    Can't export animation over 1280 x 720
    11 Posts 7 Posters 5.3k Views 7 Watching
      Lersince1991
      I just want to export and image set on my 2015 sketchup pro however when I go to change the resolution export settings, and no matter what I set they revert back to 1280 x 720 every single time!!!!!
      I've tried changing the resolution to custom, tried changing the format, anti-aliasing, transparency, frame rate, aspect ratio. no matter what I do it changes back to 16:9 at 1280 x 720.
      I have disabled all extensions and also unchecked things like use maximum texture size and hardware acceleration.
      Same result.
      What the hell is going on?
      I'm on OS X Yosemite.
      On our work pc's there are different options now to export as image sets but this hasn't been updated in OS X version?
      Also on a weirder note, for some strange reason when I press esc key when changing the resolution it comes up with loads of weird word suggestions...
        Charlie__V
        I can't speak to OS X Yosemite.......as I am windows only.
        I do recall a number of years back when working with a very large file (w/lots of scenes), I attempted an animation export.....and it would fail due to a limitation of either system memory and or file limitation.
        So, have you tried exporting just two scenes? (assuming you have several)
        Sorry I cannot be of more help.
        Charlie
          slbaumgartner
          I'm also on OS X Yosemite, SketchUp 2015 pro, 2012 MacBookPro retina. I see the same strange substitution list on pressing escape, but not your other issue. As a test, I exported a custom 1096 x 1096 animation and it worked just fine. So, I also have no explanation...sorry.
          • jeff hammondJ Offline
            what if you try exporting larger than HD (1920x1080) .mp4?
            if i try larger, it reverts to HD size.. (if i try exporting .avi, i can preview at larger than HD but the exported file has been reverted to HD)
            the workaround would maybe be to export .jpg/.png/.tif as the format (do it into a new folder or your desktop is going to be a meesss πŸ˜‰ )... then using iMovie or quicktime7pro (if it even works on yosemite?), import the image sequence then export as video.
              Or VirtualDub.
                driven
                I recall you need to use Custom to go outside of the presets...
                both for larger or smaller than the defaults...
                after selecting export >> animation >> png/jpg will save as image sequence, but it's not obvious...
                right click and see what text substitutions you have enabled...
                although i have never used escape in that context before, I tried it and it added or subtracted Px, for 4/5 changes then gave me that dropdown...
                  slbaumgartner
                  I just did 2046 x 2046 mp4 and it worked (size deliberately not divisible by 8 to see whether that has any bearing on mp4 compression). However, I note that my custom size and ratio settings are not "sticky". When I go back to the dialog, one or another will have been reset to a standard size.
                    slbaumgartner
                    I right-clicked and turned off all text substitutions, and I still get the weird list when I pr
                    I right-clicked and turned off all text substitutions, and I still get the weird list when I press ESC.
                      slbaumgartner
                      I right-clicked and turned off all text substitutions, and I still get the weird list when I press ESC.[/quote]
                        driven
                        it's bugging me, why would anyone 'press ESC' in an input box?
                        is it a PC thing?
                        I always use return...
                          plankton2
                          Using Sketchup 2015 for exporting an "animation set", I have encountered a pixel resolution limitation of 3840x2160. In previous versions of Sketchup, I was able to export animation sets with the same parameters available for exporting a 2D Graphic, which would be 9999x5653.
                          When doing a finished animation, I routinely render at 3 or 4 times the desired resolution and then size the images down to a usable size such as 1920 x 1080. This process is essentially a poor man's anti aliasing.
                          It would be great to have the full resolution capacity back in the Export> Animation> Image set routine!!!
