    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 22.6k Views 18 Watching
      driven
      hi,
      very interesting...
      I thought maybe you could ask to change perspective...
            #test perspective, if parallel, ask to change now, or return
            if !cam.perspective? then
             result = UI.messagebox('Camera must be perspective, not parallel, change now?', MB_YESNO)
               if result == IDYES
                 cam.perspective = true
               else
                return
      I'll have a closer look if i get a chance...
      • rami_lpmR Offline
        rami_lpm
        I'm not sure. Most panoramas require a carefully placed camera.
        If I switch automatically from a parallel camera, I don't know if the panorama will be useful. Remember that writing the images can take several minutes.
        Thanks for the advice anyway.
          T774AM12RUS
          Hello
          I have an error window on start:
          Error Loading File RamTools_Panorama.rb
          C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ',', expecting '='
          ...name="pano", html_template_fn,css_filename, js_template_fn)
          C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ')', expecting '='
          C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:703: syntax error, unexpected kEND, expecting $end
          end #module pano
          • rami_lpmR Offline
            rami_lpm
            Yes, that's because v0.3 didn't support SU8. The newest version(0.31) should work fine.
            • erikBE Offline
              erikB
              srx,
              would you mind posting a step by step description how you used this plugin and su4thea to create your rendered panos ?
              erikB
              • srxS Offline
                srx
                @erikb said:
                srx,
                erikB
                Nothing serious...
                1 Make WEBGL panorama with plugin. It will create images named pano001, pano002 etc in the folder panorama. Check if it works.
                2 Use "Save current camera scenes" option of the plugin to create SketchUp scenes.
                3 Render those scenes with SU4Thea(do not use Vigneting) and save each rendered scene over the matching pano001,... from the step 1
                That's all.
                www.saurus.rs
                • erikBE Offline
                  erikB
                  srx,
                  Sorry to bother you again, but what I could not figure out is still unclear. Where is the option to "save current camera scenes" of the plugin ?
                  PS.
                  erikB
                  Win 7 64
                    In SU place the camera where you would like the panorama to be generated from.
                    Create a scene
                    Now under Plugins > Panorama > Save Current Camera Scenes
                    This will generate the cubic scenes from that scene. The scenes name will be prefixed and suffixed with p[scene_name]_# eg Scene 1 will have 6 new scenes added called Scene 1_1, Scene 1_2 etc.....
                    Use these scenes in Thea
                    • erikBE Offline
                      erikB
                      thank you,
                      Just found it myself. Lesson 1: "read" the comments from the maker. I was only working with the icons toolbar and could not understand why I couldn't find it. ๐Ÿ˜ณ
                      anyway thanks Rich
                        testing something
                        {edit}killed test{edit}
                        • rami_lpmR Offline
                          rami_lpm
                          Hey. Sorry, I didn't make a button for that because I still haven't found a way to undo it, and so many scenes can disorganize your model very quickly. (you can always delete them manually, but I find it awkward)
                          Rich, that is awesome, I didn't know you could insert stuff like that in phpBB.
                            driven
                            @Rich
                            your test breaks the page in Safari...
                            I had to disable images to post...
                              weird, I fail to understand why?
                                No zoom on the Panorama ?
                                • rami_lpmR Offline
                                  rami_lpm
                                  I think I can make it zoom. I'm not a java whiz but I'll give it a try.
                                  Edit: ok, it should work now.
                                  • jo-keJ Offline
                                    jo-ke
                                    zoom is possible with the mouse wheel.
                                    very nice plugin. I always wanted to have a pure SU- pano. That's it!
                                    http://www.zz7.de
                                    • W Offline
                                      wehby
                                      Rami,
                                      Nice work on the script. It contains a lot of the features that I had hoped the next version of CubicPanoOut would contain.
                                      Regards,
                                      wehby
                                      • rami_lpmR Offline
                                        rami_lpm
                                        hey, you're welcome. I wrote this because I needed an easier CubicPanoOut.
                                        • F Offline
                                          framed
                                          Thanks for the fantastic plugin! Is it possible to restrict the pano extents to create partial panoramas (i.e. not 360 degrees)?
                                          • rami_lpmR Offline
                                            rami_lpm
                                            yes, but you'll have to modify a bit of code.
                                            open the file pano0.js with notepad, should be on the same folder as the panoramic images.
                                            (the name may be different, but the same as the .html file that shows the panorama)
                                            add this under line 100 ( the one that goes lat=00;lon=00 )
                                            leftLimit=lon-90;rightLimit=lon+90;bottomLimit=lat-80;topLimit=lat+80;
                                            you can modify this angles to the values you need.
                                            then add this under line 107 ( function update(){ )
                                            if ( lon < leftLimit ) { lon = leftLimit };if ( lon > rightLimit ) { lon = rightLimit };if ( lat < bottomLimit ) { lat = bottomLimit };if ( lat > topLimit ) { lat = topLimit };
                                            and that should do it.
                                            I'll make this easier when I get the time.
                                            I'm here if you have any questions.
                                            thanks for using my plugin.
                                            • 2 / 4
