    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 22.6k Views 18 Watching
    • srxS Offline
      srx
      Here is my try.
      6 preview images rendered in Thea4SU, Presto engine, 1 minute each, 6 minutes all.
      All in all from model to web panorama in 10 minutes!
      I made a mistake of adding vignetting which is seen in panorama...Other then that very good result.
      404 Not Found
      (www.saurus.rs)
      Thanks again. 👍
      www.saurus.rs
        gashtan
        I have som problem with this plugin...need I install Three.js too? If I install plugin, ruby window write me an error
        Error Loading File RamTools_Panorama.rb
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; odd number list for Hash
        						@options = { title; "RamTools Panorama Output", r...
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '}'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ',', expecting kEND
        ...e; "RamTools Panorama Output", renderer; "Canvas", askFolder...
        ...a Output", renderer; "Canvas", askFolder; "No", fov; "55", p...
        ...er; "Canvas", askFolder; "No", fov; "55", path; "Ask", compV...
        ...", askFolder; "No", fov; "55", path; "Ask", compVal; "0.6", ...
        ... "No", fov; "55", path; "Ask", compVal; "0.6", isDebug; fals...
        ..., path; "Ask", compVal; "0.6", isDebug; false, tTag; true, i...
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to false
        ...ompVal; "0.6", isDebug; false, tTag; true, imgRes; "2048", o...
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '='
        ...; "0.6", isDebug; false, tTag; true, imgRes; "2048", ownTemp...
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to true
        ...", isDebug; false, tTag; true, imgRes; "2048", ownTemplate; ...
        ...ug; false, tTag; true, imgRes; "2048", ownTemplate; false, i...
        ...e, tTag; true, imgRes; "2048", ownTemplate; false, invContro...
        ...s; "2048", ownTemplate; false, invControls; "No", fnHtml; "t...
        ...nTemplate; false, invControls; "No", fnHtml; "template2.html...
        ...ate; false, invControls; "No", fnHtml; "template2.html", fnC...
        ...No", fnHtml; "template2.html", fnCss;"template2.css", fnJs; ...
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting kEND
        ..., fnCss;"template2.css", fnJs; "template2.js" }
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected '}', expecting kEND
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ',', expecting '='
        ...name="pano", html_template_fn,css_filename, js_template_fn)
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ')', expecting '='
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;703; syntax error, unexpected $end, expecting kEND
        file_loaded( __FILE__ )
        Is it compatibile with SU8 anyway? Thanks for your answer.
        • rami_lpmR Offline
          rami_lpm
          I think not, sorry. They changed the ruby version for sketchup 2014. I think it has to do with that. I'll see if I can fix it.
            driven
            hi,
            very interesting...
            I thought maybe you could ask to change perspective...
                  #test perspective, if parallel, ask to change now, or return
                  if !cam.perspective? then
                   result = UI.messagebox('Camera must be perspective, not parallel, change now?', MB_YESNO)
                     if result == IDYES
                       cam.perspective = true
                     else
                      return
            I'll have a closer look if i get a chance...
            • rami_lpmR Offline
              rami_lpm
              I'm not sure. Most panoramas require a carefully placed camera.
              If I switch automatically from a parallel camera, I don't know if the panorama will be useful. Remember that writing the images can take several minutes.
              Thanks for the advice anyway.
                T774AM12RUS
                Hello
                I have an error window on start:
                C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ',', expecting '='
                C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ')', expecting '='
                C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:703: syntax error, unexpected kEND, expecting $end
                end #module pano
                • rami_lpmR Offline
                  rami_lpm
                  Yes, that's because v0.3 didn't support SU8. The newest version(0.31) should work fine.
                  • erikBE Offline
                    erikB
                    srx,
                    would you mind posting a step by step description how you used this plugin and su4thea to create your rendered panos ?
                    erikB
                    • srxS Offline
                      srx
                      @erikb said:
                      srx,
                      erikB
                      Nothing serious...
                      1 Make WEBGL panorama with plugin. It will create images named pano001, pano002 etc in the folder panorama. Check if it works.
                      2 Use "Save current camera scenes" option of the plugin to create SketchUp scenes.
                      3 Render those scenes with SU4Thea(do not use Vigneting) and save each rendered scene over the matching pano001,... from the step 1
                      That's all.
                      www.saurus.rs
                      • erikBE Offline
                        erikB
                        srx,
                        Sorry to bother you again, but what I could not figure out is still unclear. Where is the option to "save current camera scenes" of the plugin ?
                        PS.
                        erikB
                        Win 7 64
                          In SU place the camera where you would like the panorama to be generated from.
                          Create a scene
                          Now under Plugins > Panorama > Save Current Camera Scenes
                          This will generate the cubic scenes from that scene. The scenes name will be prefixed and suffixed with p[scene_name]_# eg Scene 1 will have 6 new scenes added called Scene 1_1, Scene 1_2 etc.....
                          Use these scenes in Thea
                          • erikBE Offline
                            erikB
                            thank you,
                            Just found it myself. Lesson 1: "read" the comments from the maker. I was only working with the icons toolbar and could not understand why I couldn't find it. 😳
                            anyway thanks Rich
                              testing something
                              {edit}killed test{edit}
                              • rami_lpmR Offline
                                rami_lpm
                                Hey. Sorry, I didn't make a button for that because I still haven't found a way to undo it, and so many scenes can disorganize your model very quickly. (you can always delete them manually, but I find it awkward)
                                Rich, that is awesome, I didn't know you could insert stuff like that in phpBB.
                                  driven
                                  @Rich
                                  your test breaks the page in Safari...
                                  I had to disable images to post...
                                    weird, I fail to understand why?
                                      No zoom on the Panorama ?
                                      • rami_lpmR Offline
                                        rami_lpm
                                        I think I can make it zoom. I'm not a java whiz but I'll give it a try.
                                        Edit: ok, it should work now.
                                        • jo-keJ Offline
                                          jo-ke
                                          zoom is possible with the mouse wheel.
                                          very nice plugin. I always wanted to have a pure SU- pano. That's it!
                                          http://www.zz7.de
                                          • W Offline
                                            wehby
                                            Rami,
                                            Nice work on the script. It contains a lot of the features that I had hoped the next version of CubicPanoOut would contain.
                                            Regards,
                                            wehby
                                            • 2 / 4
