    Off Screen Dialog.
    35 Posts 6 Posters 6.8k Views 6 Watching
    • hellnbakH
      hellnbak
      Please define "off screen dialog"
      Yeah, I are dum
      • BoxB
        A dialog that is off the screen.
        Tig has a reg edit to reset them but I can't find it.
        • KrisidiousK
          Krisidious
          I can tell it's there because if I click anywhere I get the error donk noise.
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            you know, any pop up dialog box that you have to hit "ok" or put a key in or something.
            By: Kristoff Rand
            • BoxB
              Have you changed your screen setup?
              The low tech way is the move the screens around until you find it using the screen res settings.
              • KrisidiousK
                Krisidious
                Yeah, I've tried turning them off and changing resolution to use just one screen. but I can't find it anywhere. it's like it's actually off screen.
                By: Kristoff Rand
                • BoxB
                  Have a look at this.
                  http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=50344%26amp;p=454143%26amp;hilit=regedit#p454143
                    driven
                    do either of these work?
                    Win + Tab shows all windows stacked and skewed.
                    Alt + Tab shows all windows side by side.
                    • KrisidiousK
                      Krisidious
                      Tried the regedit and had no effect.
                      tried win + tab and alt + tab. wintab cycled through all programs properly, but could not engage or find dialog.
                      alt-tab did not see SU at all.
                      strangely I can use other dialogs inside of SU, like the material or stlyes panels. but anything else makes the donk noise.
                      By: Kristoff Rand
                      • BoxB
                        I think that regedit was specifically for the preferences window.
                        I assume you've tried the reset workspace in preferences.
                        I'm sure tig will pop in with a full dialog reset regedit.
                        • KrisidiousK
                          Krisidious
                          reset workspace? nooooo... do you have any idea how many toolbars I have? all of them I think.
                          By: Kristoff Rand
                          • BoxB
                            It doesn't touch toolbars, only dialogs.
                            • KrisidiousK
                              Krisidious
                              Ok... I'm going to trust you.
                              By: Kristoff Rand
                              • KrisidiousK
                                Krisidious
                                I thought you meant tool bar reset button... nope. workspace reset didn't bring it up. this is freaky.
                                this only happens if I try to remove the old live ivy from my su2015 plugins folder.
                                By: Kristoff Rand
                                  If Workspace reset doesn't work...
                                  Run Regedit...
                                  For Preferences off-screen dialog...
                                  Look in HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**PrefsPS**
                                  Set x and y values to 0 [dialog's top-left corner], IF they are bigger than the screen's x/y coords, or -ve values...
                                  Restart SketchUp...
                                  There are also about a dozen entries starting with 'Snappy'...
                                  e.g. HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**Snappy**Components
                                  These are the settings for the other dialogs.
                                  Open each in turn and look at the x and y values...
                                  Reset any suspicious ones as before...
                                  If a dialog has no x/y then it's never been opened [yet]...
                                  There's also one for the 'RubyConsoleDlg'...
                                  The Toolbar-Reset option is needed to sort out Toolbars, as its 'RubyWorkSpace' setup is not readily editable...
                                  • KrisidiousK
                                    Krisidious
                                    and no... what in the hell is going on here. It's because I want to use the new Live Ivy so bad... that's why this is happening.
                                    By: Kristoff Rand
                                      I have also exchanged PMs with you...
                                      Why do you have a Plugins folder in ProgramData tree?
                                      What is adding the Gems folder to the $: ?
                                      πŸ˜•
                                      • KrisidiousK
                                        Krisidious
                                        Why do you have a Plugins folder in ProgramData tree? 3DxSketchUp.rb and ImaginationVisualizer.rb are in it... No idea why. I install all plugins to my main plugin directory.
                                        What is adding the Gems folder? uuidtools-2.1.4
                                        By: Kristoff Rand
                                          Some 3rd party tools install into the ProgramData Plugins folder, with NO user choice [ill-advisedly!]: that folder is really intended for use on computers where several users share one Plugins folder... πŸ˜’
                                          OK, so no duplicated plugins installed in parallel folders... πŸ˜•
                                          There is no way that what is installed/loaded in one version of SketchUp should affect what is installed/loading in another version - unless there is some kind of shared Plugins folder setup between them...
                                          In your case it appears there is NOT !
                                          Obviously something is wrong...
                                          Have you tried Repairing/Reinstalling SUp v2015 ?
                                          πŸ€“
                                          • KrisidiousK
                                            Krisidious
                                            using SU reinstall/repair had no effect.
                                            By: Kristoff Rand
