    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 327.9k Views 45 Watching
    • soloS Offline
      @rich o brien said:
      It is a new SubD plugin currently in Alpha
      Need beta testers?
        I imagine he will be upping the user count soon. But best ask the man himself.
        • F Offline
          faust07
          Is Rich a blender man? πŸ˜‰
            I'm a journey man
            but i would like to see blender-esque tools in SU
            • john2J Offline
              john2
              @alvis said:
              original post http://forums.sketchucation.com/viewtopic.php?p=417045#p417045
              This is really awesome. Can you explain the procedure for making this please? πŸ‘
              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
              • HieruH Offline
                Hieru
                The modelling stages illustrated are pretty straightforward. Is there a particular stage you don't understand?
                www.davidhier.co.uk
                • bazB Offline
                  baz
                  Yes it is quite awesome. Perhaps you could tell us which parts of the 'procedure' that you are wanting?
                  • john2J Offline
                    john2
                    Hexagonal chain onwards, it was rotated and copied around a central axis,. Then what happened? You did a joint push pull I suppose, but how did the final outcome, the bend occur?
                    • olisheaO Offline
                      olishea
                      Free Form Deformation plugin. FFD. A classic.
                      Could also do it with a couple of other plugins.
                      There are some other similar things on this thread:
                      404 Not Found
                      (sketchucation.com)
                      oli
                        Click image....
                        [sw:36hr5zeo]8ooOjnfQxycbKwV[/sw:36hr5zeo]
                        Click Image...
                        [sw:36hr5zeo]kv02TBsbR5JGVgg[/sw:36hr5zeo]
                        • mitcorbM Offline
                          mitcorb
                          Very nice, Rich:
                          Which viewer is this?
                          • BoxB Offline
                            I was just fiddling with some ideas while eating lunch and thought it might fit this thread.
                            I wanted a solid egg shape with pulled legs.
                            I can make it in glass, I just wanted to see if I could model and effectively show it.
                            So a very quick model, and an equally quick render.
                            The whole thing could have been done in a 30min challenge.
                            So here's the proxy and the artisan result.
                            And a very fast Twilight render.
                              Philippe Stark revival! πŸ˜„
                              • cottyC Offline
                                cotty
                                Nice example, Box!
                                my SketchUp gallery
                                • panixiaP Offline
                                  panixia
                                  really nice.. just try to achieve a bit cleaner topology in the bottom to avoid those little smoothing artifacts.. πŸ‘
                                  • BoxB Offline
                                    I'm not quite sure which artifacts you mean but I deliberately wanted to create the stretch you get when you pull hot glass.
                                    I took this another step further and made the full Faberge/Stark lemon juicer with a turned wood base. The glass picks up the wood texture nicely.
                                    The client specifically asked for something earthy with a modern feel and mentioned both Faberge and Stark and then threw in "but we love oriental Lacquer-ware". They looked at this today and said when can we have it.
                                      wow!
                                      can you wing me the proxy?
                                      • BoxB Offline
                                        If by the proxy you mean the rough before subdivide and smooth, No, fraid not, I'm far too casual to keep that. If I don't like something I start again or go back. Once it's working I move ahead so all I have is the model.
                                          it's ok. i just wanted to have a doodle....
                                          • panixiaP Offline
                                            panixia
                                            i mean the subdivision artifacts between the legs and the base wich usually can be simply avoided doing exactly what rich did with those control loops..
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
