    Grumman G-44 Widgeon
    79 Posts 13 Posters 15.2k Views 13 Watching
    • Bryan KB Offline
      Requested pics.
      • Bryan KB Offline
        Remainder.
        • Bryan KB Offline
          Thanks everyone! This project is also going faster than most of previous projects. I think I'm getting the hang of it.
          With pontoons. The pontoons need to be reworked.
          Next couple of posts will be the requested pics.
          • Bryan KB Offline
            Almost done... with the flying version. I still want to do a runway version to show the landing gear.
            Still more detail left to add on this one. Most of this version's changes were made possible by hellnback sending me some very detailed plans. Thank you again.
            Those pontoons were... interesting, but I can now do crazy curvilinear surfaces thanks to Curviloft.
            This is straight SketchUp with a watermark background, ground turned on and colored and profiles and edges turned off.
            Wow. For some reason this file jumped from 6mb to 39mb!
            • hellnbakH Offline
              hellnbak
              Can't wait to see the finished model, I think it's going to be awesome πŸ‘
              • Bryan KB Offline
                Pontoon braces added. Pontoons angled correctly.
                • Bryan KB Offline
                  Thanks hellnback, but there are going to be a lot of mistakes on this one. SketchUp is now crashing constantly and becoming a lot less precise.
                  It will look good from a distance. πŸ˜†
                  • pbacotP Offline
                    Model's looking great there Bryan! Watching for more! (Happy New Year, guys) β˜€G44Widgeon29.png
                    • Bryan KB Offline
                      Thanks for the "props", pbacot. (I see what you did there πŸ˜† )
                      • hellnbakH Offline
                        hellnbak
                        Any idea what the problem might be? Have you tried reinstalling it?
                        • Bryan KB Offline
                          πŸ˜„ Old PC and high poly count.
                          • hellnbakH Offline
                            hellnbak
                            Yes, it's easy to see that the poly count would be very high
                            And, if I may say, unnecessarily so. Having that many polys doesn't add anything to your model as far as quality or appearance goes, it only (as you are discovering) serves to place a heavy load on your computer. Is there any chance you could backtrack (hopefully you have saved previous versions in various stages of development) and cut down on the polys?
                            • Bryan KB Offline
                              πŸ˜† I won't be backtracking on this one at all. This particular aircraft design has serious compound curvilinear surfaces. Without Curviloft, I could not have made this model. I would still be working on just the fuselage.
                              Update: Fixed the cockpit side window configuration and proportion.
                                Fantastic mate, really nailed the aircraft with that model, how about a render?
                                • Bryan KB Offline
                                  Thanks! Still have some more details left to create.
                                  • Bryan KB Offline
                                    Been busy at the new job and getting home late so haven't been making a lot of progress. Here's an update, but it's mostly detail corrections. I still need to finish the wing details and add the rear landing gear, maybe put a pilot in it.
                                    • Bryan KB Offline
                                      Added exhaust and main wing flaps. Reduced the polygons in an aft fuselage section as well an area near top of cockpit.
                                        Something I find quite useful is to have hidden geometry switched on and then move single points in a group to match other groups around them. This is handy when you use curviloft and find different sections with different profiles. You can see these as lines or bulges on the surface of the completed loft that look 'out of alignment'. Sorry if I am not being clear I will post a pic later to better show what I mean.
                                        • Bryan KB Offline
                                          That's a very good explanation. That's pretty much exactly how I do it as well as cleaning up bad surfaces. It's very helpful. πŸ‘
                                          • hellnbakH Offline
                                            hellnbak
                                            Brian
                                            Any progress on the beast?
                                            • 3 / 4
