    Texture Matching
    15 Posts 5 Posters 722 Views 5 Watching
    • KrisidiousK Offline
      Krisidious
      What is the quickest method for matching textures to align in multiple groups?
      I've had this problem for years, but never cared to figure it out because I wasn't rendering and it didn't matter much to me... Now that I want to get into rendering it pains my eyes. How do I get faces in multiple groups to match up correctly to an "overall" alignment.
      example: each line sections a different group.
      By: Kristoff Rand
        roland joseph
        Open the group you want to edit. Take a sample with your eye dropper of the closed group next to it that you want to align your material with (mapped in the direction you want). This way you get the texture direction from the group already mapped properly instead of the default direction.
        Same thing as ...positioning your material on a face and then sampling (eye dropper) from that face when ever you want to map a texture to another face in the same direction.
          Krisidious
          I've tried that and it's as though the entire group has been moved, the origins are different and thus the materials don't match up still.
          By: Kristoff Rand
            roland joseph
            Then it sounds like you need to do some group exploding to get rid of the old mapping.
            As in your example above, you should be able to sample any one of those groups and use that sample to align all the others.
              roland joseph
              Not sure if this is unorthodox but I also paint a face with just plain color to get rid of material mapping.
                Fredo's ThruPaint digs into groups. Did you try that?
                  Krisidious
                  The moving around will work, but would be too labor intensive. I'm looking for a way to assign the exact same mapping orientation to all faces in a model of the same texture.
                  The making the texture default sometimes works but again too labor intensive to change them all and if you use the ctrl/shift tools you end up adding all those hidden backface type defaults into your working group.
                  I'm hoping that one of the texture plugins like thrupaint or one of thomthom's UV plugins has something to the same effect.
                  I appreciate the suggestions though. ๐Ÿ˜„
                  By: Kristoff Rand
                    Krisidious
                    I have tried it, but I'm not getting the results I wanted. was wondering if I'm just missing a way to control everything of one texture. I seem to be locked into areas.
                    By: Kristoff Rand
                      Did you try this?
                        Krisidious
                        like this? My settings
                        it's not matching them for some reason.
                        By: Kristoff Rand
                          Can I have some sample area to try out.
                            Krisidious
                            http://www.aboveallhouseplans.com/section.skp
                            here ya go, sliced it to save on size. should have grabbed all groups as is.
                            By: Kristoff Rand
                            • fredo6F Offline
                              ThruPaint does not provide continous textures across different groups.
                              Actually, the best is to use the native Projected mode of the Paint tool, which, I believe use an absolute origin for texture positioning.
                                @fredo
                                Could the sample material and UVs be extended to allow this?
                                • Wo3DanW Offline
                                  Wo3Dan
                                  One think that does work across different (nested) groups with native tools is to reposition the texture and drag each red pin to a one mutual location (endpoint of a basic edge or guidepoint in plane! of faces) further down and to the left of all included geometry (thus all the basic and grouped (nested) faces that need to be painted correctly). So all these faces would then have their red pin located at the same [X,Y,Z] location.
                                  For me it worked in you model. Tedious to do though and I had to reset one texture of a nested face.
                                  Probably a plugin would be able to dig trough the (nested) geometry to do all the faces in a certain plain with the same defined/selected material. This would exclude other faces, painted with other material.
                                  But hรฉ, unfortunately I can't do Ruby scripting.
