    Off Screen Dialog.
    35 Posts 6 Posters 5.1k Views 6 Watching
    • KrisidiousK Offline
      Krisidious
      Sketchup is not starting because of what I believe is an off screen dialog. Is there anyway to force it back to the main screen?
      By: Kristoff Rand
      • hellnbakH Offline
        hellnbak
        Please define "off screen dialog"
        Yeah, I are dum
        • BoxB Offline
          A dialog that is off the screen.
          Tig has a reg edit to reset them but I can't find it.
            Krisidious
            I can tell it's there because if I click anywhere I get the error donk noise.
            By: Kristoff Rand
              Krisidious
              you know, any pop up dialog box that you have to hit "ok" or put a key in or something.
              By: Kristoff Rand
              • BoxB Offline
                Have you changed your screen setup?
                The low tech way is the move the screens around until you find it using the screen res settings.
                  Krisidious
                  Yeah, I've tried turning them off and changing resolution to use just one screen. but I can't find it anywhere. it's like it's actually off screen.
                  By: Kristoff Rand
                  • BoxB Offline
                    Have a look at this.
                    http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=50344%26amp;p=454143%26amp;hilit=regedit#p454143
                      driven
                      do either of these work?
                      Win + Tab shows all windows stacked and skewed.
                      Alt + Tab shows all windows side by side.
                        Krisidious
                        Tried the regedit and had no effect.
                        tried win + tab and alt + tab. wintab cycled through all programs properly, but could not engage or find dialog.
                        alt-tab did not see SU at all.
                        strangely I can use other dialogs inside of SU, like the material or stlyes panels. but anything else makes the donk noise.
                        By: Kristoff Rand
                        • BoxB Offline
                          I think that regedit was specifically for the preferences window.
                          I assume you've tried the reset workspace in preferences.
                          I'm sure tig will pop in with a full dialog reset regedit.
                            Krisidious
                            reset workspace? nooooo... do you have any idea how many toolbars I have? all of them I think.
                            By: Kristoff Rand
                            • BoxB Offline
                              It doesn't touch toolbars, only dialogs.
                                Krisidious
                                Ok... I'm going to trust you.
                                By: Kristoff Rand
                                  Krisidious
                                  I thought you meant tool bar reset button... nope. workspace reset didn't bring it up. this is freaky.
                                  this only happens if I try to remove the old live ivy from my su2015 plugins folder.
                                  By: Kristoff Rand
                                    If Workspace reset doesn't work...
                                    Run Regedit...
                                    For Preferences off-screen dialog...
                                    Look in HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**PrefsPS**
                                    Set x and y values to 0 [dialog's top-left corner], IF they are bigger than the screen's x/y coords, or -ve values...
                                    Restart SketchUp...
                                    There are also about a dozen entries starting with 'Snappy'...
                                    e.g. HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**Snappy**Components
                                    These are the settings for the other dialogs.
                                    Open each in turn and look at the x and y values...
                                    Reset any suspicious ones as before...
                                    If a dialog has no x/y then it's never been opened [yet]...
                                    There's also one for the 'RubyConsoleDlg'...
                                    The Toolbar-Reset option is needed to sort out Toolbars, as its 'RubyWorkSpace' setup is not readily editable...
                                      Krisidious
                                      and no... what in the hell is going on here. It's because I want to use the new Live Ivy so bad... that's why this is happening.
                                      By: Kristoff Rand
                                        I have also exchanged PMs with you...
                                        Why do you have a Plugins folder in ProgramData tree?
                                        What is adding the Gems folder to the $: ?
                                        πŸ˜•
                                          Krisidious
                                          Why do you have a Plugins folder in ProgramData tree? 3DxSketchUp.rb and ImaginationVisualizer.rb are in it... No idea why. I install all plugins to my main plugin directory.
                                          What is adding the Gems folder? uuidtools-2.1.4
                                          By: Kristoff Rand
                                            Some 3rd party tools install into the ProgramData Plugins folder, with NO user choice [ill-advisedly!]: that folder is really intended for use on computers where several users share one Plugins folder... πŸ˜’
                                            OK, so no duplicated plugins installed in parallel folders... πŸ˜•
                                            There is no way that what is installed/loaded in one version of SketchUp should affect what is installed/loading in another version - unless there is some kind of shared Plugins folder setup between them...
                                            In your case it appears there is NOT !
                                            Obviously something is wrong...
                                            Have you tried Repairing/Reinstalling SUp v2015 ?
                                            πŸ€“
