    Export just shadows
    40 Posts 8 Posters 23.2k Views 8 Watching
      I've done a tutorial on this here on SCF somewhere. I use shadow only exports frequently to create soft shadows and the appearance of multiple light sources.
        suSteve
        still struggling with this one. If I export to png or tiff for a transparent background then I end up with the box again as this is not transparent. Is it possible to export with a transparent background?
        thanks
          driven
          hi
          export without trans...
          open in Preview. magic wand the background...
            suSteve
            thanks John,
            can do but wondered if there was a way of managing it in SU
            • BoxB Offline
              With 2015 you can export ,png with transparent background.
              Like this.
              http://i155.photobucket.com/albums/s296/storeben/SU/Shadows.png
                suSteve
                Do you have a copy of the skp you have used for the .png? I have exported to png (transparency) which is where the object was visible.
                thanks
                  driven
                  I don't know if you can exclude a 3d shape shadows, on a mac...
                  have a look at tig's Shadow Projectorhttp://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=41885
                  you can hide everything else than export a png/tiff of just the shape of a shadow...
                  this is geometry, on the ground...
                    some rendering apps can render only shadows with transparent everything else.
                    the upside is you get very clean shadows which render relatively quick.. the downside is it's maybe overkill for what you're trying to accomplish in the end.
                    so what, exactly, are you trying to accomplish?
                      suSteve
                      Thanks. I am on a Mac.
                      I wanted to just export shadows only with a transparent background.
                        like that's it? that's the final goal?
                        my point is that there may be other ways to reach your goal
                          driven
                          Jeff, Dave and I also use mac...
                          I think tig's plugin or a renderer are the options...
                          how are you wanting to use the results?
                            suSteve
                            I am following this http://www.ronenbekerman.com/making-of-urban-plaza/
                              driven
                              he is doing what you started with, the shadows are on all faces as well as the ground...
                                suSteve
                                Thank you. At least I know that it is not possible to export shadows only with a transparent background on a Mac without a plugin
                                Thanks again
                                  Thanks again
                                  just a fwiw..
                                  you've been able to do this forever on Mac (natively).. Windows has just gained the capability in su2015
                                  edit-- oh wait.. I misread what you wrote.. 😳 I'll look at it again later when I'm at a computer.
                                    Is that what he did in the tutorial (great link--fine artist BTW)? No he just used a hidden line, white background, no-edges shadows export to png, and set the layer in PS to multiply.
                                    If you want you can set png to transparent background (in the export dialog "Options"). The objects will still be white but you can set the color to alpha in PS (works with white background as well anyway).
                                      Like this.
                                      ha.. i see what you did there πŸ˜‰
                                      (moved the geometry up and out of the view.. had me confused for a bit though)
                                        I believe that Renderiza has make a such plugin! πŸ˜‰
                                        [SU]Ch by Renderiza
                                        and find "shadow" πŸ˜‰
                                        http://2.bp.blogspot.com/-VUCtGknohfw/Uc-IiBqo0MI/AAAAAAAAAGM/orc3xaTIQ4w/s1600/such-webdialog.png
                                        • BoxB Offline
                                          Sorry I'm not near a computer. The geometry in mine is in full view but painted with a transparent png texture. And it's windows hence the transparent background.
                                            that looks like it might do the trick.. i tried it in 2015 despite it not being listed as supported and yeah, doesn't work.. (says su8 & 2013).. i'll try it in 8 a little later.
                                            ok, i see.
                                            re: transparent background.. the reason su2015 release notes say "transparent background upon export is available in windows" (or whatever) is because it's already been in mac since the beginning.. those type of abilities are built into OS X itself which made it easy for the devs to implement on mac..
                                            for instance.. notice the native osx screenshot above is a .png with drop shadow and transparent background.. macs are fancy like that :-D
