    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 518.2k Views 108 Watching
      tak2hata
      @goga63 said:
      Good day !
      Found bug in versions of Sketchup 2013 and Sketchup2014.
      in Sketchup 2014 when you open the "Component Options" message on the error.
      If using the editor Attribute in the Directory "BEAM_SPECS" attribute "PATH" to change the value of " [Point3d(0, 0, 0), Point3d(0, 100, 0)] "
      to Point3d(0, 0, 0), Point3d(0, 100, 0) " , deleting the characters "[" and "]" ,
      the error message does not occur.
      http://ipic.su/img/img7/fs/error.1410935291.jpg
      Hi,goga63.
      I understand the problem.
      I try to fix it.
      Thanks.
      by TAK2HATA
        tak2hata
        Hi,All.
        I update this to Version2.0.1a in 2014.09.28.
        Some new function and Improves and Bugfixs.
        Please watch what's new movie on top of thread.
        by TAK2HATA
        • KrisidiousK Offline
          Krisidious
          nice improvements... That wall tool looks nice. Can it possibly do curved walls? or transform lines into walls?
          By: Kristoff Rand
            goga63
            Thank, tak2hata !!!
            Excellent !!!
            but ...now the length of the replaced part is not equal to the length of the deleted...
            https://www.youtube.com/watch?v=CNm6fd-uhIU%26amp;list=UUYHOlAYFzT2R55uH7KDFIaQ
              tak2hata
              @goga63 said:
              Thank, tak2hata !!!
              Excellent !!!
              Hi,goga63.
              Thanks for your testing.
              But I can not make same scene.
              Please send me your tested scene file with mwall files.
              Thanks.
              by TAK2HATA
                tak2hata
                Hi,All.
                It has been a long time. ๐Ÿ˜‰
                I re-updated to version2.0.2a.
                The problem that goga63 told me is fixed.
                But this script is very long.
                So I think there will be any other problems.
                I will check for more time.
                Thanks.
                by TAK2HATA
                  goga63
                  Yes ! now everything works !!!
                  ...but if I find bugs ...
                  ...I'll be back ...
                  ๐Ÿ˜Ž ๐Ÿ˜Ž ๐Ÿ˜Ž
                    goga63
                    ... using the new features of the plugin ...
                    [flash=425,344:19h84au5]http://www.youtube.com/v/osD9DL--Wu0&hl=en&fs=1&rel=0[/flash:19h84au5]
                      bohdeechozo
                      Can anyone help me with ese kind of structure? Would beams with measures 100x50x2,5mm. I am not able to produce with the application. Thank you.
                        cadmunkey
                        Havent used this in a while. Can someone remind me how to create a slab. Do I select a face and then apply all, or select outer lines and draw by clicks? Nothing seems to work for me and I must be doing something wrong as all the other items work fine.
                        Edit: figured it out, click face then draw by clicks. Doh!
                          cadmunkey
                          Using the new SHAPE class, does the ALIGN function not work with this? No matter how I draw my shape it draws it with a justification of bottom right. Any workaround?
                            tak2hata
                            Hi,ALL.
                            I update this to v2.1.0 in 2014.11.01.
                            Some Improves.
                            Hi,Cadmunkey.
                            "SHAPE" class not support ALIGN option.
                            I will consider the method for Align of "SHAPE" in future.
                            Thanks.
                            by TAK2HATA
                              cadmunkey
                              @tak2hata said:
                              Hi,ALL.
                              Some Improves.
                              Hi,Cadmunkey.
                              Thanks.
                              OK, thanks for considering it. Such a great plugin I couldn't live without now ๐Ÿ˜‰
                              • facerF Offline
                                facer
                                T2H,
                                Great plugin, keep up the good work!
                                V2.1.0 - Question ??
                                I am using Skp 2014, W7, 32bit
                                1. I note that I can only get the "Draw by click" to work in the SMALL - simple window of
                                  the Toggle_UI. I find in the SMALL UI it is hard to read the data due to the small text size.
                                  The LARGER UI is easier for me to read. Can this be achieved?
                                2. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                                  I can not find my new STEEL BEAM in the data.
                                Thanks again,
                                Ray
                                UB207x134 data input
                                  cadmunkey
                                  @facer said:
                                  1. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                                  Thanks again,
                                  Ray
                                  Did you create that in the table editor? If so it seems to shift newly created elements to the bottom of your lists, not in order of actual section size.
                                    tak2hata
                                    Hi,all.
                                    I update this to v2.2.0. in 2014.11.16.
                                    Apply IFC classification in sketchup2015.
                                    by TAK2HATA
                                      goga63
                                      And again great work ! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                      Only after carrying over of function of editing of a profile directly in the table, the button "Profile Schema Edit" shows an empty window.
                                      Here new Russian translation to a plug-in.
                                      lang_ru.txt
                                        cadmunkey
                                        @tak2hata said:
                                        Hi,all.
                                        Genius! Thank you so much for this update ๐Ÿ˜„ ๐Ÿ‘
                                        • OxerO Offline
                                          Oxer
                                          Thanks for the update, the Profile Schema Edit window doesn't open because in the line 545 of main.rb file the path isn't correct:
                                           line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator2.html')
                                          You need fix the path to:
                                           line 548-> htmfile = File.join(File.dirname(__FILE__),'bst_profile_creator.html')
                                            cadmunkey
                                            Strange, I'm using the new version and didn't have that issue Oxer.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
