    SketchUp 2015 is 64bit
    302 Posts 74 Posters 45.3k Views 74 Watching
    • david_hD Offline
      david_h
      I am still struggling with loading some of my old reliable scripts into 2015. (Repair Broken Lines not withstanding) for some this I can change my work flow. But, for some scripts that I bought from SMUSTARD or whatever, years go that have an RBS extension, How do I load those. Plugin store of course uses RBZ.
      Any advice?
      thx,
      D
      • jeff hammondJ Offline
        Any advice?
        thx,
        D
        you can put them in the plugin folder manually.. the old way. (i don't know where it's at on windows.. someone else will have to tell you).
        if you want to install them via sketchup itself, there's a quirky little workaround you can try..
        get all your .rb and .rbs files together along with any supporting folders.. select them then right-click-> Compress Items (or, do whatever you have to do to make them into a .zip).. so now you have a zip containing all the plugins.
        change the name of that zip to .rbz (example.zip --> example.rbz)
        now use sketchup to install that .rbz and all the plugins inside it will go into the plugin folder for you.
        (probably better to install them manually πŸ˜‰ ..but, it is possible and it's a decent way to move a collection of plugins between computers etc.)
        • david_hD Offline
          david_h
          Thanks Jeff. That work around worked. I did a test run on a routine, and it worked great.
          Kudos, huzzahs and cheers all around. 😍
            yeah, it's cool because all the plugins load up and are ready for use when doing it with the .rbz (.RuBy_Zip)
              jpmorla
              @jim said:
              You can install and use differing versions of SketchUp on a computer. You can not install both the 32-bit and 64-bit version of SketchUp 2015. So if you are using a version earlier than 2015, you can install 2015 64-bit without affecting your current version.
              Thank you Jim! I am going it a try this evening. So excited!
                Jim
                Any advice?
                thx,
                D
                For repair_broken_lines.rb - lines 27 and 42 - remove the space after the function name but before the (
                But probably TT's Cleanup plugin is better to use.
                  rhino for mac just gained .skp import/export.. made possible because of sketchup's 64bit_ness πŸ‘
                    The first v2015 Maintenance Release M1 is now out.
                    If you download the appropriate installer from the usual SketchUp pages, then you will find it's now 15.1...
                    But currently Trimble have not been able to update their Release Notes which still speak of 15.0...
                    πŸ˜’
                    I understand that the main changes were made to fix issues experienced by a few PC/MAC users who could not install 15.0... without a crash ! and to fix another rare crash with some users when trying some Layout fly-outs...
                    • sfto1S Offline
                      sfto1
                      I do not see a maintenance release at sketchup.com. Where did you see this?
                      • Rich O BrienR Online
                        You won't see it as yet. But the downloadable file should be the newer maintenance release.
                          As I explained - the SketchUp 2015 Release Notes are not currently up to date with the installers' actual 15.1... versions.
                          But if you download and install from the current links you'll get v15.1...
                          Unfortunately the Release Notes still say 15.0... because they have not yet been updated !
                          And Trimble have made no proper announcement !
                          We are actually doing a favor to any users who were having problems installing v2015 in its initial format, and to the tardy SketchUp/Trimble guys - by announcing their updated version, which has been available since the end of last week, but which Trimble have failed to publicize thus far !
                          Why they have elected to do this, when M1 is to help users with difficulties in installing v2015, and they won't know there is a fixed update available - available since last Friday - it'll be Wednesday shortly !
                            driven
                            does 'check for update' work?
                            or is it not in that pipeline yet?
                              I don't think so...
                              Trimble are way behind on their game with this whole update... πŸ˜’
                                david.
                                If you download the appropriate installer from the usual SketchUp pages, ...
                                What "usual Sketchup pages" would that be? When I upgraded, I mistakenly clicked out of the page for the download and it was only by chance that I found my way to a page with the correct download file. I should have bookmarked it, but I didn't. Shouldn't Trimble have sent out an email to licensed users?
                                  http://www.sketchup.com/download/all
                                    david.
                                    Ha! Too simple. That's it, thanks!
                                    • tt_suT Offline
                                      tt_su
                                      The issue was not installer crash - it was a crash upon launching SketchUp once it had been installed. This was happening on certain custom locations such as root of a drive or unicode paths. The patch prevent the crash and let SketchUp work in the root of a drive. Though installing to unicode paths will still fail to load the Ruby StdLib so some extensions might not work.
                                      • tt_suT Offline
                                        tt_su
                                        It wonΒ΄t be pushed to existing users like most of our normal maintenance releases has been. This is because if you where affected you would not have been able to update because SketchUp would crash upon launch. If you where able to start SketchUp then you have no need for this update.
                                        This is more of a hotfix than a maintenance release.
                                          driven
                                          @tt
                                          so the advice for us to pass on to those who crash on first start-up, should be to...
                                          submit the bug-splat for the download link?
                                          or
                                          simply re-download?
                                            Glad that's been clarified - elsewhere I was sure someone said it was a crash when installing M0, rather than a BugSplat when starting M0...
                                            So you don't need M1 unless you were having problems starting M0.
                                            Of course unless you submitted a splat-report for M0, then you won't learn of M1's existence unless you read this post, or you decide to try downloading the installer again - but why would you? - with no announcement you'll expect it to be the same as the one you had already - so you'll just remain pissed-off with SketchUp and bemoan the lack of an update - which is actually there, but which has been secretly launched, so you haven't found out about it... πŸ˜’
                                            The Release Notes are still confusingly out of step, for anyone who decides to check their version against those... versions are shown for M0 [15.0...] not M1 [15.1...]
                                            • 15
                                            • 16
                                            • 3 / 16
