    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 467.9k Views 107 Watching
      goga63
      Thank, tak2hata !!!
      Excellent !!!
      but ...now the length of the replaced part is not equal to the length of the deleted...
      https://www.youtube.com/watch?v=CNm6fd-uhIU%26amp;list=UUYHOlAYFzT2R55uH7KDFIaQ
        tak2hata
        @goga63 said:
        Thank, tak2hata !!!
        Excellent !!!
        Hi,goga63.
        Thanks for your testing.
        But I can not make same scene.
        Please send me your tested scene file with mwall files.
        Thanks.
        by TAK2HATA
          tak2hata
          Hi,All.
          It has been a long time. ๐Ÿ˜‰
          I re-updated to version2.0.2a.
          The problem that goga63 told me is fixed.
          But this script is very long.
          So I think there will be any other problems.
          I will check for more time.
          Thanks.
          by TAK2HATA
            goga63
            Yes ! now everything works !!!
            ...but if I find bugs ...
            ...I'll be back ...
            ๐Ÿ˜Ž ๐Ÿ˜Ž ๐Ÿ˜Ž
              goga63
              ... using the new features of the plugin ...
              [flash=425,344:19h84au5]http://www.youtube.com/v/osD9DL--Wu0&hl=en&fs=1&rel=0[/flash:19h84au5]
                bohdeechozo
                Can anyone help me with ese kind of structure? Would beams with measures 100x50x2,5mm. I am not able to produce with the application. Thank you.
                  cadmunkey
                  Havent used this in a while. Can someone remind me how to create a slab. Do I select a face and then apply all, or select outer lines and draw by clicks? Nothing seems to work for me and I must be doing something wrong as all the other items work fine.
                  Edit: figured it out, click face then draw by clicks. Doh!
                    cadmunkey
                    Using the new SHAPE class, does the ALIGN function not work with this? No matter how I draw my shape it draws it with a justification of bottom right. Any workaround?
                      tak2hata
                      Hi,ALL.
                      I update this to v2.1.0 in 2014.11.01.
                      Some Improves.
                      Hi,Cadmunkey.
                      "SHAPE" class not support ALIGN option.
                      I will consider the method for Align of "SHAPE" in future.
                      Thanks.
                      by TAK2HATA
                        cadmunkey
                        @tak2hata said:
                        Hi,ALL.
                        Some Improves.
                        Hi,Cadmunkey.
                        Thanks.
                        OK, thanks for considering it. Such a great plugin I couldn't live without now ๐Ÿ˜‰
                        • facerF Offline
                          facer
                          T2H,
                          Great plugin, keep up the good work!
                          V2.1.0 - Question ??
                          I am using Skp 2014, W7, 32bit
                          1. I note that I can only get the "Draw by click" to work in the SMALL - simple window of
                            the Toggle_UI. I find in the SMALL UI it is hard to read the data due to the small text size.
                            The LARGER UI is easier for me to read. Can this be achieved?
                          2. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                            I can not find my new STEEL BEAM in the data.
                          Thanks again,
                          Ray
                          UB207x134 data input
                            cadmunkey
                            @facer said:
                            1. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                            Thanks again,
                            Ray
                            Did you create that in the table editor? If so it seems to shift newly created elements to the bottom of your lists, not in order of actual section size.
                              tak2hata
                              Hi,all.
                              I update this to v2.2.0. in 2014.11.16.
                              Apply IFC classification in sketchup2015.
                              by TAK2HATA
                                goga63
                                And again great work ! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                Only after carrying over of function of editing of a profile directly in the table, the button "Profile Schema Edit" shows an empty window.
                                Here new Russian translation to a plug-in.
                                lang_ru.txt
                                  cadmunkey
                                  @tak2hata said:
                                  Hi,all.
                                  Genius! Thank you so much for this update ๐Ÿ˜„ ๐Ÿ‘
                                  • OxerO Offline
                                    Oxer
                                    Thanks for the update, the Profile Schema Edit window doesn't open because in the line 545 of main.rb file the path isn't correct:
                                     line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator2.html')
                                    You need fix the path to:
                                     line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator.html')
                                      cadmunkey
                                      Strange, I'm using the new version and didn't have that issue Oxer.
                                        tak2hata
                                        Hi,All.
                                        I update this to v2.2.1. in 2014.11.22.
                                        Some bugs fixed.
                                        and Change the sample profile files to have no extension name.
                                        I found the point that oxer said.
                                        by TAK2HATA
                                        • OxerO Offline
                                          Oxer
                                          Hi tak2hata,
                                          When I push Show tool icon it appears this warning window:
                                          I suppose this is because default_pflist.xml file isn't included with the plugin. When I install the file by myself in the sample_pflist folder and then I select it through Change Profile-List File, on OSX & SU2015 the Shapes and Multiple Wall are empty in Tool Options window:
                                          but in SU2014 the content of these folders appears.
                                            tak2hata
                                            Hi,oxer.
                                            This did not include the default_pflist.xml file in older version,too.
                                            Only "sample_pflist_jis_japan.tsv" and "sample_pflist_northAmerica.tsv" and "sample_pflist_UK_AC.tsv" were included.
                                            Now "sample_pflist_jis_japan" and "sample_pflist_northAmeric" and "sample_pflist_UK_AC" are included.
                                            So I think missing "default_pflist.xml" file is not caused to new version.
                                            About Empty when select "MWall" and "Shapes",
                                            Does the folders exist in your plguin folder?
                                            by TAK2HATA
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
