    Simple Artisan examples collection
    Scheduled Pinned Locked Moved Organic Modelling
    459 Posts 45 Posters 373.7k Views 45 Watching
      I'm a journey man
      but i would like to see blender-esque tools in SU
      • john2J
        john2
        @alvis said:
        original post http://forums.sketchucation.com/viewtopic.php?p=417045#p417045
        This is really awesome. Can you explain the procedure for making this please? πŸ‘
        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        • HieruH
          Hieru
          The modelling stages illustrated are pretty straightforward. Is there a particular stage you don't understand?
          www.davidhier.co.uk
          • bazB
            baz
            Yes it is quite awesome. Perhaps you could tell us which parts of the 'procedure' that you are wanting?
            • john2J
              john2
              Hexagonal chain onwards, it was rotated and copied around a central axis,. Then what happened? You did a joint push pull I suppose, but how did the final outcome, the bend occur?
              • olisheaO
                olishea
                Free Form Deformation plugin. FFD. A classic.
                Could also do it with a couple of other plugins.
                There are some other similar things on this thread:
                404 Not Found
                (sketchucation.com)
                oli
                  Click image....
                  [sw:36hr5zeo]8ooOjnfQxycbKwV[/sw:36hr5zeo]
                  Click Image...
                  [sw:36hr5zeo]kv02TBsbR5JGVgg[/sw:36hr5zeo]
                  • mitcorbM
                    mitcorb
                    Very nice, Rich:
                    Which viewer is this?
                    • BoxB
                      I was just fiddling with some ideas while eating lunch and thought it might fit this thread.
                      I wanted a solid egg shape with pulled legs.
                      I can make it in glass, I just wanted to see if I could model and effectively show it.
                      So a very quick model, and an equally quick render.
                      The whole thing could have been done in a 30min challenge.
                      So here's the proxy and the artisan result.
                      And a very fast Twilight render.
                        Philippe Stark revival! πŸ˜„
                        • cottyC
                          cotty
                          Nice example, Box!
                          my SketchUp gallery
                          • panixiaP
                            panixia
                            really nice.. just try to achieve a bit cleaner topology in the bottom to avoid those little smoothing artifacts.. πŸ‘
                            • BoxB
                              I'm not quite sure which artifacts you mean but I deliberately wanted to create the stretch you get when you pull hot glass.
                              I took this another step further and made the full Faberge/Stark lemon juicer with a turned wood base. The glass picks up the wood texture nicely.
                              The client specifically asked for something earthy with a modern feel and mentioned both Faberge and Stark and then threw in "but we love oriental Lacquer-ware". They looked at this today and said when can we have it.
                                wow!
                                can you wing me the proxy?
                                • BoxB
                                  If by the proxy you mean the rough before subdivide and smooth, No, fraid not, I'm far too casual to keep that. If I don't like something I start again or go back. Once it's working I move ahead so all I have is the model.
                                    it's ok. i just wanted to have a doodle....
                                    • panixiaP
                                      panixia
                                      i mean the subdivision artifacts between the legs and the base wich usually can be simply avoided doing exactly what rich did with those control loops..
                                      • cottyC
                                        cotty
                                        He did this intentionally...
                                        I think he reached a realistic effect in this special case. πŸ‘
                                        my SketchUp gallery
                                        • BoxB
                                          Thanks Cotty, Yes, I'm fully aware of how to make the faces flat or regular. That's not what I wanted, so they aren't Artifacts they are design decisions.
                                          Look at the shape you get when you pull a spoon out of thick honey, it's a fluid solid and behaves in a very particular way. The surface tension isn't uniform so you get stretching.
                                          • soloS
                                            [attachment=1:jgvor0yd]<!-- ia1 -->thing2.png<!-- ia1 -->[/attachment:jgvor0yd]
                                            [attachment=0:jgvor0yd]<!-- ia0 -->thing.png<!-- ia0 -->[/attachment:jgvor0yd]
                                            Blender?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 20 / 23
