Export just shadows
40 Posts 8 Posters 19.5k Views 8 Watching
    suSteve
    I followed some posts on just exporting shadows:
    Shadows only": View>Face style>Monochrome; View>Edge style>Uncheck all; Shadow settings dialog, Light 100, Dark 0, Shadows on; Window>Styles>Face settings, set the default colour for both Front and Back faces to pure white. If you want to show transparency, put all transparent objects on a different layer and turn that off.
    I end up with the following screenshot. Any ideas what I am missing?
    thanks
    • E Offline
      ely862me
      I believe you have some shadows on the faces too. Try to uncheck the "On faces" option.
      Elisei (sketchupper)
      Come and See EliseiDesign
        suSteve
        thanks for the reply. Unchecking on faces has the same result
          Check your light-dark settings. Light 100 and dark 0 (according to your proposed setup)
          • E Offline
            ely862me
            Can you share your model ?
            I have never tried this either. For the moment, if I choose Hidden lines mode and uncheck all the edges I get this.
              suSteve
              thanks. Model attached (its just a box)
              thanks again
              shadows only.skp
              • E Offline
                ely862me
                Go to Face style and select hidden lines then uncheck all the edges. Also uncheck the sky.
                shadows only a.skp
                  suSteve
                  thank you for taking the time to look at this and thanks for the answer
                    I've done a tutorial on this here on SCF somewhere. I use shadow only exports frequently to create soft shadows and the appearance of multiple light sources.
                      suSteve
                      still struggling with this one. If I export to png or tiff for a transparent background then I end up with the box again as this is not transparent. Is it possible to export with a transparent background?
                      thanks
                        driven
                        hi
                        export without trans...
                        open in Preview. magic wand the background...
                          suSteve
                          thanks John,
                          can do but wondered if there was a way of managing it in SU
                            With 2015 you can export ,png with transparent background.
                            Like this.
                            http://i155.photobucket.com/albums/s296/storeben/SU/Shadows.png
                              suSteve
                              Do you have a copy of the skp you have used for the .png? I have exported to png (transparency) which is where the object was visible.
                              thanks
                                driven
                                I don't know if you can exclude a 3d shape shadows, on a mac...
                                have a look at tig's Shadow Projectorhttp://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=41885
                                you can hide everything else than export a png/tiff of just the shape of a shadow...
                                this is geometry, on the ground...
                                  some rendering apps can render only shadows with transparent everything else.
                                  the upside is you get very clean shadows which render relatively quick.. the downside is it's maybe overkill for what you're trying to accomplish in the end.
                                  so what, exactly, are you trying to accomplish?
                                    suSteve
                                    Thanks. I am on a Mac.
                                    I wanted to just export shadows only with a transparent background.
                                      like that's it? that's the final goal?
                                      my point is that there may be other ways to reach your goal
                                        driven
                                        Jeff, Dave and I also use mac...
                                        I think tig's plugin or a renderer are the options...
                                        how are you wanting to use the results?
                                          suSteve
                                          I am following this http://www.ronenbekerman.com/making-of-urban-plaza/
                                          1 / 2
