    [Plugin Library] LibFredo6 - v15.9d - 09 Jul 26
    2.2k Posts 580 Posters 5.7m Views 582 Watching
    • fredo6F Offline
      Eozel,
      I re-released all my plugins for non-ascii usernames.
      Please upgrade to LibFredo6 6.3 and latest versions of my plugins. I hope it will work for you now.
      • V Offline
        vivo44
        Hello Fredo,
        Je viens d'installer SKP14 ainsi que tous mes plugins via le menu Extensions de SKP (le SCF me dit qu'il ne sait pas unziper..)
        J'ai toujours un message d'erreur au lancement de SKP:
        "Erreur de chargement du fichier Fredo6_!LibFredo6.rb
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
        C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'"
        Qu'est-ce que j'ai fait de mal?? 😞
        Merci pour ton aide! Et bravo pour ton travail!
        • fredo6F Offline
          Il semblerait qu'il reste des vieux fichiers (pas au format UTF8) dans la directory Plugins. Peux tu faire le menage ou montrer la liste des fichiers / directories dans le repertoire Plugins de Sketchup
          • V Offline
            vivo44
            Ok voici la liste, je traine des pluggins depuis 6 ans donc c'est possible...mais je ne comprends pas lesquels!
            • fredo6F Offline
              Just remove
              • LibTraductor.rb (i guess this is the one causing the issue, as it must be old)
              • RDE_dir
              • SUCLOCK_Dir_11
              • ROUNDCORNER_dir_23
              • E Offline
                el_apprentice
                @fred06
                Hi! Good day..
                Where exactly I can download the LibFredo6 - v6.3a in this thread?
                Leiy
                  @el_apprentice said:
                  @fred06
                  Hi! Good day..
                  Leiy
                  Go to the first post on the first page--always a good place to start. It's very clearly spelled out with the link given in the text below the yellow Download image.
                  • V Offline
                    vivo44
                    @fredo6 said:
                    Just remove
                    • RDE_dir
                    • SUCLOCK_Dir_11
                    Great! I work properly now!
                    Thank you very much for your time.
                    A+
                      kristianmorse
                      where's the download link for 6.3?
                      • 5 Offline
                        5ketchupUser55
                        When trying to download, I click download button and then I see just a dark green square with Download button with yellow background, which does nothing.
                        I went all these registration steps to download this plugin, disabled plugins in my browser and what I see?
                        This site designer needs some professional medical help, because behind all of these bells and whistles basic functionality is lost.
                        I do hope You still remember that this site should allow people to share their plugins?
                        • TIGT Online
                          The logical place to get your up to date Plugin RBZs is from the PluginsStore... http://sketchucation.com/pluginstore
                          It is linked in the tools' thread...
                          It has excellent search and filtering capabilities and contains 99% of all Plugins available on SCF...
                            tmt0009
                            Hello,
                            I have LibFredo6 - v6.3a on my mac now. I'm trying to get Curviloft so that I can use it but can' figure out how to actually use the plugin. I install it like I installed the LibFredo app but it won't appear anywhere other than the extensions window and I can't find the toolbar. What am I missing?
                            • N Offline
                              nwarner33
                              Hi there, is there a trick to getting your plugins to work with sketchup 2015? Or has that not happened yet?
                              Thanks for all you do.
                              Nic
                              • fredo6F Offline
                                Nic
                                All my plugins work with SU15
                                Fred
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v6.4a - 17 Nov 14
                                  LibFredo6 6.4a is a release mainly for AngleInspector 1.0, part of FredoTools 2.4a.
                                  It also fixes some bugs and adjustments that have an impact on DrawAlong and MoveAlong. So it is advised to upgrade
                                  See main post of this thread for Download of LibFredo6.
                                  • OxerO Offline
                                    Oxer
                                    New Spanish Language file v6.4a
                                    Spanish Language
                                    • fredo6F Offline
                                      Oxer,
                                      Thanks very much. This will go in next update
                                        mjvanderploeg
                                        Dear all,
                                        got a problem using libfredo6 with fredo tools and round corner. Error message is that libfredo6 is not 6.3 or higher, while the latest 6.4 is installed. See attached files. Can you help?
                                        error message 1
                                        installed libfredo6 version
                                        error message 2
                                        log file
                                        • fredo6F Offline
                                          Actually the message should say "you must install LibFredo6 6.4". So it's not a problem of version.
                                          The issue seems to come from a wrong installation of FredoTools.
                                          Did you install both LibFredo6 and FredoTools in the same directory?
                                          I suggest you have a look at the footprint and possibly cleanup and reinstall FredoTools (ideally from the PluginStore).
                                            mjvanderploeg
                                            Fredo,
                                            Thanks for your quick reply. A few things I forgot to mention. I'm running Sketchup 2013 in LinuxMint 17, using wine.
                                            This is the contents of the Plugin folder:
                                            drwxr-xr-x 3 margriet margriet 4096 nov 24 21:23 Fredo6_FredoTools
                                            -rw-r--r-- 1 margriet margriet 1633 okt 18 00:28 Fredo6_FredoTools.rb
                                            drwxr-xr-x 4 margriet margriet 4096 nov 24 21:23 Fredo6_!LibFredo6
                                            -rw-r--r-- 1 margriet margriet 12896 okt 18 00:17 Fredo6_!LibFredo6.rb
                                            drwxr-xr-x 4 margriet margriet 4096 nov 24 21:24 Fredo6_RoundCorner
                                            -rw-r--r-- 1 margriet margriet 1633 okt 18 15:57 Fredo6_RoundCorner.rb
                                            drwxr-xr-x 4 margriet margriet 4096 nov 22 09:32 su_advancedcameratools
                                            -rw-r--r-- 1 margriet margriet 1715 aug 6 2013 su_advancedcameratools.rb
                                            drwxr-xr-x 8 margriet margriet 4096 nov 22 09:32 su_dynamiccomponents
                                            -rw-r--r-- 1 margriet margriet 1717 aug 6 2013 su_dynamiccomponents.rb
                                            drwxr-xr-x 3 margriet margriet 4096 nov 22 09:33 su_sandbox
                                            -rw-r--r-- 1 margriet margriet 1663 aug 6 2013 su_sandbox.rb
                                            drwxr-xr-x 2 margriet margriet 4096 nov 22 09:33 su_webtextures
                                            -rw-r--r-- 1 margriet margriet 1299 aug 6 2013 su_webtextures.rb
                                            So all plugins are in the same folder.
                                            The Fredotools are indeed the latest version from the plugin store
                                            -rw-r--r-- 1 margriet margriet 305756 nov 24 20:08 FredoTools_v2.4a.rbz
                                            As the sketchucation tools do not work on my machine, I manually downloaded your plugins from the store and installed them via the Window -> preferences -> extensions menu.
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 111
                                            • 112
                                            • 45 / 112
