    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 578 Posters 4.6m Views 580 Watching
    • 5 Offline
      5ketchupUser55
      When trying to download, I click download button and then I see just a dark green square with Download button with yellow background, which does nothing.
      I went all these registration steps to download this plugin, disabled plugins in my browser and what I see?
      This site designer needs some professional medical help, because behind all of these bells and whistles basic functionality is lost.
      I do hope You still remember that this site should allow people to share their plugins?
        The logical place to get your up to date Plugin RBZs is from the PluginsStore... http://sketchucation.com/pluginstore
        It is linked in the tools' thread...
        It has excellent search and filtering capabilities and contains 99% of all Plugins available on SCF...
          tmt0009
          Hello,
          I have LibFredo6 - v6.3a on my mac now. I'm trying to get Curviloft so that I can use it but can' figure out how to actually use the plugin. I install it like I installed the LibFredo app but it won't appear anywhere other than the extensions window and I can't find the toolbar. What am I missing?
          • N Offline
            nwarner33
            Hi there, is there a trick to getting your plugins to work with sketchup 2015? Or has that not happened yet?
            Thanks for all you do.
            Nic
            • fredo6F Offline
              Nic
              All my plugins work with SU15
              Fred
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v6.4a - 17 Nov 14
                LibFredo6 6.4a is a release mainly for AngleInspector 1.0, part of FredoTools 2.4a.
                It also fixes some bugs and adjustments that have an impact on DrawAlong and MoveAlong. So it is advised to upgrade
                See main post of this thread for Download of LibFredo6.
                • OxerO Offline
                  Oxer
                  New Spanish Language file v6.4a
                  Spanish Language
                  • fredo6F Offline
                    Oxer,
                    Thanks very much. This will go in next update
                      mjvanderploeg
                      Dear all,
                      got a problem using libfredo6 with fredo tools and round corner. Error message is that libfredo6 is not 6.3 or higher, while the latest 6.4 is installed. See attached files. Can you help?
                      error message 1
                      installed libfredo6 version
                      error message 2
                      log file
                      • fredo6F Offline
                        Actually the message should say "you must install LibFredo6 6.4". So it's not a problem of version.
                        The issue seems to come from a wrong installation of FredoTools.
                        Did you install both LibFredo6 and FredoTools in the same directory?
                        I suggest you have a look at the footprint and possibly cleanup and reinstall FredoTools (ideally from the PluginStore).
                          mjvanderploeg
                          Fredo,
                          Thanks for your quick reply. A few things I forgot to mention. I'm running Sketchup 2013 in LinuxMint 17, using wine.
                          This is the contents of the Plugin folder:
                          drwxr-xr-x 3 margriet margriet 4096 nov 24 21:23 Fredo6_FredoTools
                          -rw-r--r-- 1 margriet margriet 1633 okt 18 00:28 Fredo6_FredoTools.rb
                          drwxr-xr-x 4 margriet margriet 4096 nov 24 21:23 Fredo6_!LibFredo6
                          -rw-r--r-- 1 margriet margriet 12896 okt 18 00:17 Fredo6_!LibFredo6.rb
                          drwxr-xr-x 4 margriet margriet 4096 nov 24 21:24 Fredo6_RoundCorner
                          -rw-r--r-- 1 margriet margriet 1633 okt 18 15:57 Fredo6_RoundCorner.rb
                          drwxr-xr-x 4 margriet margriet 4096 nov 22 09:32 su_advancedcameratools
                          -rw-r--r-- 1 margriet margriet 1715 aug 6 2013 su_advancedcameratools.rb
                          drwxr-xr-x 8 margriet margriet 4096 nov 22 09:32 su_dynamiccomponents
                          -rw-r--r-- 1 margriet margriet 1717 aug 6 2013 su_dynamiccomponents.rb
                          drwxr-xr-x 3 margriet margriet 4096 nov 22 09:33 su_sandbox
                          -rw-r--r-- 1 margriet margriet 1663 aug 6 2013 su_sandbox.rb
                          drwxr-xr-x 2 margriet margriet 4096 nov 22 09:33 su_webtextures
                          -rw-r--r-- 1 margriet margriet 1299 aug 6 2013 su_webtextures.rb
                          So all plugins are in the same folder.
                          The Fredotools are indeed the latest version from the plugin store
                          -rw-r--r-- 1 margriet margriet 305756 nov 24 20:08 FredoTools_v2.4a.rbz
                          As the sketchucation tools do not work on my machine, I manually downloaded your plugins from the store and installed them via the Window -> preferences -> extensions menu.
                          • fredo6F Offline
                            I think this may be due to Linux, where the ! charcater is actually not the considered going before alphanumeric characters. This means that FredoTools seems to be loaded before LibFredo6.
                            The only thing I see would be to simply remove the file Fredo6_FredoTools.rb(which is actually not useful). LibFredo6 will load it.
                            • Spirou4DS Offline
                              Spirou4D
                              No my dear, your last release isn't 6.4a!!!! There are a mistake.
                              Take alook on your lib, please.
                              • BoxB Offline
                                Looks it to me.
                                  Justusson
                                  does anyone know why I'm getting dotted lines, when drawing with TOS, and not filled lines?
                                  (Both with arch, rectangle sometimes and so forth,..)
                                  These dotted lines, much like hidden lines don't affect the surface at all. They need to be filled in afterwards manually. They apply themselves to the curved surfaces, but don't do anything more than that.
                                  Hope anyone can help me,
                                  Best regards/
                                    It sounds to me as if you have it set to draw construction lines instead of edges. You ought to spend some time looking at the info here. Especially look at the Quickcard PDF file available in the first post of the thread.
                                      Justusson
                                      Excellent, thanks Dave R, just was I was looking for. Hadn't seen the Construction lines/ Plain Lines.
                                      Best /
                                      Christoffer
                                        sahli85
                                        libfredo6 don't work ๐Ÿ˜ข
                                          Please check for proper installation...
                                          BUT...
                                          I'm not sure if this is relevant...
                                          When SketchUp v2014 came in it should have fixed the issues with Windows users having accented characters in their user names.
                                          Unfortunately, it was found that sometimes it still failed in some circumstances...
                                          One issue was with a single-quote ['] in user names ! [like "B'Boss"]...
                                          BUT I thought this had been addressed in later versions...
                                          Also some "FILE" values etc fail if the result is not forced into UTF-8 encoding in the script itself - this is system dependent...
                                          Any SUp guys care to comment ?
                                          thomthom ??
                                          • fredo6F Offline
                                            The prolem comes from the quote in the username, which clashes with string parsing.
                                            So not a non-ascii problem, but even worse, as I never thought quotes where allowed in usernames.
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 111
                                            • 112
                                            • 45 / 112
