    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v6.3a - 19 Oct 14
      LibFredo6 6.3a is a release mainly for supporting username with non-ascii characters in SU14.
      If this is your case, you will need also to upgrade all my scripts which I am republishing.
      Note that non-ascii usernames are normally supported since Sketchup 2014, but there were bugs in Ruby 2.0.
      See main post of this thread for Download of LibFredo6.
      • E
        eozel
        @fredo6 said:
        Eozel,
        It seems Ruby 2.0 is a disaster when the path contains non-ascii charcaters and many functions are impacted.
        If you know how to do it, could you edit the file Curviloft.plugin which is in Fredo6_Curviloft subfolder and at the end remove the line "BOOTSTRAP = bootstrap_Curviloft"
        Thanks for your all supports, with removing of the line, Curviloft works fine.
        Fredotoposhape gives error when SU start "You must install Libfredo 6 version 5.2 or higher to run fredo6_toposhaper".
        Also, Have you got any shape plugin which works fine?
        • fredo6F
          Eozel,
          I re-released all my plugins for non-ascii usernames.
          Please upgrade to LibFredo6 6.3 and latest versions of my plugins. I hope it will work for you now.
          • V
            vivo44
            Hello Fredo,
            Je viens d'installer SKP14 ainsi que tous mes plugins via le menu Extensions de SKP (le SCF me dit qu'il ne sait pas unziper..)
            J'ai toujours un message d'erreur au lancement de SKP:
            "Erreur de chargement du fichier Fredo6_!LibFredo6.rb
            Error: #<ArgumentError: invalid byte sequence in UTF-8>
            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'"
            Qu'est-ce que j'ai fait de mal?? 😞
            Merci pour ton aide! Et bravo pour ton travail!
            • fredo6F
              Il semblerait qu'il reste des vieux fichiers (pas au format UTF8) dans la directory Plugins. Peux tu faire le menage ou montrer la liste des fichiers / directories dans le repertoire Plugins de Sketchup
              • V
                vivo44
                Ok voici la liste, je traine des pluggins depuis 6 ans donc c'est possible...mais je ne comprends pas lesquels!
                • fredo6F
                  Just remove
                  • LibTraductor.rb (i guess this is the one causing the issue, as it must be old)
                  • RDE_dir
                  • SUCLOCK_Dir_11
                  • ROUNDCORNER_dir_23
                  • E
                    el_apprentice
                    @fred06
                    Hi! Good day..
                    Where exactly I can download the LibFredo6 - v6.3a in this thread?
                    Leiy
                      @el_apprentice said:
                      @fred06
                      Hi! Good day..
                      Leiy
                      Go to the first post on the first page--always a good place to start. It's very clearly spelled out with the link given in the text below the yellow Download image.
                      • V
                        vivo44
                        @fredo6 said:
                        Just remove
                        • RDE_dir
                        • SUCLOCK_Dir_11
                        Great! I work properly now!
                        Thank you very much for your time.
                        A+
                        • K
                          kristianmorse
                          where's the download link for 6.3?
                            5ketchupUser55
                            When trying to download, I click download button and then I see just a dark green square with Download button with yellow background, which does nothing.
                            I went all these registration steps to download this plugin, disabled plugins in my browser and what I see?
                            This site designer needs some professional medical help, because behind all of these bells and whistles basic functionality is lost.
                            I do hope You still remember that this site should allow people to share their plugins?
                              The logical place to get your up to date Plugin RBZs is from the PluginsStore... http://sketchucation.com/pluginstore
                              It is linked in the tools' thread...
                              It has excellent search and filtering capabilities and contains 99% of all Plugins available on SCF...
                              • T
                                tmt0009
                                Hello,
                                I have LibFredo6 - v6.3a on my mac now. I'm trying to get Curviloft so that I can use it but can' figure out how to actually use the plugin. I install it like I installed the LibFredo app but it won't appear anywhere other than the extensions window and I can't find the toolbar. What am I missing?
                                • N
                                  nwarner33
                                  Hi there, is there a trick to getting your plugins to work with sketchup 2015? Or has that not happened yet?
                                  Thanks for all you do.
                                  Nic
                                  • fredo6F
                                    Nic
                                    All my plugins work with SU15
                                    Fred
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v6.4a - 17 Nov 14
                                      LibFredo6 6.4a is a release mainly for AngleInspector 1.0, part of FredoTools 2.4a.
                                      It also fixes some bugs and adjustments that have an impact on DrawAlong and MoveAlong. So it is advised to upgrade
                                      • OxerO
                                        Oxer
                                        New Spanish Language file v6.4a
                                        Spanish Language
                                        • fredo6F
                                          Oxer,
                                          Thanks very much. This will go in next update
                                            mjvanderploeg
                                            Dear all,
                                            got a problem using libfredo6 with fredo tools and round corner. Error message is that libfredo6 is not 6.3 or higher, while the latest 6.4 is installed. See attached files. Can you help?
                                            error message 1
                                            installed libfredo6 version
                                            error message 2
                                            log file
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 113
                                            • 114
                                            • 44 / 114
