    Export just shadows
    40 Posts 8 Posters 25.5k Views 8 Watching
    • ely862meE
      ely862me
      Go to Face style and select hidden lines then uncheck all the edges. Also uncheck the sky.
      shadows only a.skp
      Elisei (sketchupper)
      Come and See EliseiDesign
        suSteve
        thank you for taking the time to look at this and thanks for the answer
          I've done a tutorial on this here on SCF somewhere. I use shadow only exports frequently to create soft shadows and the appearance of multiple light sources.
            suSteve
            still struggling with this one. If I export to png or tiff for a transparent background then I end up with the box again as this is not transparent. Is it possible to export with a transparent background?
            thanks
              driven
              hi
              export without trans...
              open in Preview. magic wand the background...
                suSteve
                thanks John,
                can do but wondered if there was a way of managing it in SU
                • BoxB
                  With 2015 you can export ,png with transparent background.
                  Like this.
                  http://i155.photobucket.com/albums/s296/storeben/SU/Shadows.png
                    suSteve
                    Do you have a copy of the skp you have used for the .png? I have exported to png (transparency) which is where the object was visible.
                    thanks
                      driven
                      I don't know if you can exclude a 3d shape shadows, on a mac...
                      have a look at tig's Shadow Projectorhttp://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=41885
                      you can hide everything else than export a png/tiff of just the shape of a shadow...
                      this is geometry, on the ground...
                      • jeff hammondJ
                        some rendering apps can render only shadows with transparent everything else.
                        the upside is you get very clean shadows which render relatively quick.. the downside is it's maybe overkill for what you're trying to accomplish in the end.
                        so what, exactly, are you trying to accomplish?
                          suSteve
                          Thanks. I am on a Mac.
                          I wanted to just export shadows only with a transparent background.
                          • jeff hammondJ
                            like that's it? that's the final goal?
                            my point is that there may be other ways to reach your goal
                              driven
                              Jeff, Dave and I also use mac...
                              I think tig's plugin or a renderer are the options...
                              how are you wanting to use the results?
                                suSteve
                                I am following this http://www.ronenbekerman.com/making-of-urban-plaza/
                                  driven
                                  he is doing what you started with, the shadows are on all faces as well as the ground...
                                    suSteve
                                    Thank you. At least I know that it is not possible to export shadows only with a transparent background on a Mac without a plugin
                                    Thanks again
                                    • jeff hammondJ
                                      Thanks again
                                      just a fwiw..
                                      you've been able to do this forever on Mac (natively).. Windows has just gained the capability in su2015
                                      edit-- oh wait.. I misread what you wrote.. 😳 I'll look at it again later when I'm at a computer.
                                      • pbacotP
                                        Is that what he did in the tutorial (great link--fine artist BTW)? No he just used a hidden line, white background, no-edges shadows export to png, and set the layer in PS to multiply.
                                        If you want you can set png to transparent background (in the export dialog "Options"). The objects will still be white but you can set the color to alpha in PS (works with white background as well anyway).
                                        • jeff hammondJ
                                          Like this.
                                          ha.. i see what you did there πŸ˜‰
                                          (moved the geometry up and out of the view.. had me confused for a bit though)
                                            I believe that Renderiza has make a such plugin! πŸ˜‰
                                            [SU]Ch by Renderiza
                                            and find "shadow" πŸ˜‰
                                            http://2.bp.blogspot.com/-VUCtGknohfw/Uc-IiBqo0MI/AAAAAAAAAGM/orc3xaTIQ4w/s1600/such-webdialog.png
