    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 53.9k Views 14 Watching
      Can I ask someone to report what you now see in the Shortcutter dialog in SketchUp 2015?
      • KrisidiousK
        Krisidious
        Looks like this on Win 7 in SU 2015 64bit
        By: Kristoff Rand
        • BoxB
            I guess you want to see the end of the list showing either 'Plugins' OR the new-fangled 'Extensions' in v2015.
            I confirm it's now working correctly in v2015. ๐Ÿ˜„
            And in v2014 it shows as 'Plugins' as expected...
              not for me ๐Ÿ˜ž
              time to sue someone
              • BoxB
                ๐Ÿ’š Have you tried clearing your cache
                  Clear your IE cache ?
                  Retry...
                  • P
                    Pherim
                    Still not seeing the Extensions entry...
                      It is not made IF you have no shortcuts set up to access items in the Plugins AKA Extensions menu.
                      You also need to clear your Internet Explorer cache so that any older html/js etc is deleted...
                        I'm still seeing Plugins, not Extensions on my Mac. I've cleared the Safari caches, set a shortcut for an entry in Extensions, quit SketchUp and restarted. Still no Extensions section in the list.
                        • P
                          Pherim
                          Yes, I have changed all shortcuts that were previously assigned to the plugins menu to the extensions menu, as they were still connected with the plugins folder after importing my settings from 2013. I just tried setting a new shortcut but "Extensions" still doesn't show up.
                          And yes I tried deleting the browser cache, I even restarted my PC.
                            What version of SketchUcation PluginStore ?
                            v2.6.1 ?
                              I was on 2.6.2
                              I downgraded to 2.6.1
                              Thing is Gabor's is behaving as expected. My is fubarred
                              • P
                                Pherim
                                Yeah, 2.6.1.
                                  v2.6.1 ?
                                  V2.6.2b2
                                  • BoxB
                                    I also have the B2 that Dave has and it works.
                                    • P
                                      Pherim
                                      Where can I get this 2.6.2?
                                        We privately test upcoming releases amongst a beta group.
                                          Here's the current situation.
                                          PCs
                                          In <=v2014 shortcuts might include 'Plugins/' items.
                                          If you then export a "Preferences.dat" file those shortcuts will include any 'Plugins/' ones.
                                          PCs >=v2015, as it installs earlier shortcuts are 'migrated' from say v2014.
                                          Quite ill-advisedly v2015 has an 'Extensions' menu rather than a 'Plugins' menu.
                                          If you import an earlier-version "Preferences.dat" file into v2015 you might create some shortcuts looking at 'Plugins/', these are ineffective as that menu item does not exist, it never will.
                                          BUT when the list of shortcuts is assembled it includes the spurious 'Plugins/' ones too !
                                          The Shortcutter reports them.
                                          Gรกbor on the sever-side MUST include for 'Plugins' AND 'Extensions'.
                                          If you are on v2015 and it lists ANY items under 'Plugins' you need to reassign them to the equivalent item in the 'Extensions' menu...
                                          You can do that manually, OR if you have an earlier-version "Preferences.dat" you can always edit it using Notepad[++] and find replace 'Plugins/' with 'Extensions/', save it as "Preferences2015.dat", re-import that into v2015, and when prompted choose to overwrite any 'Plugins/' shortcuts with the equivalent 'Extensions/' one...
                                          MACs
                                          The plist contains the shortcuts.
                                          I think that 'Plugins' are reported differently using arcane codes rather than readable paths, they are listed as 'Other/' in the data sent to the server.
                                          Copying the plist between versions should replicate the shortcuts.
                                          I think that Gรกbor currently translates 'Other' as 'Plugins', so in v2015 they are still reported as 'Plugins' even when they appear under 'Extensions' ?
                                          IF Gรกbor can extract the SketchUp version he can decide to use 'Extensions' in >=v2015 ??
                                          • G
                                            Gรกbor
                                            @TIG: See our PM conversation. ๐Ÿ˜„
                                            • 4 / 5
