    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 53.9k Views 14 Watching
      Thanks for flagging it.
        We are working on it !
          driven
          @ tig
          the mac code I used was
          require "pathname"
          target = Pathname(Sketchup.find_support_files("").grep(/User/)[0]).parent
          shortcuts = Pathname(target + "Shortcuts.plist")
          File.write(shortcuts,File.open(shortcuts,&;read).gsub("Plugins","Extensions")) if File.exists?(shortcuts)
          that's taken out of a general migration assistant but it should work stand-alone...
            It needs a minor adjustment server-side to parse for "^Extensions/|^Plugins/" - GΓ‘bor is on to it...
            It ought to work on PC or MAC as the string passed from the Ruby-side is the same...
              Can I ask someone to report what you now see in the Shortcutter dialog in SketchUp 2015?
              • KrisidiousK
                Krisidious
                Looks like this on Win 7 in SU 2015 64bit
                By: Kristoff Rand
                • BoxB
                    I guess you want to see the end of the list showing either 'Plugins' OR the new-fangled 'Extensions' in v2015.
                    I confirm it's now working correctly in v2015. πŸ˜„
                    And in v2014 it shows as 'Plugins' as expected...
                      not for me 😞
                      time to sue someone
                      • BoxB
                        πŸ’š Have you tried clearing your cache
                          Clear your IE cache ?
                          Retry...
                          • P
                            Pherim
                            Still not seeing the Extensions entry...
                              It is not made IF you have no shortcuts set up to access items in the Plugins AKA Extensions menu.
                              You also need to clear your Internet Explorer cache so that any older html/js etc is deleted...
                                I'm still seeing Plugins, not Extensions on my Mac. I've cleared the Safari caches, set a shortcut for an entry in Extensions, quit SketchUp and restarted. Still no Extensions section in the list.
                                • P
                                  Pherim
                                  Yes, I have changed all shortcuts that were previously assigned to the plugins menu to the extensions menu, as they were still connected with the plugins folder after importing my settings from 2013. I just tried setting a new shortcut but "Extensions" still doesn't show up.
                                  And yes I tried deleting the browser cache, I even restarted my PC.
                                    What version of SketchUcation PluginStore ?
                                    v2.6.1 ?
                                      I was on 2.6.2
                                      I downgraded to 2.6.1
                                      Thing is Gabor's is behaving as expected. My is fubarred
                                      • P
                                        Pherim
                                        Yeah, 2.6.1.
                                          v2.6.1 ?
                                          V2.6.2b2
                                          • BoxB
                                            I also have the B2 that Dave has and it works.
                                            • 4 / 5
