    Export just shadows
    40 Posts 8 Posters 25.5k Views 8 Watching
    • ely862meE
      ely862me
      Can you share your model ?
      I have never tried this either. For the moment, if I choose Hidden lines mode and uncheck all the edges I get this.
      Elisei (sketchupper)
      Come and See EliseiDesign
        suSteve
        thanks. Model attached (its just a box)
        thanks again
        shadows only.skp
        • ely862meE
          ely862me
          Go to Face style and select hidden lines then uncheck all the edges. Also uncheck the sky.
          shadows only a.skp
            suSteve
            thank you for taking the time to look at this and thanks for the answer
              I've done a tutorial on this here on SCF somewhere. I use shadow only exports frequently to create soft shadows and the appearance of multiple light sources.
                suSteve
                still struggling with this one. If I export to png or tiff for a transparent background then I end up with the box again as this is not transparent. Is it possible to export with a transparent background?
                thanks
                  driven
                  hi
                  export without trans...
                  open in Preview. magic wand the background...
                    suSteve
                    thanks John,
                    can do but wondered if there was a way of managing it in SU
                    • BoxB
                      With 2015 you can export ,png with transparent background.
                      Like this.
                      http://i155.photobucket.com/albums/s296/storeben/SU/Shadows.png
                        suSteve
                        Do you have a copy of the skp you have used for the .png? I have exported to png (transparency) which is where the object was visible.
                        thanks
                          driven
                          I don't know if you can exclude a 3d shape shadows, on a mac...
                          have a look at tig's Shadow Projectorhttp://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=41885
                          you can hide everything else than export a png/tiff of just the shape of a shadow...
                          this is geometry, on the ground...
                          • jeff hammondJ
                            some rendering apps can render only shadows with transparent everything else.
                            the upside is you get very clean shadows which render relatively quick.. the downside is it's maybe overkill for what you're trying to accomplish in the end.
                            so what, exactly, are you trying to accomplish?
                              suSteve
                              Thanks. I am on a Mac.
                              I wanted to just export shadows only with a transparent background.
                              • jeff hammondJ
                                like that's it? that's the final goal?
                                my point is that there may be other ways to reach your goal
                                  driven
                                  Jeff, Dave and I also use mac...
                                  I think tig's plugin or a renderer are the options...
                                  how are you wanting to use the results?
                                    suSteve
                                    I am following this http://www.ronenbekerman.com/making-of-urban-plaza/
                                      driven
                                      he is doing what you started with, the shadows are on all faces as well as the ground...
                                        suSteve
                                        Thank you. At least I know that it is not possible to export shadows only with a transparent background on a Mac without a plugin
                                        Thanks again
                                        • jeff hammondJ
                                          Thanks again
                                          just a fwiw..
                                          you've been able to do this forever on Mac (natively).. Windows has just gained the capability in su2015
                                          edit-- oh wait.. I misread what you wrote.. ๐Ÿ˜ณ I'll look at it again later when I'm at a computer.
                                          • pbacotP
                                            Is that what he did in the tutorial (great link--fine artist BTW)? No he just used a hidden line, white background, no-edges shadows export to png, and set the layer in PS to multiply.
                                            If you want you can set png to transparent background (in the export dialog "Options"). The objects will still be white but you can set the color to alpha in PS (works with white background as well anyway).
