    SketchUp 2015 is 64bit
    302 Posts 74 Posters 45.6k Views 74 Watching
    • Chris FullmerC Offline
      @david_h said:
      So I am doin' the whole "Plugin store Thing"(thanks Rich for the video) I did know that much. But it gives an "Extensions" directory rather than the good ol' plugins tab.
      SketchUp 2015 changed the name of the "Plugins" menu to be the "Extensions" menu. No real difference, we're just working towards getting all our developers to register their 'plugins' as 'extensions'. It is not actually related to whether an extension is distributed as just a .rb file, or a .rbz or a .zip. Its just some calls they have to make in their code. Point is, don't be alarmed by the Extensions menu, its just a name change ๐Ÿ˜„ Old .rb files will still shot up in that menu, even though they used to show up in the Plugins menu.
      @david_h said:
      what about old but beloved little plugins with .rb extensions.. Can I just move them into the extensions directory? I can't just create a plugins directory it seems.
      It is very hit-or-miss as to which ooold .rb plugins can be copied over and still work. That is why you really really have to install them via the Extension Warehouse, the SketchUcation plugin store, or smustard, just so you make sure you are getting the most recent version. Then if you still have some .rb extensions that you can't live without, just copy them into your plugins folder like you used to. Just do it sin small batches. If one doesn't work, it might pop up a loading error. then you'll know which one failed, and you won't be able to carry that one forward. In that case, all you can do is track down the author and try to get an update, or try a different plugin with same functionality.
      @david_h said:
      And do i need to re-download and re-install my renderers? Podium, twilight, thea. .. etc etc etc? Thanks for the help
      These are are ones that you will most definitely have to re-download their newest version, that is specifically compatible with SU 2015. Most extensions that have their own installers do things to your system that simply copying their plugin files from one version of SU to the next is bound to fail. So yeah, a good rule of thumb is that if it has its own installer, it definitely cannot simply be copied.
      Hope that helps!
      • david_hD Offline
        david_h
        Hey Chris! thanks for the reply. I feel like a newbie today. Cuz. .I kinda am.
        I am resigned to just reload everything. I'll muddle thru somehow. ๐Ÿ˜„
        https://www.youtube.com/watch?v=2O8gTIr4lys
        So .. .Chris. . .they treatin' ya okay over there in the land of Sketchup? You likin' that new gig?
        • quimQ Offline
          quim
          "Ons Gaan Nou Braai" an old South African Expression for we going to have a party (BBQ).
          Eish dis x64 is moving. loving it.
          WEBSITE http://www.q-prodesigns.co.za
            @david_h said:
            And that is why I didn't upgrade with 13, 14, whatever. I didn't want to slog thru all the plugsin and crap .. .again. Looks like a fun day for me!
            D
            Think of it as a good opportunity to do some housekeeping. Don't install those old plugins you never used anyway.
            • david_hD Offline
              david_h
              That is true. I am doing a lot of housekeeping on plugins. I think I was up to 24,764. I only use about 12.
                There you go! That's one or two plugins you won't need to download. ๐Ÿ˜„
                • david_hD Offline
                  david_h
                  Still having a bit of an issue getting Thea and Podium to show up. But I'm working on it.
                  EDIT Well,. .. just got Thea. . .now onto podium
                  • KrisidiousK Offline
                    Krisidious
                    Remember Thea is updated for 2014 64bit.
                    By: Kristoff Rand
                    • david_hD Offline
                      david_h
                      Yeah. . .I finally figured that one out. I'm getting there. Takes me a while.
                        Bruce Watt
                        Hope that helps!
                        Thats very informative and helpfull. I tried to get Podium walker to instal before reading this and found it was a no go. Guess we need to wait a bit long for these extension installers to be updated.
                        SKUP PRO 2021 latest version / update
                        Windows 10 Pro
                        Dell Alienware Aurora R10 AMD
                        AMD Ryzenโ„ข 9 3900X
                        NVIDIAยฎ GeForce RTXโ„ข 2080 Ti 11GB GDDR6
                        • jeff hammondJ Offline
                          @andybot said:
                          @driven said:
                          SketchUp now starts with a 30 day trial of SketchUp Pro.
                          which is nice...
                          interesting, no more 8 hour trial period? That's too bad imo.
                          [c.t.]
                          maybe people started figuring out you could use free sketchup for everything then sketchup pro only when exporting/importing dwg..
                          8hrs could potentially last all year until the next release when you can start over again
                          [/conspiracy theory]
                            driven
                            been there, got the post card....
                              archheni
                              We experienced some dramatic speed improvements in SU 2015 compared to SU 8!
                              Our files are all usually very large here so we just tested it with one of our current projects..in SU8 it took around 10 min to open the file and around 20 min to export just one single(!) picture with 4000px.
                              Now SU 2015 opens the very same file on the same machine in under 10s and exported the same picture in less than a minute!
                              Thank you for finally listening to your Pro users!!!!
                              • andybotA Offline
                                andybot
                                very impressive. ๐Ÿ˜ Finally had some time to play and it's amazing to be able to work with some files which caused previous versions just absolutely bog down. Here's a 150MB site model from which I was easily able to export an image (ended up using about 4+Gb of system memory. I would have exported larger, but it was about at the available memory limit with my lower spec laptop.) Can't wait for vray2.0 to be functional in 2015 ๐ŸŽ‰
                                  sketchuh
                                  yes yes yes!!!
                                  • Mistro11M Offline
                                    Mistro11
                                    Who said Sketchup being 64bit was not necessary? I'm seeing all kinds of improvements and blockades opened. โ˜€
                                    i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                    Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                    • BoxB Offline
                                      I wonder if people would be seeing performance improvements if they installed the 32bit version instead. By that I mean I'm curious to what degree the under the hood improvements are unrelated to the 64bit setup.
                                        Krisidious
                                        Interesting... Would be nice to know. I might do that tomorrow.
                                        By: Kristoff Rand
                                        • jason_marantoJ Offline
                                          jason_maranto
                                          Bear in mind that to take any program from 32-bit to 64-bit means refactoring all of the old code (this is mostly due to Apples rather stringent 64-bit coding requirements) -- reworking all of that code can have the effect of improving the performance of the software in many subtle ways (just by virtue of getting a fresh perspective on old code).
                                          Those newly reworked bits will often also benefit the 32-bit versions performance.
                                          My only expectation of 64-bit in SketchUp was to enable SketchUp to be a better platform for extensions that wanted to run in 64-bit inside SketchUp. This is a big deal because it enables 3rd parties to code extensions for SketchUp more easily, and in ways that will work better for their software. Since SketchUp is primarily a platform for extensions, anything that makes it easier for the extension developers is an extremely good thing for the end user.
                                          I would not expend alot of energy trying to tie 64-bit capability to SketchUp performance in and of itself. Most performance gains would be a "side effect" of the conversion process. However I will be expecting a noticeable performance gain with 3rd party engines rendering within SketchUp's process.
                                          I also was one of the (apparently rare) users who ran out of memory in modeling operations -- so I expect those issues to be resolved as well.
                                          For most users I think the biggest working performance bottleneck has always been the openGL "styles" rendering -- and these have also been reworked in 2015 with the "fast styles" approach... I think this is a bigger deal for people who only work in SketchUp (however I know of very few people who use SketchUp without a 3rd party render engine).
                                          Also the face finder rework is something that should benefit previously slower processes as well -- so it is not as simple as saying that the only performance difference is because of 64-bit.
                                          Best,
                                          Jason.
                                            Krisidious
                                            I just wanted to use all my ram when I needed it... Nothing worse than paying for hardware you can't use in your most frequently used program.
                                            By: Kristoff Rand
                                            • 15
                                            • 16
                                            • 4 / 16
