    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 46.9k Views 14 Watching
      driven
      @ tig
      the mac code I used was
      require "pathname"
      target = Pathname(Sketchup.find_support_files("").grep(/User/)[0]).parent
      shortcuts = Pathname(target + "Shortcuts.plist")
      File.write(shortcuts,File.open(shortcuts,&;read).gsub("Plugins","Extensions")) if File.exists?(shortcuts)
      that's taken out of a general migration assistant but it should work stand-alone...
        It needs a minor adjustment server-side to parse for "^Extensions/|^Plugins/" - GΓ‘bor is on to it...
        It ought to work on PC or MAC as the string passed from the Ruby-side is the same...
          Can I ask someone to report what you now see in the Shortcutter dialog in SketchUp 2015?
          • KrisidiousK Offline
            Krisidious
            Looks like this on Win 7 in SU 2015 64bit
            By: Kristoff Rand
            • BoxB Offline
                I guess you want to see the end of the list showing either 'Plugins' OR the new-fangled 'Extensions' in v2015.
                I confirm it's now working correctly in v2015. πŸ˜„
                And in v2014 it shows as 'Plugins' as expected...
                  not for me 😞
                  time to sue someone
                  • BoxB Offline
                    πŸ’š Have you tried clearing your cache
                      Clear your IE cache ?
                      Retry...
                        Pherim
                        Still not seeing the Extensions entry...
                          It is not made IF you have no shortcuts set up to access items in the Plugins AKA Extensions menu.
                          You also need to clear your Internet Explorer cache so that any older html/js etc is deleted...
                            I'm still seeing Plugins, not Extensions on my Mac. I've cleared the Safari caches, set a shortcut for an entry in Extensions, quit SketchUp and restarted. Still no Extensions section in the list.
                              Pherim
                              Yes, I have changed all shortcuts that were previously assigned to the plugins menu to the extensions menu, as they were still connected with the plugins folder after importing my settings from 2013. I just tried setting a new shortcut but "Extensions" still doesn't show up.
                              And yes I tried deleting the browser cache, I even restarted my PC.
                                What version of SketchUcation PluginStore ?
                                v2.6.1 ?
                                  I was on 2.6.2
                                  I downgraded to 2.6.1
                                  Thing is Gabor's is behaving as expected. My is fubarred
                                    Pherim
                                    Yeah, 2.6.1.
                                      v2.6.1 ?
                                      V2.6.2b2
                                      • BoxB Offline
                                        I also have the B2 that Dave has and it works.
                                          Pherim
                                          Where can I get this 2.6.2?
                                            We privately test upcoming releases amongst a beta group.
                                            • 4 / 5
