    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • E
      eozel
      @fredo6 said:
      Eozel,
      Thanks very much. We are progressing
      1. for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
      2. For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
        [attachment=2:36qnwv6n]<!-- ia2 -->Fredo6_RoundCorner.rb<!-- ia2 -->[/attachment:36qnwv6n][attachment=1:36qnwv6n]<!-- ia1 -->Fredo6_Curviloft.rb<!-- ia1 -->[/attachment:36qnwv6n]
      3. For Curviloft, there may be an additional problem.
      Anyway, once this is solved, I will republish the scripts.
      Thanks again
      Curviloft gives following error after i replaced the Fredo6_Curviloft.rb. Round cornet works with no problem.
      • fredo6F
        Eozel,
        Thanks.
        For Curviloft, It may be due to a problem of installation in the Fredo6_Curviloft subfolder. Can you check that you have the following footprint.
        Also, can you check the Trace Log as it should indicate an error on loading the bootstrap_Curviloft.rb file
        • E
          eozel
          @fredo6 said:
          Eozel,
          Thanks.
          [attachment=1:1fbh2u6z]<!-- ia1 -->Curviloft 1.png<!-- ia1 -->[/attachment:1fbh2u6z]
          1413537183.466945;Fredo6_!LibFredo6.rb:71: in `log'
          DATE / TIME: 2014-10-17 12:13:03 +0300
          SKETCHUP VERSION: 14.1.1282
          RUBY_PLATFORM: i386-mingw32
          LOG FILE: LibFredo6Trace_14_1413537183465.txt
          1413537183.465944;Fredo6_!LibFredo6.rb:113: in `startup'
          LibFredo6: Starting up Fredo6_!LibFredo6.rb
          1413537183.5357492;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
          Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
          1413537183.5638778;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
          Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
          1413537183.589764;Fredo6_!LibFredo6.rb:173: in `startup'
          LibFredo6: Beginning of loading Cycle***+
          1413537183.646673;Fredo6_!LibFredo6.rb:180: in `startup'
          LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
          1413537183.840369;Lib6Core.rb:992: in `load_full_rubies'
          LibFredo6 6.2a: Ruby files loaded [96 ms]
          1413537183.888124;Lib6Core.rb:921: in `effective_load_part2'
          LibFredo6 6.2a: Startup (creating menus and icons) [24 ms]
          1413537184.057875;Lib6Core.rb:992: in `load_full_rubies'
          Curviloft 1.3a: Ruby files loaded [71 ms]
          1413537184.080328;Lib6Core.rb:913: in rescue in block in effective_load_part2' ?Curviloft 1.3a: Error starting up plugin (creating menus and icons) undefined method startup' for F6_Curviloft:Module [in Lib6Core.rb - #`block in effective_load_part2(): line 909]
          1413537185.629963;Lib6Core.rb:992: in `load_full_rubies'
          FredoTools 2.1a: Ruby files loaded [33 ms]
          1413537185.659319;Lib6Plugin.rb:150: in `load_body'
          Lib6Material.rb: Loading body code from body_Lib6Material.rb [3 ms]
          1413537185.7227268;Lib6Core.rb:921: in `effective_load_part2'
          FredoTools 2.1a: Startup (creating menus and icons) [67 ms]
          1413537185.820959;Lib6Core.rb:963: in `load_bootstrap_rubies'
          RoundCorner 2.6a: Bootstrap Ruby files loaded [3 ms]
          1413537185.8898308;Lib6Core.rb:921: in `effective_load_part2'
          RoundCorner 2.6a: Startup (creating menus and icons) [42 ms]
          1413537185.916391;Fredo6_!LibFredo6.rb:189: in `startup'
          LibFredo6: End of loading Cycle***-
          1413537200.377671;Lib6Plugin.rb:150: in `load_body'
          Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [28 ms]
          1413537200.46688;Lib6Core.rb:85: in `use_single_library'
          Lib6G6.rb: Loading body code from body_Lib6G6.rb [68 ms]
          1413537200.5250602;Lib6Core.rb:85: in `use_single_library'
          Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [34 ms]
          1413537200.5839438;Lib6Core.rb:85: in `use_single_library'
          Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [35 ms]
          1413537200.637125;Lib6Core.rb:85: in `use_single_library'
          Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
          1413537200.757068;Lib6Core.rb:85: in `use_single_library'
          Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [100 ms]
          1413537200.841938;Lib6Core.rb:85: in `use_single_library'
          Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [60 ms]
          1413537200.901935;Lib6Core.rb:85: in `use_single_library'
          Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [36 ms]
          1413537200.941764;Lib6Core.rb:85: in `use_single_library'
          Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [18 ms]
          1413537201.013798;Lib6Core.rb:85: in `use_single_library'
          Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [48 ms]
          1413537201.0753632;Lib6Core.rb:85: in `use_single_library'
          Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [34 ms]
          1413537201.117089;Lib6Plugin.rb:150: in `load_body'
          Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [19 ms]
          1413537201.184042;Lib6Plugin.rb:150: in `load_body'
          Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [43 ms]
          1413537201.233104;Lib6Plugin.rb:150: in `load_body'
          Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [20 ms]
          • fredo6F
            Eozel,
            It seems Ruby 2.0 is a disaster when the path contains non-ascii charcaters and many functions are impacted.
            If you know how to do it, could you edit the file Curviloft.plugin which is in Fredo6_Curviloft subfolder and at the end remove the line "BOOTSTRAP = bootstrap_Curviloft"
            • fredo6F
              NEW RELEASE: LibFredo6 v6.3a - 19 Oct 14
              LibFredo6 6.3a is a release mainly for supporting username with non-ascii characters in SU14.
              If this is your case, you will need also to upgrade all my scripts which I am republishing.
              Note that non-ascii usernames are normally supported since Sketchup 2014, but there were bugs in Ruby 2.0.
              See main post of this thread for Download of LibFredo6.
              • E
                eozel
                @fredo6 said:
                Eozel,
                Thanks for your all supports, with removing of the line, Curviloft works fine.
                Fredotoposhape gives error when SU start "You must install Libfredo 6 version 5.2 or higher to run fredo6_toposhaper".
                Also, Have you got any shape plugin which works fine?
                • fredo6F
                  Eozel,
                  I re-released all my plugins for non-ascii usernames.
                  Please upgrade to LibFredo6 6.3 and latest versions of my plugins. I hope it will work for you now.
                  • V
                    vivo44
                    Hello Fredo,
                    Je viens d'installer SKP14 ainsi que tous mes plugins via le menu Extensions de SKP (le SCF me dit qu'il ne sait pas unziper..)
                    J'ai toujours un message d'erreur au lancement de SKP:
                    "Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                    Error: #<ArgumentError: invalid byte sequence in UTF-8>
                    C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                    C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                    C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                    C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
                    C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                    C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
                    C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'"
                    Qu'est-ce que j'ai fait de mal?? 😞
                    Merci pour ton aide! Et bravo pour ton travail!
                    • fredo6F
                      Il semblerait qu'il reste des vieux fichiers (pas au format UTF8) dans la directory Plugins. Peux tu faire le menage ou montrer la liste des fichiers / directories dans le repertoire Plugins de Sketchup
                      • V
                        vivo44
                        Ok voici la liste, je traine des pluggins depuis 6 ans donc c'est possible...mais je ne comprends pas lesquels!
                        • fredo6F
                          Just remove
                          • LibTraductor.rb (i guess this is the one causing the issue, as it must be old)
                          • RDE_dir
                          • SUCLOCK_Dir_11
                          • ROUNDCORNER_dir_23
                          • E
                            el_apprentice
                            @fred06
                            Hi! Good day..
                            Where exactly I can download the LibFredo6 - v6.3a in this thread?
                            Leiy
                              @el_apprentice said:
                              @fred06
                              Hi! Good day..
                              Leiy
                              Go to the first post on the first page--always a good place to start. It's very clearly spelled out with the link given in the text below the yellow Download image.
                              • V
                                vivo44
                                @fredo6 said:
                                Just remove
                                • RDE_dir
                                • SUCLOCK_Dir_11
                                Great! I work properly now!
                                Thank you very much for your time.
                                A+
                                • K
                                  kristianmorse
                                  where's the download link for 6.3?
                                    5ketchupUser55
                                    When trying to download, I click download button and then I see just a dark green square with Download button with yellow background, which does nothing.
                                    I went all these registration steps to download this plugin, disabled plugins in my browser and what I see?
                                    This site designer needs some professional medical help, because behind all of these bells and whistles basic functionality is lost.
                                    I do hope You still remember that this site should allow people to share their plugins?
                                      The logical place to get your up to date Plugin RBZs is from the PluginsStore... http://sketchucation.com/pluginstore
                                      It is linked in the tools' thread...
                                      It has excellent search and filtering capabilities and contains 99% of all Plugins available on SCF...
                                      • T
                                        tmt0009
                                        Hello,
                                        I have LibFredo6 - v6.3a on my mac now. I'm trying to get Curviloft so that I can use it but can' figure out how to actually use the plugin. I install it like I installed the LibFredo app but it won't appear anywhere other than the extensions window and I can't find the toolbar. What am I missing?
                                        • N
                                          nwarner33
                                          Hi there, is there a trick to getting your plugins to work with sketchup 2015? Or has that not happened yet?
                                          Thanks for all you do.
                                          Nic
                                          • fredo6F
                                            Nic
                                            All my plugins work with SU15
                                            Fred
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 115
                                            • 116
                                            • 44 / 116
