    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 24.1k Views 18 Watching
    • rami_lpmR
      rami_lpm
      @erikb said:
      I was only working with the icons toolbar
      Hey. Sorry, I didn't make a button for that because I still haven't found a way to undo it, and so many scenes can disorganize your model very quickly. (you can always delete them manually, but I find it awkward)
      Rich, that is awesome, I didn't know you could insert stuff like that in phpBB.
        driven
        @Rich
        your test breaks the page in Safari...
        I had to disable images to post...
          weird, I fail to understand why?
            No zoom on the Panorama ?
            • rami_lpmR
              rami_lpm
              I think I can make it zoom. I'm not a java whiz but I'll give it a try.
              Edit: ok, it should work now.
              • jo-keJ
                jo-ke
                zoom is possible with the mouse wheel.
                very nice plugin. I always wanted to have a pure SU- pano. That's it!
                http://www.zz7.de
                • W
                  wehby
                  Rami,
                  Nice work on the script. It contains a lot of the features that I had hoped the next version of CubicPanoOut would contain.
                  Regards,
                  wehby
                  • rami_lpmR
                    rami_lpm
                    hey, you're welcome. I wrote this because I needed an easier CubicPanoOut.
                    • F
                      framed
                      Thanks for the fantastic plugin! Is it possible to restrict the pano extents to create partial panoramas (i.e. not 360 degrees)?
                      • rami_lpmR
                        rami_lpm
                        yes, but you'll have to modify a bit of code.
                        open the file pano0.js with notepad, should be on the same folder as the panoramic images.
                        (the name may be different, but the same as the .html file that shows the panorama)
                        add this under line 100 ( the one that goes lat=00;lon=00 )
                        leftLimit=lon-90;rightLimit=lon+90;bottomLimit=lat-80;topLimit=lat+80;
                        you can modify this angles to the values you need.
                        then add this under line 107 ( function update(){ )
                        if ( lon < leftLimit ) { lon = leftLimit };if ( lon > rightLimit ) { lon = rightLimit };if ( lat < bottomLimit ) { lat = bottomLimit };if ( lat > topLimit ) { lat = topLimit };
                        and that should do it.
                        I'll make this easier when I get the time.
                        I'm here if you have any questions.
                        thanks for using my plugin.
                        • F
                          framed
                          Thanks for your quick response. Using the extra lines of code you provided worked, kind of. You can still pan beyond the limit then it snaps back. This is a bit ugly. What would be better is if the pano hits a wall at the limit, can't go any further, and doesn't render anything beyond the limit. Is this possible?
                          Also, I note that when using the Canvas renderer, there is warping of the images (straight lines get drawn squiggly) and there are vertical lines at the image joins. Can this be fixed? WebGL doesn't have these issues so I'm just using that instead.
                          • rami_lpmR
                            rami_lpm
                            That's strange, it should stop, not pan beyond the limit.
                            It's not possible to stop rendering after the limit because of the way the plugin is built.
                            What's your browser and version?
                            Can you send me the files so I can test it?
                            Thanks.
                            • F
                              faust07
                              Works great even with pictures from scenes of external renderers. Issuing panoramas directly from SketchUp results for large models to the known clipping problem, especially from the pedestrian perspective in the bottom area. And especially when shadows are enabled.
                              A short question: Is it feasible to reduce the many generated files to one html Start file and another file containing everything else (especially with several panoramas)?
                              • rami_lpmR
                                rami_lpm
                                I work in metric and rarely encountered the clipping problem.
                                Can you try scaling up the model before taking the panorama? (a pain, I know, but the only solution I can think of)
                                Sadly, no. I can't reduce the number of files. Each file is required and I don't know a way of packing them all together.
                                Maybe you can try generating the images with CubicPanoOut and stitching them with GoCubic. This outputs a single quicktime file for each panorama.
                                That is what I used to do before writing this plugin (so I could stop relying on quicktime).
                                CubicPanoOut
                                GoCubic
                                Anyway, I'll try and find a 'one file' solution.
                                • F
                                  faust07
                                  Thank you for your quick response. The clipping problem is already mitigated by the possibility of external rendering of scenes. Reducing the number of files is only for the ease of use for normal users, clients or patients ... πŸ˜‰
                                  • rami_lpmR
                                    rami_lpm
                                    No problem.
                                    Hey, it turns out you can inline almost everything into a single html file. See this two articles. I'll see what I can do with this.
                                    Offline Application
                                    Inliner
                                    • F
                                      faust07
                                      That sounds great! I have looked into it ... I once - over 20 years ago - programmed a little and am now primarily user. So I understand very little and can only be amazed by your progress.
                                      • rami_lpmR
                                        rami_lpm
                                        I just updated the plugin.
                                        It should be able to wrap every panorama inside one rather big html file.
                                        Also, I realized that I myself started learning to code 20 years ago. Now I feel old. =P
                                        • OxerO
                                          Oxer
                                          Thanks for the plugin!!
                                          I use Thea Render and works fine replacing the images generated for the plugin with images generated for Thea Render, only one question, when I select Custom Template, the titles to select the different filetype don't appear in the pop-up windows, see the image.
                                          MAC 0S X 10.11.4 & SU2016
                                          • rami_lpmR
                                            rami_lpm
                                            Thank you for the feedback.
                                            That's a strange behavior. 'custom template' requests three template files: html, css and js in that order.
                                            Can you try pasting this line in the ruby console and telling me if it shows the title?
                                            UI.openpanel("can you read this?", "~/","yes")
                                            • 2 / 4
