    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 46.9k Views 14 Watching
      Pherim
      Still not seeing the Extensions entry...
        It is not made IF you have no shortcuts set up to access items in the Plugins AKA Extensions menu.
        You also need to clear your Internet Explorer cache so that any older html/js etc is deleted...
          I'm still seeing Plugins, not Extensions on my Mac. I've cleared the Safari caches, set a shortcut for an entry in Extensions, quit SketchUp and restarted. Still no Extensions section in the list.
            Pherim
            Yes, I have changed all shortcuts that were previously assigned to the plugins menu to the extensions menu, as they were still connected with the plugins folder after importing my settings from 2013. I just tried setting a new shortcut but "Extensions" still doesn't show up.
            And yes I tried deleting the browser cache, I even restarted my PC.
              What version of SketchUcation PluginStore ?
              v2.6.1 ?
                I was on 2.6.2
                I downgraded to 2.6.1
                Thing is Gabor's is behaving as expected. My is fubarred
                  Pherim
                  Yeah, 2.6.1.
                    v2.6.1 ?
                    V2.6.2b2
                    • BoxB Offline
                      I also have the B2 that Dave has and it works.
                        Pherim
                        Where can I get this 2.6.2?
                          We privately test upcoming releases amongst a beta group.
                            Here's the current situation.
                            PCs
                            In <=v2014 shortcuts might include 'Plugins/' items.
                            If you then export a "Preferences.dat" file those shortcuts will include any 'Plugins/' ones.
                            PCs >=v2015, as it installs earlier shortcuts are 'migrated' from say v2014.
                            Quite ill-advisedly v2015 has an 'Extensions' menu rather than a 'Plugins' menu.
                            If you import an earlier-version "Preferences.dat" file into v2015 you might create some shortcuts looking at 'Plugins/', these are ineffective as that menu item does not exist, it never will.
                            BUT when the list of shortcuts is assembled it includes the spurious 'Plugins/' ones too !
                            The Shortcutter reports them.
                            Gábor on the sever-side MUST include for 'Plugins' AND 'Extensions'.
                            If you are on v2015 and it lists ANY items under 'Plugins' you need to reassign them to the equivalent item in the 'Extensions' menu...
                            You can do that manually, OR if you have an earlier-version "Preferences.dat" you can always edit it using Notepad[++] and find replace 'Plugins/' with 'Extensions/', save it as "Preferences2015.dat", re-import that into v2015, and when prompted choose to overwrite any 'Plugins/' shortcuts with the equivalent 'Extensions/' one...
                            MACs
                            The plist contains the shortcuts.
                            I think that 'Plugins' are reported differently using arcane codes rather than readable paths, they are listed as 'Other/' in the data sent to the server.
                            Copying the plist between versions should replicate the shortcuts.
                            I think that Gábor currently translates 'Other' as 'Plugins', so in v2015 they are still reported as 'Plugins' even when they appear under 'Extensions' ?
                            IF Gábor can extract the SketchUp version he can decide to use 'Extensions' in >=v2015 ??
                              Gábor
                              @TIG: See our PM conversation. 😄
                                driven
                                I see Extensions, what's so arcane? migrated Plugins...
                                  No issues.
                                  It turns out that on MACs Gábor keeps 'Other' and also uses 'Plugins' OR 'Extensions' when they are available...
                                  In the MAC's plist it's difficult to trap where some menu items are, so they go in 'Other' [not used on PCs], and the 'Plugins'/AKA 'Extensions' list is also used if they have entries.
                                  Reading the MAC's plist into a 'readable' format is the challenge...
                                  On the PC we need to trap for users who import a dat file from an older version that includes 'Plugins/...' as that is NOT reflected in a corresponding 'Extensions/...' entry...
                                  At least the report'd show them what's up in v2015 !
                                    @pherim said:
                                    Not really sure what you're trying to say with your last paragraph, but as I said before, I had already changed all Shortcuts to the extensions menu before I even reported this problem here. Still, extensions does not show up at all.
                                    edit: alright, I finally got it. I had to reset Shortcuts completely and then assign new shortcuts altogether, and now Extensions shows up.
                                    Not sure what you did 😕
                                    But for most PC users Extensions DO list properly.
                                    Have you resized the dialog to see the bottom part ?
                                    Have you definitely cleared the Internet Explorer cache ?
                                    The only 'real' PC issue is displaying Extensions AND Plugins in v2015, if the user has imported an older dat file...
                                      Pherim
                                      edit: alright, I finally got it. I had to reset Shortcuts completely and then assign new shortcuts altogether, and now Extensions has appeared. But importing from SU2013 (probably 2014 as well) doesn't seem to work at all, I tried exporting and re-importing the settings from 2015, but Extensions was gone again, even though there were no shortcuts left that pointed to "Plugins".
                                        I did no import of dat files on 2015
                                          Pherim
                                          And it's gone again... maybe I try to assign a shortcut it doesn't like to a function it doesn't like, but then again it works in SU2013.
                                            So you ought to have NO 'Plugins/...' entries ?
                                            If you use Sketchup.get_shortcuts.grep(/Plugin/) do you get a result ?
                                            If so, then it begs the question, "How did 'they' get there?"
                                            When v2015 installs and brings over the earlier versions shortcuts does it not make Plugins >>> Extensions, maybe not...
                                            At least the "Shortcutter" can show users of v2015 those shortcuts incorrectly pointing at a non-existent Plugins menu !
                                            They can then export the v2015 Preferences.dat, use Notepad++ to edit it and replace 'Plugins/' with 'Extensions/' ans save, then import it back in, accepting the overwrite of the incorrect shortcuts.
                                            When "Shortcutter" works again there should be no 'Plugins' items listed, as they will have all been moved to be 'Extensions' ?
                                            • 4 / 5
