    Off Screen Dialog.
    35 Posts 6 Posters 6.8k Views 6 Watching
    • KrisidiousK
      Krisidious
      reset workspace? nooooo... do you have any idea how many toolbars I have? all of them I think.
      By: Kristoff Rand
      • BoxB
        It doesn't touch toolbars, only dialogs.
        • KrisidiousK
          Krisidious
          Ok... I'm going to trust you.
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            I thought you meant tool bar reset button... nope. workspace reset didn't bring it up. this is freaky.
            this only happens if I try to remove the old live ivy from my su2015 plugins folder.
            By: Kristoff Rand
              If Workspace reset doesn't work...
              Run Regedit...
              For Preferences off-screen dialog...
              Look in HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**PrefsPS**
              Set x and y values to 0 [dialog's top-left corner], IF they are bigger than the screen's x/y coords, or -ve values...
              Restart SketchUp...
              There are also about a dozen entries starting with 'Snappy'...
              e.g. HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**Snappy**Components
              These are the settings for the other dialogs.
              Open each in turn and look at the x and y values...
              Reset any suspicious ones as before...
              If a dialog has no x/y then it's never been opened [yet]...
              There's also one for the 'RubyConsoleDlg'...
              The Toolbar-Reset option is needed to sort out Toolbars, as its 'RubyWorkSpace' setup is not readily editable...
              • KrisidiousK
                Krisidious
                and no... what in the hell is going on here. It's because I want to use the new Live Ivy so bad... that's why this is happening.
                By: Kristoff Rand
                  I have also exchanged PMs with you...
                  Why do you have a Plugins folder in ProgramData tree?
                  What is adding the Gems folder to the $: ?
                  πŸ˜•
                  • KrisidiousK
                    Krisidious
                    Why do you have a Plugins folder in ProgramData tree? 3DxSketchUp.rb and ImaginationVisualizer.rb are in it... No idea why. I install all plugins to my main plugin directory.
                    What is adding the Gems folder? uuidtools-2.1.4
                    By: Kristoff Rand
                      Some 3rd party tools install into the ProgramData Plugins folder, with NO user choice [ill-advisedly!]: that folder is really intended for use on computers where several users share one Plugins folder... πŸ˜’
                      OK, so no duplicated plugins installed in parallel folders... πŸ˜•
                      There is no way that what is installed/loaded in one version of SketchUp should affect what is installed/loading in another version - unless there is some kind of shared Plugins folder setup between them...
                      In your case it appears there is NOT !
                      Obviously something is wrong...
                      Have you tried Repairing/Reinstalling SUp v2015 ?
                      πŸ€“
                      • KrisidiousK
                        Krisidious
                        using SU reinstall/repair had no effect.
                        By: Kristoff Rand
                          driven
                          Kris have you removed SCF_Toolbar yet?
                          • KrisidiousK
                            Krisidious
                            could it be that the template wants to load the leaves and can't find them? Nope...
                            By: Kristoff Rand
                            • KrisidiousK
                              Krisidious
                              One of them... reluctantly... What are you trying to say?
                              By: Kristoff Rand
                              • KrisidiousK
                                Krisidious
                                I'll try that... But it's going to unmake all my Layout trays. hear that SU Team?
                                My wallet is gone... It did not unmake my trays as I have experienced in previous reinstall/repairs.
                                By: Kristoff Rand
                                • KrisidiousK
                                  Krisidious
                                  I've narrowed it down to these two files inside of the LiveIvy folder.
                                  SU2015-64 will not start unless these two files, these exact files... Not the newer versions, but these exact files are in their respective folders inside SU2015 Plugins.
                                  This LiveIvy_tool.rb file at location.
                                  \AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\LiveIvy\LiveIvy_tool.rb
                                  This ivyleaf_3.skp at location.
                                  \AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\LiveIvy\Textures\ivyleaf_3.skp
                                  If I delete the entire Live Ivy install, folder and plugin file. SU2015 will not start.
                                  How in the hell can a skp be required to start SU.
                                  LiveIvy_tool.rb
                                  ivyleaf_3.skp
                                  By: Kristoff Rand
                                    As I explained to you in a recent PM... πŸ˜’
                                    Your Plugins folder is quite frankly a mess.
                                    You have copied old plugins files from an earlier version.
                                    Some required 'helper' files have not been copied over OR reinstalled.
                                    Some 'system' files that ought only to be in Tools seem to have ill-advisedly copied older versions loading from Plugins !
                                    You also have some old files that are encoded incompatibly with v2014/2015.
                                    Once that is fixed you might find that LiveIvy behaves, currently I don't see how it could be causing issues, the 'skp' weirdness is also a mystery. The older version of LiveIvy does auto-load and immediately load the three ivyleaf_1.skp, .._2.skp and .._3.skp components, so as it loads and they are not there it will cause errors - perhaps even splats - BUT if it does not load at all [i.e. it's not there] how can it cause any issues... πŸ˜•
                                    I suspect this a tangled web of errors.
                                    Try tidying up the Plugins folder issues as I explained in my PM.
                                    Then remove all LiveIvy files/subfolder, and reinstall from new...
                                    If it's still bust then perhaps PM me screen-shots showing ALL .rb/.rbs files that are loading from the Plugins folderS...
                                    OR error messages from the Console...
                                    πŸ˜’
                                    • KrisidiousK
                                      Krisidious
                                      I don't see how it can be a "Mess"... The only two plugins I copied over were LiveIvy and SCF powerbars. Everything else was installed one at a time from either the Plugin Store or the Extension Warehouse. Perhaps I installed older version from those places, but I tested each one as I installed them. Restarting SU everytime. Perhaps these are errors so small it doesn't effect the plugin itself or SU when starting? I've never experienced that before.
                                      Are you talking about the SCF powebar? I found that of the 3 bars one caused errors and when it was removed everything else seems to work on with no errors?
                                      I'll remove everything except Live Ivy and see what happens.
                                      the 'skp' weirdness is also a mystery. The older version of LiveIvy does auto-load and immediately load the three ivyleaf_1.skp, .._2.skp and .._3.skp components, so as it loads and they are not there it will cause errors - perhaps even splats - BUT if it does not load at all [i.e. it's not there] how can it cause any issues... πŸ˜• When I install the new LiveIvy it should not affect the skp loading because it overwrites that skp with a new version with the exact same name. So it should just load the new one. How could it need a specific skp? strange indeed.
                                      πŸ˜’
                                      Will do... And stop rolling your eyes at me... πŸ˜•
                                      By: Kristoff Rand
                                      • KrisidiousK
                                        Krisidious
                                        Yeah... removing all plugins except for Live Ivy new version and it works fine. πŸ˜’
                                        By: Kristoff Rand
                                          πŸ˜’
                                          Print off the PM I sent you...
                                          Read it and tick-off the items as you go...
                                          In it I analyzed each error in that long error-message you gave me, and clearly explained what they each meant.
                                          For example - incorrectly located/duplicated [old] files]in the wrong folder, missing helper files, incompatible encoded files, syntax in files' coding now incompatible with Ruby2 etc...
                                          If you fix those then the errors will stop and the new LiveIvy WILL load and work !
                                          Perhaps we should continue this sub-topic by PM, as this is more to do with fixing your Plugins folders' 'mess' so that you can use LiveIvy, rather than any LiveIvy issue per se...
                                          Less 'doing your laundry in public' too...
                                          • KrisidiousK
                                            Krisidious
                                            I must have missed this pm... I'll go back and look again.
                                            By: Kristoff Rand
                                            • 2 / 2
