    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 544.9k Views 108 Watching
    • T
      tak2hata
      I update this to v1.9.7.
      Fix the encoding code problem.
      Hi,JQL.
      I search the Sketchup ruby API,
      but there are no method for approaching to classifier.
      I will wait for future release.
      Thanks.
      by TAK2HATA
      • sumasterS
        sumaster
        Hello Tak2hata Sir,
        NOW Its working . . . . . . . Thanks . . . . . 😍
        Thank you,
        SUmaster
        • G
          goga63
          Good day !
          Found bug in versions of Sketchup 2013 and Sketchup2014.
          in Sketchup 2014 when you open the "Component Options" message on the error.
          If using the editor Attribute in the Directory "BEAM_SPECS" attribute "PATH" to change the value of " [Point3d(0, 0, 0), Point3d(0, 100, 0)] "
          to Point3d(0, 0, 0), Point3d(0, 100, 0) " , deleting the characters "[" and "]" ,
          the error message does not occur.
          http://ipic.su/img/img7/fs/error.1410935291.jpg
          • T
            tak2hata
            @goga63 said:
            Good day !
            Hi,goga63.
            I understand the problem.
            I try to fix it.
            Thanks.
            by TAK2HATA
            • T
              tak2hata
              Hi,All.
              I update this to Version2.0.1a in 2014.09.28.
              Some new function and Improves and Bugfixs.
              Please watch what's new movie on top of thread.
              by TAK2HATA
              • KrisidiousK
                Krisidious
                nice improvements... That wall tool looks nice. Can it possibly do curved walls? or transform lines into walls?
                By: Kristoff Rand
                • G
                  goga63
                  Thank, tak2hata !!!
                  Excellent !!!
                  but ...now the length of the replaced part is not equal to the length of the deleted...
                  https://www.youtube.com/watch?v=CNm6fd-uhIU%26amp;list=UUYHOlAYFzT2R55uH7KDFIaQ
                  • T
                    tak2hata
                    @goga63 said:
                    Thank, tak2hata !!!
                    Excellent !!!
                    Hi,goga63.
                    Thanks for your testing.
                    But I can not make same scene.
                    Please send me your tested scene file with mwall files.
                    Thanks.
                    by TAK2HATA
                    • T
                      tak2hata
                      Hi,All.
                      It has been a long time. 😉
                      I re-updated to version2.0.2a.
                      The problem that goga63 told me is fixed.
                      But this script is very long.
                      So I think there will be any other problems.
                      I will check for more time.
                      Thanks.
                      by TAK2HATA
                      • G
                        goga63
                        Yes ! now everything works !!!
                        ...but if I find bugs ...
                        ...I'll be back ...
                        • G
                          goga63
                          ... using the new features of the plugin ...
                          [flash=425,344:19h84au5]http://www.youtube.com/v/osD9DL--Wu0&hl=en&fs=1&rel=0[/flash:19h84au5]
                          • B
                            bohdeechozo
                            Can anyone help me with ese kind of structure? Would beams with measures 100x50x2,5mm. I am not able to produce with the application. Thank you.
                            • C
                              cadmunkey
                              Havent used this in a while. Can someone remind me how to create a slab. Do I select a face and then apply all, or select outer lines and draw by clicks? Nothing seems to work for me and I must be doing something wrong as all the other items work fine.
                              Edit: figured it out, click face then draw by clicks. Doh!
                              • C
                                cadmunkey
                                Using the new SHAPE class, does the ALIGN function not work with this? No matter how I draw my shape it draws it with a justification of bottom right. Any workaround?
                                • T
                                  tak2hata
                                  Hi,ALL.
                                  I update this to v2.1.0 in 2014.11.01.
                                  Some Improves.
                                  Hi,Cadmunkey.
                                  "SHAPE" class not support ALIGN option.
                                  I will consider the method for Align of "SHAPE" in future.
                                  Thanks.
                                  by TAK2HATA
                                  • C
                                    cadmunkey
                                    @tak2hata said:
                                    Hi,ALL.
                                    Some Improves.
                                    Hi,Cadmunkey.
                                    Thanks.
                                    OK, thanks for considering it. Such a great plugin I couldn't live without now 😉
                                    • facerF
                                      facer
                                      T2H,
                                      Great plugin, keep up the good work!
                                      V2.1.0 - Question ??
                                      I am using Skp 2014, W7, 32bit
                                      1. I note that I can only get the "Draw by click" to work in the SMALL - simple window of
                                        the Toggle_UI. I find in the SMALL UI it is hard to read the data due to the small text size.
                                        The LARGER UI is easier for me to read. Can this be achieved?
                                      2. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                                        I can not find my new STEEL BEAM in the data.
                                      Thanks again,
                                      Ray
                                      UB207x134 data input
                                      • C
                                        cadmunkey
                                        @facer said:
                                        1. Is the new STEEL BEAM (ref attachment) data saved for latter use?
                                        Thanks again,
                                        Ray
                                        Did you create that in the table editor? If so it seems to shift newly created elements to the bottom of your lists, not in order of actual section size.
                                        • T
                                          tak2hata
                                          Hi,all.
                                          I update this to v2.2.0. in 2014.11.16.
                                          Apply IFC classification in sketchup2015.
                                          by TAK2HATA
                                          • G
                                            goga63
                                            And again great work ! 👍 👍 👍
                                            Only after carrying over of function of editing of a profile directly in the table, the button "Profile Schema Edit" shows an empty window.
                                            Here new Russian translation to a plug-in.
                                            lang_ru.txt
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
