    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 231.7k Views 45 Watching
      I imagine he will be upping the user count soon. But best ask the man himself.
      • F Offline
        faust07
        Is Rich a blender man? πŸ˜‰
          I'm a journey man
          but i would like to see blender-esque tools in SU
          • john2J Offline
            john2
            @alvis said:
            original post http://forums.sketchucation.com/viewtopic.php?p=417045#p417045
            This is really awesome. Can you explain the procedure for making this please? πŸ‘
            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
            • HieruH Offline
              Hieru
              The modelling stages illustrated are pretty straightforward. Is there a particular stage you don't understand?
              www.davidhier.co.uk
              • bazB Offline
                baz
                Yes it is quite awesome. Perhaps you could tell us which parts of the 'procedure' that you are wanting?
                • john2J Offline
                  john2
                  Hexagonal chain onwards, it was rotated and copied around a central axis,. Then what happened? You did a joint push pull I suppose, but how did the final outcome, the bend occur?
                  • olisheaO Offline
                    olishea
                    Free Form Deformation plugin. FFD. A classic.
                    Could also do it with a couple of other plugins.
                    There are some other similar things on this thread:
                    http://sketchucation.com/forums/viewtopic.php?f=333%26amp;t=50584
                    oli
                      Click image....
                      [sw:36hr5zeo]8ooOjnfQxycbKwV[/sw:36hr5zeo]
                      Click Image...
                      [sw:36hr5zeo]kv02TBsbR5JGVgg[/sw:36hr5zeo]
                      • mitcorbM Offline
                        mitcorb
                        Very nice, Rich:
                        Which viewer is this?
                        • BoxB Offline
                          I was just fiddling with some ideas while eating lunch and thought it might fit this thread.
                          I wanted a solid egg shape with pulled legs.
                          I can make it in glass, I just wanted to see if I could model and effectively show it.
                          So a very quick model, and an equally quick render.
                          The whole thing could have been done in a 30min challenge.
                          So here's the proxy and the artisan result.
                          And a very fast Twilight render.
                            Philippe Stark revival! πŸ˜„
                            • cottyC Offline
                              cotty
                              Nice example, Box!
                              my SketchUp gallery
                              • panixiaP Offline
                                panixia
                                really nice.. just try to achieve a bit cleaner topology in the bottom to avoid those little smoothing artifacts.. πŸ‘
                                • BoxB Offline
                                  I'm not quite sure which artifacts you mean but I deliberately wanted to create the stretch you get when you pull hot glass.
                                  I took this another step further and made the full Faberge/Stark lemon juicer with a turned wood base. The glass picks up the wood texture nicely.
                                  The client specifically asked for something earthy with a modern feel and mentioned both Faberge and Stark and then threw in "but we love oriental Lacquer-ware". They looked at this today and said when can we have it.
                                    wow!
                                    can you wing me the proxy?
                                    • BoxB Offline
                                      If by the proxy you mean the rough before subdivide and smooth, No, fraid not, I'm far too casual to keep that. If I don't like something I start again or go back. Once it's working I move ahead so all I have is the model.
                                        it's ok. i just wanted to have a doodle....
                                        • panixiaP Offline
                                          panixia
                                          i mean the subdivision artifacts between the legs and the base wich usually can be simply avoided doing exactly what rich did with those control loops..
                                          • cottyC Offline
                                            cotty
                                            He did this intentionally...
                                            I think he reached a realistic effect in this special case. πŸ‘
                                            my SketchUp gallery
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
