    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 24.1k Views 18 Watching
    • srxS
      srx
      I tried to create scenes with CubicPanoOut plugin, renamed and replaced images in html folder, and they don't match. Would be great to have this option. The easy way of making rendered WEB panoramas. 😄
      www.saurus.rs
      • cottyC
        cotty
        This should work (did you turn on shadows?), I've tried this workflow long time ago with Indigo: http://www.indigorenderer.com/forum/viewtopic.php?f=19%26amp;t=10942
        my SketchUp gallery
        • rami_lpmR
          rami_lpm
          I added the menu entry. It saves the scenes and shows in the console each scene's filename.
          I haven't found a way to allow undoing, so be careful.
          • rami_lpmR
            rami_lpm
            Adding the option to make the scenes shouldn't be such a problem. I'll get on it.
            I wasn't aware of Renderiza PanoScene.
            It's strange that the output from cubicpanoout doesn't work with my html. Its basically the same concept and output.
            (edit: on second thought no, it is not. I had to change the scenes order and rotation to make work easier with WebGL )
            • srxS
              srx
              It works! I checked with Thea render. All I had to do was to adjust the resolution to 2048x2048. Making WEB panorama in a few minutes (+ rendering time). Thank you for making this possible. 😍
              www.saurus.rs
              • rami_lpmR
                rami_lpm
                Good. I'll get a renderer and take a look.
                • srxS
                  srx
                  Here is my try.
                  6 preview images rendered in Thea4SU, Presto engine, 1 minute each, 6 minutes all.
                  All in all from model to web panorama in 10 minutes!
                  I made a mistake of adding vignetting which is seen in panorama...Other then that very good result.
                  404 Not Found
                  (www.saurus.rs)
                  Thanks again. 👍
                  www.saurus.rs
                  • G
                    gashtan
                    I have som problem with this plugin...need I install Three.js too? If I install plugin, ruby window write me an error
                    Error Loading File RamTools_Panorama.rb
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; odd number list for Hash
                    						@options = { title; "RamTools Panorama Output", r...
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '}'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ',', expecting kEND
                    ...e; "RamTools Panorama Output", renderer; "Canvas", askFolder...
                    ...a Output", renderer; "Canvas", askFolder; "No", fov; "55", p...
                    ...er; "Canvas", askFolder; "No", fov; "55", path; "Ask", compV...
                    ...", askFolder; "No", fov; "55", path; "Ask", compVal; "0.6", ...
                    ... "No", fov; "55", path; "Ask", compVal; "0.6", isDebug; fals...
                    ..., path; "Ask", compVal; "0.6", isDebug; false, tTag; true, i...
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to false
                    ...ompVal; "0.6", isDebug; false, tTag; true, imgRes; "2048", o...
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '='
                    ...; "0.6", isDebug; false, tTag; true, imgRes; "2048", ownTemp...
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to true
                    ...", isDebug; false, tTag; true, imgRes; "2048", ownTemplate; ...
                    ...ug; false, tTag; true, imgRes; "2048", ownTemplate; false, i...
                    ...e, tTag; true, imgRes; "2048", ownTemplate; false, invContro...
                    ...s; "2048", ownTemplate; false, invControls; "No", fnHtml; "t...
                    ...nTemplate; false, invControls; "No", fnHtml; "template2.html...
                    ...ate; false, invControls; "No", fnHtml; "template2.html", fnC...
                    ...No", fnHtml; "template2.html", fnCss;"template2.css", fnJs; ...
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting kEND
                    ..., fnCss;"template2.css", fnJs; "template2.js" }
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected '}', expecting kEND
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ',', expecting '='
                    ...name="pano", html_template_fn,css_filename, js_template_fn)
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ')', expecting '='
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;703; syntax error, unexpected $end, expecting kEND
                    file_loaded( __FILE__ )
                    Is it compatibile with SU8 anyway? Thanks for your answer.
                    • rami_lpmR
                      rami_lpm
                      I think not, sorry. They changed the ruby version for sketchup 2014. I think it has to do with that. I'll see if I can fix it.
                        driven
                        hi,
                        very interesting...
                        I thought maybe you could ask to change perspective...
                              #test perspective, if parallel, ask to change now, or return
                              if !cam.perspective? then
                               result = UI.messagebox('Camera must be perspective, not parallel, change now?', MB_YESNO)
                                 if result == IDYES
                                   cam.perspective = true
                                 else
                                  return
                        I'll have a closer look if i get a chance...
                        • rami_lpmR
                          rami_lpm
                          I'm not sure. Most panoramas require a carefully placed camera.
                          If I switch automatically from a parallel camera, I don't know if the panorama will be useful. Remember that writing the images can take several minutes.
                          Thanks for the advice anyway.
                          • T
                            T774AM12RUS
                            Hello
                            I have an error window on start:
                            C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ',', expecting '='
                            C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ')', expecting '='
                            C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:703: syntax error, unexpected kEND, expecting $end
                            end #module pano
                            • rami_lpmR
                              rami_lpm
                              Yes, that's because v0.3 didn't support SU8. The newest version(0.31) should work fine.
                              • erikBE
                                erikB
                                srx,
                                would you mind posting a step by step description how you used this plugin and su4thea to create your rendered panos ?
                                erikB
                                • srxS
                                  srx
                                  @erikb said:
                                  srx,
                                  erikB
                                  Nothing serious...
                                  1 Make WEBGL panorama with plugin. It will create images named pano001, pano002 etc in the folder panorama. Check if it works.
                                  2 Use "Save current camera scenes" option of the plugin to create SketchUp scenes.
                                  3 Render those scenes with SU4Thea(do not use Vigneting) and save each rendered scene over the matching pano001,... from the step 1
                                  That's all.
                                  www.saurus.rs
                                  • erikBE
                                    erikB
                                    srx,
                                    Sorry to bother you again, but what I could not figure out is still unclear. Where is the option to "save current camera scenes" of the plugin ?
                                    PS.
                                    erikB
                                    Win 7 64
                                      In SU place the camera where you would like the panorama to be generated from.
                                      Create a scene
                                      Now under Plugins > Panorama > Save Current Camera Scenes
                                      This will generate the cubic scenes from that scene. The scenes name will be prefixed and suffixed with p[scene_name]_# eg Scene 1 will have 6 new scenes added called Scene 1_1, Scene 1_2 etc.....
                                      Use these scenes in Thea
                                      • erikBE
                                        erikB
                                        thank you,
                                        Just found it myself. Lesson 1: "read" the comments from the maker. I was only working with the icons toolbar and could not understand why I couldn't find it. 😳
                                        anyway thanks Rich
                                          testing something
                                          {edit}killed test{edit}
                                          • rami_lpmR
                                            rami_lpm
                                            Hey. Sorry, I didn't make a button for that because I still haven't found a way to undo it, and so many scenes can disorganize your model very quickly. (you can always delete them manually, but I find it awkward)
                                            Rich, that is awesome, I didn't know you could insert stuff like that in phpBB.
                                            • 1 / 4
