    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 525.4k Views 108 Watching
      goga63
      ... using the new features of the plugin ...
      [flash=425,344:19h84au5]http://www.youtube.com/v/osD9DL--Wu0&hl=en&fs=1&rel=0[/flash:19h84au5]
        bohdeechozo
        Can anyone help me with ese kind of structure? Would beams with measures 100x50x2,5mm. I am not able to produce with the application. Thank you.
          cadmunkey
          Havent used this in a while. Can someone remind me how to create a slab. Do I select a face and then apply all, or select outer lines and draw by clicks? Nothing seems to work for me and I must be doing something wrong as all the other items work fine.
          Edit: figured it out, click face then draw by clicks. Doh!
            cadmunkey
            Using the new SHAPE class, does the ALIGN function not work with this? No matter how I draw my shape it draws it with a justification of bottom right. Any workaround?
              tak2hata
              Hi,ALL.
              I update this to v2.1.0 in 2014.11.01.
              Some Improves.
              Hi,Cadmunkey.
              "SHAPE" class not support ALIGN option.
              I will consider the method for Align of "SHAPE" in future.
              Thanks.
              by TAK2HATA
                cadmunkey
                @tak2hata said:
                Hi,ALL.
                Some Improves.
                Hi,Cadmunkey.
                Thanks.
                OK, thanks for considering it. Such a great plugin I couldn't live without now 😉
                • facerF Offline
                  facer
                  T2H,
                  Great plugin, keep up the good work!
                  V2.1.0 - Question ??
                  I am using Skp 2014, W7, 32bit
                  1. I note that I can only get the "Draw by click" to work in the SMALL - simple window of
                    the Toggle_UI. I find in the SMALL UI it is hard to read the data due to the small text size.
                    The LARGER UI is easier for me to read. Can this be achieved?
                  2. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                    I can not find my new STEEL BEAM in the data.
                  Thanks again,
                  Ray
                  UB207x134 data input
                    cadmunkey
                    @facer said:
                    1. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                    Thanks again,
                    Ray
                    Did you create that in the table editor? If so it seems to shift newly created elements to the bottom of your lists, not in order of actual section size.
                      tak2hata
                      Hi,all.
                      I update this to v2.2.0. in 2014.11.16.
                      Apply IFC classification in sketchup2015.
                      by TAK2HATA
                        goga63
                        And again great work ! 👍 👍 👍
                        Only after carrying over of function of editing of a profile directly in the table, the button "Profile Schema Edit" shows an empty window.
                        Here new Russian translation to a plug-in.
                        lang_ru.txt
                          cadmunkey
                          @tak2hata said:
                          Hi,all.
                          Genius! Thank you so much for this update 😄 👍
                          • OxerO Offline
                            Oxer
                            Thanks for the update, the Profile Schema Edit window doesn't open because in the line 545 of main.rb file the path isn't correct:
                             line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator2.html')
                            You need fix the path to:
                             line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator.html')
                              cadmunkey
                              Strange, I'm using the new version and didn't have that issue Oxer.
                                tak2hata
                                Hi,All.
                                I update this to v2.2.1. in 2014.11.22.
                                Some bugs fixed.
                                and Change the sample profile files to have no extension name.
                                I found the point that oxer said.
                                by TAK2HATA
                                • OxerO Offline
                                  Oxer
                                  Hi tak2hata,
                                  When I push Show tool icon it appears this warning window:
                                  I suppose this is because default_pflist.xml file isn't included with the plugin. When I install the file by myself in the sample_pflist folder and then I select it through Change Profile-List File, on OSX & SU2015 the Shapes and Multiple Wall are empty in Tool Options window:
                                  but in SU2014 the content of these folders appears.
                                    tak2hata
                                    Hi,oxer.
                                    This did not include the default_pflist.xml file in older version,too.
                                    Only "sample_pflist_jis_japan.tsv" and "sample_pflist_northAmerica.tsv" and "sample_pflist_UK_AC.tsv" were included.
                                    Now "sample_pflist_jis_japan" and "sample_pflist_northAmeric" and "sample_pflist_UK_AC" are included.
                                    So I think missing "default_pflist.xml" file is not caused to new version.
                                    About Empty when select "MWall" and "Shapes",
                                    Does the folders exist in your plguin folder?
                                    by TAK2HATA
                                    • OxerO Offline
                                      Oxer
                                      Yes, the folders exist and they have content:
                                      This happens in SU2015 only, in SU 2014 the content of the folders appear in the Tool Options window correctly.
                                        tak2hata
                                        Hi,all
                                        I update this to V2.2.4 in 2014-12-07.
                                        Some bugfix and Improve the profile selector.and "Mwall" Work well on MacOSX.
                                        Hi,Oxer.
                                        Please try this version.
                                        by TAK2HATA
                                        • chialiang168C Offline
                                          chialiang168
                                          https://dl.dropboxusercontent.com/u/108539326/001-Share/building_structure_tools/languages.JPG
                                          Chinese and Taiwanese language files
                                          中国と台湾の言語ファイル
                                          中国と台湾の言語ファイル
                                          • OxerO Offline
                                            Oxer
                                            I installed the v2.2.4 and all work fine now on OS X 10.10.1 👍
                                            Thanks tak2hata !!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
