    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 24.1k Views 18 Watching
    • rami_lpmR
      rami_lpm
      Adding the option to make the scenes shouldn't be such a problem. I'll get on it.
      I wasn't aware of Renderiza PanoScene.
      It's strange that the output from cubicpanoout doesn't work with my html. Its basically the same concept and output.
      (edit: on second thought no, it is not. I had to change the scenes order and rotation to make work easier with WebGL )
      • srxS
        srx
        It works! I checked with Thea render. All I had to do was to adjust the resolution to 2048x2048. Making WEB panorama in a few minutes (+ rendering time). Thank you for making this possible. 😍
        www.saurus.rs
        • rami_lpmR
          rami_lpm
          Good. I'll get a renderer and take a look.
          • srxS
            srx
            Here is my try.
            6 preview images rendered in Thea4SU, Presto engine, 1 minute each, 6 minutes all.
            All in all from model to web panorama in 10 minutes!
            I made a mistake of adding vignetting which is seen in panorama...Other then that very good result.
            404 Not Found
            (www.saurus.rs)
            Thanks again. 👍
            www.saurus.rs
            • G
              gashtan
              I have som problem with this plugin...need I install Three.js too? If I install plugin, ruby window write me an error
              Error Loading File RamTools_Panorama.rb
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; odd number list for Hash
              						@options = { title; "RamTools Panorama Output", r...
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '}'
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ',', expecting kEND
              ...e; "RamTools Panorama Output", renderer; "Canvas", askFolder...
              ...a Output", renderer; "Canvas", askFolder; "No", fov; "55", p...
              ...er; "Canvas", askFolder; "No", fov; "55", path; "Ask", compV...
              ...", askFolder; "No", fov; "55", path; "Ask", compVal; "0.6", ...
              ... "No", fov; "55", path; "Ask", compVal; "0.6", isDebug; fals...
              ..., path; "Ask", compVal; "0.6", isDebug; false, tTag; true, i...
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to false
              ...ompVal; "0.6", isDebug; false, tTag; true, imgRes; "2048", o...
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '='
              ...; "0.6", isDebug; false, tTag; true, imgRes; "2048", ownTemp...
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to true
              ...", isDebug; false, tTag; true, imgRes; "2048", ownTemplate; ...
              ...ug; false, tTag; true, imgRes; "2048", ownTemplate; false, i...
              ...e, tTag; true, imgRes; "2048", ownTemplate; false, invContro...
              ...s; "2048", ownTemplate; false, invControls; "No", fnHtml; "t...
              ...nTemplate; false, invControls; "No", fnHtml; "template2.html...
              ...ate; false, invControls; "No", fnHtml; "template2.html", fnC...
              ...No", fnHtml; "template2.html", fnCss;"template2.css", fnJs; ...
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting kEND
              ..., fnCss;"template2.css", fnJs; "template2.js" }
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected '}', expecting kEND
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ',', expecting '='
              ...name="pano", html_template_fn,css_filename, js_template_fn)
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ')', expecting '='
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;703; syntax error, unexpected $end, expecting kEND
              file_loaded( __FILE__ )
              Is it compatibile with SU8 anyway? Thanks for your answer.
              • rami_lpmR
                rami_lpm
                I think not, sorry. They changed the ruby version for sketchup 2014. I think it has to do with that. I'll see if I can fix it.
                  driven
                  hi,
                  very interesting...
                  I thought maybe you could ask to change perspective...
                        #test perspective, if parallel, ask to change now, or return
                        if !cam.perspective? then
                         result = UI.messagebox('Camera must be perspective, not parallel, change now?', MB_YESNO)
                           if result == IDYES
                             cam.perspective = true
                           else
                            return
                  I'll have a closer look if i get a chance...
                  • rami_lpmR
                    rami_lpm
                    I'm not sure. Most panoramas require a carefully placed camera.
                    If I switch automatically from a parallel camera, I don't know if the panorama will be useful. Remember that writing the images can take several minutes.
                    Thanks for the advice anyway.
                    • T
                      T774AM12RUS
                      Hello
                      I have an error window on start:
                      C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ',', expecting '='
                      C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ')', expecting '='
                      C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:703: syntax error, unexpected kEND, expecting $end
                      end #module pano
                      • rami_lpmR
                        rami_lpm
                        Yes, that's because v0.3 didn't support SU8. The newest version(0.31) should work fine.
                        • erikBE
                          erikB
                          srx,
                          would you mind posting a step by step description how you used this plugin and su4thea to create your rendered panos ?
                          erikB
                          • srxS
                            srx
                            @erikb said:
                            srx,
                            erikB
                            Nothing serious...
                            1 Make WEBGL panorama with plugin. It will create images named pano001, pano002 etc in the folder panorama. Check if it works.
                            2 Use "Save current camera scenes" option of the plugin to create SketchUp scenes.
                            3 Render those scenes with SU4Thea(do not use Vigneting) and save each rendered scene over the matching pano001,... from the step 1
                            That's all.
                            www.saurus.rs
                            • erikBE
                              erikB
                              srx,
                              Sorry to bother you again, but what I could not figure out is still unclear. Where is the option to "save current camera scenes" of the plugin ?
                              PS.
                              erikB
                              Win 7 64
                                In SU place the camera where you would like the panorama to be generated from.
                                Create a scene
                                Now under Plugins > Panorama > Save Current Camera Scenes
                                This will generate the cubic scenes from that scene. The scenes name will be prefixed and suffixed with p[scene_name]_# eg Scene 1 will have 6 new scenes added called Scene 1_1, Scene 1_2 etc.....
                                Use these scenes in Thea
                                • erikBE
                                  erikB
                                  thank you,
                                  Just found it myself. Lesson 1: "read" the comments from the maker. I was only working with the icons toolbar and could not understand why I couldn't find it. 😳
                                  anyway thanks Rich
                                    testing something
                                    {edit}killed test{edit}
                                    • rami_lpmR
                                      rami_lpm
                                      Hey. Sorry, I didn't make a button for that because I still haven't found a way to undo it, and so many scenes can disorganize your model very quickly. (you can always delete them manually, but I find it awkward)
                                      Rich, that is awesome, I didn't know you could insert stuff like that in phpBB.
                                        driven
                                        @Rich
                                        your test breaks the page in Safari...
                                        I had to disable images to post...
                                          weird, I fail to understand why?
                                            No zoom on the Panorama ?
                                            • 1 / 4
