    1.5k Posts 478 Posters 4.3m Views 478 Watching
      I quickly redrew your cabinet and then rounded over the edges on the top and sides in one go.
      I double clicked with Select while holding the Ctrl key (Option on Mac) on all three sides in turn to select their edges and then ran the tool once.
      • RedFoxyR
        RedFoxy
        [attachment=1:358glolk]<!-- ia1 -->Screenshot - 12_19_2014 , 4_51_30 PM.png<!-- ia1 -->[/attachment:358glolk]
        [attachment=0:358glolk]<!-- ia0 -->Screenshot - 12_19_2014 , 4_53_49 PM.png<!-- ia0 -->[/attachment:358glolk]
        Hmmm... however tempting redrawing around 60 different pieces of office furniture is ๐Ÿ˜„ I have been encountering this problem with other objects before while working on a completely different project, so from that I take it's rather the issue of program/plugins incompatibility rather than the objects themselves... Thank you very much for trying to help, I suppose this problem is gonna stay unsolved for now, will definitely have to run all the plugins separately to see which one may be causing the errors..
          Just the sides of the main box and the parameters were 2mm and 2 sides.
          Prefer to work in Scale *100 and at the end Scale /100
          At this Scale (mm)Sketchup don't like very tiny segments, surfaces...
            Pilou, at this scale SketchUp rounded over the corners just fine and filled in all the face on my installation.
            • RedFoxyR
              RedFoxy
              Thank you for the suggestion but that was never an issue for me... worked completely fine in 2014. ๐Ÿ˜ข
                AcesHigh
                RedFoxy, do you still have 2014 installed?
                You can just open 2015 and 2014. Open your file first in 2015. Then in 2014 (it will say it will have to open as read only). Then round corner the objects you want in 2014 and copy to the main file in 2015 (saving once in a while in 2015).
                  define
                  Hello Fredo,
                  can't thank you enough for all your plugins!!! Donate folks!! At the end of the day
                  we will have to open our refrigerators door - isn't it?
                  I have a question:
                  When inspecting the icons for 'RoundCorner' I stumbled upon one which is labeled 'CustomProfile'.
                  It however don't seem to be implemented. Did you work on this as well?
                  ...absolutely amazed by your work and with maximum respect
                  Klaus
                  • fredo6F
                    Klaus,
                    Custom profiles (based on a quarter definition of profile) is something that I have included in the code, but I would need to build a kind of GUI to activate it in the script.
                    see http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=20485%26amp;start=30#p172163
                    • PixeroP
                      Pixero
                      Please do. ๐Ÿ˜‰
                      Another small request.
                      Would it be possible to make the scripts create quads only? As it is now it also creates triangles.
                        How would you expect the result would be in quads for that example you posted?
                        • fredo6F
                          I think it is rather something like this:
                          Coincidentally, I was just giving an other look at RoundCorner using subdivisions techniques, essentially to generalize usage to complex situations where a pure geometrical construction is not possible.
                          • pbacotP
                            Would it be something like this?
                            EDIT --oh no, the other faces get ruined for quads--I tried applying texture and just realized this and came back to find your post below, Fredo!
                              [attachment=0:2nffscfk]<!-- ia0 -->Quad round corner.png<!-- ia0 -->[/attachment:2nffscfk]
                              Yea, that type of rounding would be great!
                              ๐Ÿ‘ ๐Ÿ‘
                              • fredo6F
                                @thomthom said:
                                ๐Ÿ‘ ๐Ÿ‘
                                I am not so familar with subdivision. But I think you are, as you work on your SubDivide plugin!
                                • fredo6F
                                  [attachment=4:1tjc0skc]<!-- ia4 -->triangles.JPG<!-- ia4 -->[/attachment:1tjc0skc]
                                  Another possibility is the double rounding
                                  Basically you proceed in 2 steps:
                                  1. Round the vertical edge by an offset A (here A = 0.2m)
                                    [attachment=3:1tjc0skc]<!-- ia3 -->Double Rounding 1.png<!-- ia3 -->[/attachment:1tjc0skc][attachment=0:1tjc0skc]<!-- ia0 -->Double Rounding 11.png<!-- ia0 -->[/attachment:1tjc0skc]
                                  2. Then Round the top edges by an offset B, such as B is lower than A (here B = 0.15 m)
                                    [attachment=2:1tjc0skc]<!-- ia2 -->Double rounding 2.png<!-- ia2 -->[/attachment:1tjc0skc][attachment=1:1tjc0skc]<!-- ia1 -->Double Rounding 3.png<!-- ia1 -->[/attachment:1tjc0skc]
                                  I can maybe automate this type of double rounding in the Plugin
                                    Fredo, it would be very nice if you could implement double rounding. That's essentially the way the real corners would get rounded on the models I draw.
                                      define
                                      Klaus,
                                      Thanks for your answer Fredo. A custom profile-option could come in handy when having situations like thick peripheral seams like on leather sofas or cushions made from 'heavy duty' textiles. It's very special though - might be to tricky to use in the end, if it has to many special options, conditions and constraints.
                                      thx again for your phantastic work!
                                      Klaus
                                      • H
                                        HirokaMatsuiko2015
                                        Hello thank you for your plugin its very convenient to use
                                        i have an idea similar to blender bevel
                                        if you choose inner loopcut or Lines then bevel it it will do this effect
                                        http://i.imgur.com/AZWBKVP.png
                                        • PixeroP
                                          Pixero
                                          Maybe this can give you some ideas: http://www.mariussilaghi.com/products/quad-chamfer
                                          • C
                                            cdubea
                                            Fredo, thanks for this crucial tool that is missing in Sketchup.
                                            I have a question/request. I'm using SketchUp on Dell XPS 13 laptop (Win 8.1). The problem I'm having is the toolbar is compressed in size making it very difficult to use:
                                            http://www.dubea.com/fotos/roundcorner.jpg
                                            Is there any way to expand the toolbar?
                                            Thanks again
                                            http://www.dubea.org/chris_small.jpg
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 74
                                            • 75
                                            • 50 / 75
