<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t export animation over 1280 x 720]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I just want to export and image set on my 2015 sketchup pro however when I go to change the resolution export settings, and no matter what I set they revert back to 1280 x 720 every single time!!!!!</p>
<p dir="auto">I've tried changing the resolution to custom, tried changing the format, anti-aliasing, transparency, frame rate, aspect ratio. no matter what I do it changes back to 16:9 at 1280 x 720.</p>
<p dir="auto">I have disabled all extensions and also unchecked things like use maximum texture size and hardware acceleration.</p>
<p dir="auto">Same result.</p>
<p dir="auto">What the hell is going on?</p>
<p dir="auto">I'm on OS X Yosemite.</p>
<p dir="auto">On our work pc's there are different options now to export as image sets but this hasn't been updated in OS X version?</p>
<p dir="auto">Also on a weirder note, for some strange reason when I press esc key when changing the resolution it comes up with loads of weird word suggestions...</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/r0wp_ScreenShot2014-12-03at10.44.30.png" alt="Screen Shot 2014-12-03 at 10.44.30.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.sketchucation.com/topic/148389/can-t-export-animation-over-1280-x-720</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 03:17:54 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/148389.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Dec 2014 10:37:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Fri, 25 Sep 2015 16:46:21 GMT]]></title><description><![CDATA[<p dir="auto">Using Sketchup 2015 for exporting an "animation set", I have encountered a pixel resolution limitation of 3840x2160. In previous versions of Sketchup, I was able to export animation sets with the same parameters available for exporting a 2D Graphic, which would be 9999x5653.</p>
<p dir="auto">When doing a finished animation, I routinely render at 3 or 4 times the desired resolution and then size the images down to a usable size such as 1920 x 1080. This process is essentially a poor man's anti aliasing.</p>
<p dir="auto">It would be great to have the full resolution capacity back in the Export&gt; Animation&gt; Image set routine!!!</p>
]]></description><link>https://community.sketchucation.com/post/1492380</link><guid isPermaLink="true">https://community.sketchucation.com/post/1492380</guid><dc:creator><![CDATA[plankton2]]></dc:creator><pubDate>Fri, 25 Sep 2015 16:46:21 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 21:13:47 GMT]]></title><description><![CDATA[<p dir="auto">it's bugging me, why would anyone  'press ESC' in an input box?</p>
<p dir="auto">is it a PC thing?</p>
<p dir="auto">I always use return...</p>
]]></description><link>https://community.sketchucation.com/post/1465144</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465144</guid><dc:creator><![CDATA[driven]]></dc:creator><pubDate>Wed, 03 Dec 2014 21:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 21:11:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/driven" aria-label="Profile: driven">@<bdi>driven</bdi></a> said:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser" aria-label="Profile: unknownuser">@<bdi>unknownuser</bdi></a> said:</p>
<blockquote>
</blockquote>
<p dir="auto">right click and see what text substitutions you have enabled...<br />
although i have never used escape in that context before, I tried it and it added or subtracted Px, for 4/5 changes then gave me that dropdown...</p>
</blockquote>
<p dir="auto">I right-clicked and turned off all text substitutions, and I still get the weird list when I press ESC.[/quote]</p>
]]></description><link>https://community.sketchucation.com/post/1465143</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465143</guid><dc:creator><![CDATA[slbaumgartner]]></dc:creator><pubDate>Wed, 03 Dec 2014 21:11:47 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 21:09:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unknownuser" aria-label="Profile: unknownuser">@<bdi>unknownuser</bdi></a> said:</p>
<blockquote>
<p dir="auto">I right-clicked and turned off all text substitutions, and I still get the weird list when I pr</p>
</blockquote>
<p dir="auto">I right-clicked and turned off all text substitutions, and I still get the weird list when I press ESC.</p>
]]></description><link>https://community.sketchucation.com/post/1465142</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465142</guid><dc:creator><![CDATA[slbaumgartner]]></dc:creator><pubDate>Wed, 03 Dec 2014 21:09:56 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 21:05:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeff" aria-label="Profile: jeff">@<bdi>jeff</bdi></a> hammond said:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slbaumgartner" aria-label="Profile: slbaumgartner">@<bdi>slbaumgartner</bdi></a> said:</p>
<blockquote>
<p dir="auto">As a test, I exported a custom 1096 x 1096 animation and it worked just fine.</p>
</blockquote>
<p dir="auto">what if you try exporting larger than HD (1920x1080) .mp4?</p>
<p dir="auto">if i try larger, it reverts to HD size.. (if i try exporting .avi, i can preview at larger than HD but the exported file has been reverted to HD)</p>
<p dir="auto">the workaround would maybe be to export .jpg/.png/.tif as the format (do it into a new folder or your desktop is going to be a meesss <img src="https://community.sketchucation.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=d4d42be6ce8" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /> )... then using iMovie or quicktime7pro (if it even works on yosemite?), import the image sequence then export as video.</p>
</blockquote>
<p dir="auto">I just did 2046 x 2046 mp4 and it worked (size deliberately not divisible by 8 to see whether that has any bearing on mp4 compression).  However, I note that my custom size and ratio settings are not "sticky".  When I go back to the dialog, one or another will have been reset to a standard size.</p>
]]></description><link>https://community.sketchucation.com/post/1465139</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465139</guid><dc:creator><![CDATA[slbaumgartner]]></dc:creator><pubDate>Wed, 03 Dec 2014 21:05:22 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 20:20:45 GMT]]></title><description><![CDATA[<p dir="auto">I recall you need to use Custom to go outside of the presets...<br />
<img src="/uploads/imported_attachments/IDkH_2014-12-0308.06.43pm.png" alt="both for larger or smaller than the defaults..." title="both for larger or smaller than the defaults..." class=" img-fluid img-markdown" /><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/lersince1991" aria-label="Profile: lersince1991">@<bdi>lersince1991</bdi></a> said:</p>
<blockquote>
</blockquote>
<p dir="auto">after selecting <em>export &gt;&gt; animation &gt;&gt; png/jpg</em> will save as image sequence, but it's not obvious...</p>
<blockquote>
</blockquote>
]]></description><link>https://community.sketchucation.com/post/1465130</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465130</guid><dc:creator><![CDATA[driven]]></dc:creator><pubDate>Wed, 03 Dec 2014 20:20:45 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 19:12:42 GMT]]></title><description><![CDATA[<p dir="auto">Or VirtualDub.</p>
]]></description><link>https://community.sketchucation.com/post/1465120</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465120</guid><dc:creator><![CDATA[Rich O Brien]]></dc:creator><pubDate>Wed, 03 Dec 2014 19:12:42 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 18:27:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slbaumgartner" aria-label="Profile: slbaumgartner">@<bdi>slbaumgartner</bdi></a> said:</p>
<blockquote>
</blockquote>
]]></description><link>https://community.sketchucation.com/post/1465112</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465112</guid><dc:creator><![CDATA[jeff hammond]]></dc:creator><pubDate>Wed, 03 Dec 2014 18:27:00 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 18:20:01 GMT]]></title><description><![CDATA[<p dir="auto">I'm also on OS X Yosemite, SketchUp 2015 pro, 2012 MacBookPro retina.  I see the same strange substitution list on pressing escape, but not your other issue.  As a test, I exported a custom 1096 x 1096 animation and it worked just fine.  So, I also have no explanation...sorry.</p>
]]></description><link>https://community.sketchucation.com/post/1465111</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465111</guid><dc:creator><![CDATA[slbaumgartner]]></dc:creator><pubDate>Wed, 03 Dec 2014 18:20:01 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t export animation over 1280 x 720 on Wed, 03 Dec 2014 12:31:28 GMT]]></title><description><![CDATA[<p dir="auto">I can't speak to OS X Yosemite.......as I am windows only.<br />
I do recall a number of years back when working with a very large file (w/lots of scenes), I attempted an animation export.....and it would fail due to a limitation of either system memory and or file limitation.</p>
<p dir="auto">So, have you tried exporting just two scenes? (assuming you have several)</p>
<p dir="auto">Sorry I cannot be of more help.</p>
<p dir="auto">Charlie</p>
]]></description><link>https://community.sketchucation.com/post/1465021</link><guid isPermaLink="true">https://community.sketchucation.com/post/1465021</guid><dc:creator><![CDATA[Charlie__V]]></dc:creator><pubDate>Wed, 03 Dec 2014 12:31:28 GMT</pubDate></item></channel></rss>
