    Export just shadows
    40 Posts 8 Posters 25.5k Views 8 Watching
      suSteve
      thanks John,
      can do but wondered if there was a way of managing it in SU
      • BoxB
        With 2015 you can export ,png with transparent background.
        Like this.
        http://i155.photobucket.com/albums/s296/storeben/SU/Shadows.png
          suSteve
          Do you have a copy of the skp you have used for the .png? I have exported to png (transparency) which is where the object was visible.
          thanks
            driven
            I don't know if you can exclude a 3d shape shadows, on a mac...
            have a look at tig's Shadow Projectorhttp://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=41885
            you can hide everything else than export a png/tiff of just the shape of a shadow...
            this is geometry, on the ground...
            • jeff hammondJ
              some rendering apps can render only shadows with transparent everything else.
              the upside is you get very clean shadows which render relatively quick.. the downside is it's maybe overkill for what you're trying to accomplish in the end.
              so what, exactly, are you trying to accomplish?
                suSteve
                Thanks. I am on a Mac.
                I wanted to just export shadows only with a transparent background.
                • jeff hammondJ
                  like that's it? that's the final goal?
                  my point is that there may be other ways to reach your goal
                    driven
                    Jeff, Dave and I also use mac...
                    I think tig's plugin or a renderer are the options...
                    how are you wanting to use the results?
                      suSteve
                      I am following this http://www.ronenbekerman.com/making-of-urban-plaza/
                        driven
                        he is doing what you started with, the shadows are on all faces as well as the ground...
                          suSteve
                          Thank you. At least I know that it is not possible to export shadows only with a transparent background on a Mac without a plugin
                          Thanks again
                          • jeff hammondJ
                            Thanks again
                            just a fwiw..
                            you've been able to do this forever on Mac (natively).. Windows has just gained the capability in su2015
                            edit-- oh wait.. I misread what you wrote.. 😳 I'll look at it again later when I'm at a computer.
                            • pbacotP
                              Is that what he did in the tutorial (great link--fine artist BTW)? No he just used a hidden line, white background, no-edges shadows export to png, and set the layer in PS to multiply.
                              If you want you can set png to transparent background (in the export dialog "Options"). The objects will still be white but you can set the color to alpha in PS (works with white background as well anyway).
                              • jeff hammondJ
                                Like this.
                                ha.. i see what you did there πŸ˜‰
                                (moved the geometry up and out of the view.. had me confused for a bit though)
                                  I believe that Renderiza has make a such plugin! πŸ˜‰
                                  [SU]Ch by Renderiza
                                  and find "shadow" πŸ˜‰
                                  http://2.bp.blogspot.com/-VUCtGknohfw/Uc-IiBqo0MI/AAAAAAAAAGM/orc3xaTIQ4w/s1600/such-webdialog.png
                                  • BoxB
                                    Sorry I'm not near a computer. The geometry in mine is in full view but painted with a transparent png texture. And it's windows hence the transparent background.
                                    • jeff hammondJ
                                      that looks like it might do the trick.. i tried it in 2015 despite it not being listed as supported and yeah, doesn't work.. (says su8 & 2013).. i'll try it in 8 a little later.
                                      ok, i see.
                                      re: transparent background.. the reason su2015 release notes say "transparent background upon export is available in windows" (or whatever) is because it's already been in mac since the beginning.. those type of abilities are built into OS X itself which made it easy for the devs to implement on mac..
                                      for instance.. notice the native osx screenshot above is a .png with drop shadow and transparent background.. macs are fancy like that :-D
                                      • BoxB
                                        I don't know what can and can't be done on a Mac, I gave my version of how to solve the question. Transparent texture transparent background and a jobs a carrot.
                                        • jeff hammondJ
                                          yeah, and i think yours is the best solution offered here.. especially for keeping it inside sketchup without a plugin
                                          i clarified that transparent exports are possible on mac since there seems to be some confusion in the thread about which OS is being used when in this case, it doesn't matter.. both su versions have the same capabilities/flaws regarding exporting transparent backgrounds and non-transparent objects (unless we use the method you've shown πŸ‘ )
                                          not necessarily your solution here @steve but following up on the rendering solution i mentioned earlier in case it helps others who might be reading.
                                          sketchup export - no shadows/shading:
                                          shadow pass render: (in this one, i didn't ignore any objects so i could get the semi-transparent shading on the faces)
                                          combined:
                                          example with only ground shadows.. ignore geometry
                                          of course, this is all going to depend on your renderer's capabilities.. i use indigo.. this is on my laptop which i don't have a license for so it's the free version of indigo. (watermark + size limit)
                                          ymmv
                                          [EDIT] oh, @pilou.. i tried the renderiza plugin on su8.. it doesn't work (i mean, the plugin works but it doesn't accomplish this particular task)
                                          • BoxB
                                            And roughly the same cluster of shapes with transparent texture and some edges and faces on and off.
                                            http://i155.photobucket.com/albums/s296/storeben/SU/7c7414e5-8105-4078-b053-c96dd4da7cec.png
                                            I must admit, I'm lost as to where this is going and as such am off to bed.
                                            BTW the transparent png texture that I used was discussed recently in this thread.
                                            http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=60086
                                            • 2 / 2
