    Off Screen Dialog.
    35 Posts 6 Posters 6.8k Views 6 Watching
    • KrisidiousK
      Krisidious
      I can tell it's there because if I click anywhere I get the error donk noise.
      By: Kristoff Rand
      • KrisidiousK
        Krisidious
        @hellnbak said:
        Please define "off screen dialog"
        you know, any pop up dialog box that you have to hit "ok" or put a key in or something.
        By: Kristoff Rand
        • BoxB
          Have you changed your screen setup?
          The low tech way is the move the screens around until you find it using the screen res settings.
          • KrisidiousK
            Krisidious
            Yeah, I've tried turning them off and changing resolution to use just one screen. but I can't find it anywhere. it's like it's actually off screen.
            By: Kristoff Rand
            • BoxB
              Have a look at this.
              http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=50344%26amp;p=454143%26amp;hilit=regedit#p454143
                driven
                do either of these work?
                Win + Tab shows all windows stacked and skewed.
                Alt + Tab shows all windows side by side.
                • KrisidiousK
                  Krisidious
                  Tried the regedit and had no effect.
                  tried win + tab and alt + tab. wintab cycled through all programs properly, but could not engage or find dialog.
                  alt-tab did not see SU at all.
                  strangely I can use other dialogs inside of SU, like the material or stlyes panels. but anything else makes the donk noise.
                  By: Kristoff Rand
                  • BoxB
                    I think that regedit was specifically for the preferences window.
                    I assume you've tried the reset workspace in preferences.
                    I'm sure tig will pop in with a full dialog reset regedit.
                    • KrisidiousK
                      Krisidious
                      reset workspace? nooooo... do you have any idea how many toolbars I have? all of them I think.
                      By: Kristoff Rand
                      • BoxB
                        It doesn't touch toolbars, only dialogs.
                        • KrisidiousK
                          Krisidious
                          Ok... I'm going to trust you.
                          By: Kristoff Rand
                          • KrisidiousK
                            Krisidious
                            I thought you meant tool bar reset button... nope. workspace reset didn't bring it up. this is freaky.
                            this only happens if I try to remove the old live ivy from my su2015 plugins folder.
                            By: Kristoff Rand
                              If Workspace reset doesn't work...
                              Run Regedit...
                              For Preferences off-screen dialog...
                              Look in HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**PrefsPS**
                              Set x and y values to 0 [dialog's top-left corner], IF they are bigger than the screen's x/y coords, or -ve values...
                              Restart SketchUp...
                              There are also about a dozen entries starting with 'Snappy'...
                              e.g. HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**Snappy**Components
                              These are the settings for the other dialogs.
                              Open each in turn and look at the x and y values...
                              Reset any suspicious ones as before...
                              If a dialog has no x/y then it's never been opened [yet]...
                              There's also one for the 'RubyConsoleDlg'...
                              The Toolbar-Reset option is needed to sort out Toolbars, as its 'RubyWorkSpace' setup is not readily editable...
                              • KrisidiousK
                                Krisidious
                                and no... what in the hell is going on here. It's because I want to use the new Live Ivy so bad... that's why this is happening.
                                By: Kristoff Rand
                                  I have also exchanged PMs with you...
                                  Why do you have a Plugins folder in ProgramData tree?
                                  What is adding the Gems folder to the $: ?
                                  πŸ˜•
                                  • KrisidiousK
                                    Krisidious
                                    Why do you have a Plugins folder in ProgramData tree? 3DxSketchUp.rb and ImaginationVisualizer.rb are in it... No idea why. I install all plugins to my main plugin directory.
                                    What is adding the Gems folder? uuidtools-2.1.4
                                    By: Kristoff Rand
                                      Some 3rd party tools install into the ProgramData Plugins folder, with NO user choice [ill-advisedly!]: that folder is really intended for use on computers where several users share one Plugins folder... πŸ˜’
                                      OK, so no duplicated plugins installed in parallel folders... πŸ˜•
                                      There is no way that what is installed/loaded in one version of SketchUp should affect what is installed/loading in another version - unless there is some kind of shared Plugins folder setup between them...
                                      In your case it appears there is NOT !
                                      Obviously something is wrong...
                                      Have you tried Repairing/Reinstalling SUp v2015 ?
                                      πŸ€“
                                      • KrisidiousK
                                        Krisidious
                                        using SU reinstall/repair had no effect.
                                        By: Kristoff Rand
                                          driven
                                          Kris have you removed SCF_Toolbar yet?
                                          • KrisidiousK
                                            Krisidious
                                            could it be that the template wants to load the leaves and can't find them? Nope...
                                            By: Kristoff Rand
