    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 24.1k Views 18 Watching
    • rami_lpmR
      rami_lpm
      @gashtan said:
      Is it compatibile with SU8 anyway?
      I think not, sorry. They changed the ruby version for sketchup 2014. I think it has to do with that. I'll see if I can fix it.
        driven
        hi,
        very interesting...
        I thought maybe you could ask to change perspective...
              #test perspective, if parallel, ask to change now, or return
              if !cam.perspective? then
               result = UI.messagebox('Camera must be perspective, not parallel, change now?', MB_YESNO)
                 if result == IDYES
                   cam.perspective = true
                 else
                  return
        I'll have a closer look if i get a chance...
        • rami_lpmR
          rami_lpm
          I'm not sure. Most panoramas require a carefully placed camera.
          If I switch automatically from a parallel camera, I don't know if the panorama will be useful. Remember that writing the images can take several minutes.
          Thanks for the advice anyway.
          • T
            T774AM12RUS
            Hello
            I have an error window on start:
            Error Loading File RamTools_Panorama.rb
            C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ',', expecting '='
            ...name="pano", html_template_fn,css_filename, js_template_fn)
            C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ')', expecting '='
            C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:703: syntax error, unexpected kEND, expecting $end
            end #module pano
            • rami_lpmR
              rami_lpm
              Yes, that's because v0.3 didn't support SU8. The newest version(0.31) should work fine.
              • erikBE
                erikB
                srx,
                would you mind posting a step by step description how you used this plugin and su4thea to create your rendered panos ?
                erikB
                • srxS
                  srx
                  @erikb said:
                  srx,
                  erikB
                  Nothing serious...
                  1 Make WEBGL panorama with plugin. It will create images named pano001, pano002 etc in the folder panorama. Check if it works.
                  2 Use "Save current camera scenes" option of the plugin to create SketchUp scenes.
                  3 Render those scenes with SU4Thea(do not use Vigneting) and save each rendered scene over the matching pano001,... from the step 1
                  That's all.
                  www.saurus.rs
                  • erikBE
                    erikB
                    srx,
                    Sorry to bother you again, but what I could not figure out is still unclear. Where is the option to "save current camera scenes" of the plugin ?
                    PS.
                    erikB
                    Win 7 64
                      In SU place the camera where you would like the panorama to be generated from.
                      Create a scene
                      Now under Plugins > Panorama > Save Current Camera Scenes
                      This will generate the cubic scenes from that scene. The scenes name will be prefixed and suffixed with p[scene_name]_# eg Scene 1 will have 6 new scenes added called Scene 1_1, Scene 1_2 etc.....
                      Use these scenes in Thea
                      • erikBE
                        erikB
                        thank you,
                        Just found it myself. Lesson 1: "read" the comments from the maker. I was only working with the icons toolbar and could not understand why I couldn't find it. ๐Ÿ˜ณ
                        anyway thanks Rich
                          testing something
                          {edit}killed test{edit}
                          • rami_lpmR
                            rami_lpm
                            Hey. Sorry, I didn't make a button for that because I still haven't found a way to undo it, and so many scenes can disorganize your model very quickly. (you can always delete them manually, but I find it awkward)
                            Rich, that is awesome, I didn't know you could insert stuff like that in phpBB.
                              driven
                              @Rich
                              your test breaks the page in Safari...
                              I had to disable images to post...
                                weird, I fail to understand why?
                                  No zoom on the Panorama ?
                                  • rami_lpmR
                                    rami_lpm
                                    I think I can make it zoom. I'm not a java whiz but I'll give it a try.
                                    Edit: ok, it should work now.
                                    • jo-keJ
                                      jo-ke
                                      zoom is possible with the mouse wheel.
                                      very nice plugin. I always wanted to have a pure SU- pano. That's it!
                                      http://www.zz7.de
                                      • W
                                        wehby
                                        Rami,
                                        Nice work on the script. It contains a lot of the features that I had hoped the next version of CubicPanoOut would contain.
                                        Regards,
                                        wehby
                                        • rami_lpmR
                                          rami_lpm
                                          hey, you're welcome. I wrote this because I needed an easier CubicPanoOut.
                                          • F
                                            framed
                                            Thanks for the fantastic plugin! Is it possible to restrict the pano extents to create partial panoramas (i.e. not 360 degrees)?
                                            • 2 / 4
