
                          2. Then Round the top edges by an offset B, such as B is lower than A (here B = 0.15 m)
                            [attachment=2:1tjc0skc]<!-- ia2 -->Double rounding 2.png<!-- ia2 -->[/attachment:1tjc0skc][attachment=1:1tjc0skc]<!-- ia1 -->Double Rounding 3.png<!-- ia1 -->[/attachment:1tjc0skc]
                          I can maybe automate this type of double rounding in the Plugin
                            Fredo, it would be very nice if you could implement double rounding. That's essentially the way the real corners would get rounded on the models I draw.
                              define
                              Klaus,
                              Thanks for your answer Fredo. A custom profile-option could come in handy when having situations like thick peripheral seams like on leather sofas or cushions made from 'heavy duty' textiles. It's very special though - might be to tricky to use in the end, if it has to many special options, conditions and constraints.
                              thx again for your phantastic work!
                              Klaus
                              • H
                                HirokaMatsuiko2015
                                Hello thank you for your plugin its very convenient to use
                                i have an idea similar to blender bevel
                                if you choose inner loopcut or Lines then bevel it it will do this effect
                                http://i.imgur.com/AZWBKVP.png
                                • PixeroP
                                  Pixero
                                  Maybe this can give you some ideas: http://www.mariussilaghi.com/products/quad-chamfer
                                  • C
                                    cdubea
                                    Fredo, thanks for this crucial tool that is missing in Sketchup.
                                    I have a question/request. I'm using SketchUp on Dell XPS 13 laptop (Win 8.1). The problem I'm having is the toolbar is compressed in size making it very difficult to use:
                                    http://www.dubea.com/fotos/roundcorner.jpg
                                    Is there any way to expand the toolbar?
                                    Thanks again
                                    http://www.dubea.org/chris_small.jpg
                                    • PixeroP
                                      Pixero
                                      I have the same problem on my Macbook Pro with Bootcamp and Windows 8.1.
                                      A way of setting the size to fit a certain resolution would be great.
                                        mrjumpmanv2
                                        Hey,
                                        I'm trying to download Roundcorner for sketchup 2015 on windows
                                        I've tried downloading it on sketchucation's plugin downloader
                                        and everytime i try and find it it doesn't show up anywhere. I've
                                        checked the toolbars menu and the extensions tab under preferences
                                        and it's not there. Every time I start up sketchup it gives me this error.
                                        Is this plugin supposed to work with sketchup 2015? Let me know if there's
                                        any more information i can add to help you help me.
                                        Regards,
                                        Christian S.
                                        %(#000040)["Anyone who has never made a mistake has never tried anything new."
                                        Albert Einstein]
                                          All of Fredo's tools should work with v2015, but you need to install the latest versions from the PluginStore.
                                          AND you must have the latest version of LibFredo installed also available there...
                                          http://sketchucation.com/pluginstore?pln=LibFredo6
                                          The invalid byte UTF-8 suggests an older file version.
                                          It also sometimes occurs with file-paths including weird accented characters etc [although your user-path looks innocuous enough !]
                                          Another issue might be if you have copied over lots of files from an earlier SketchUp version's Plugins folder - you might have copied some old files across which are incompatible/unwanted - wherever possible you should always install fresh/latest copies when setting up your new SketchUp version...
                                          If getting the LibFredo etc doesn't fix things, then please provide screenshot[s] of your Plugins folder's contents, so we can see if you have any old/wrong files that need removing... 🤓
                                          • N
                                            NicholasElliott
                                            How do you download the file in the first place!?
                                            I need the link to the file in order to install… there used to be a clear button that said ‘DOWNLOAD’!
                                            Where has that gone!?
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 74
                                            • 75
                                            • 50 / 75
