    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 22.6k Views 18 Watching
    • cottyC Offline
      cotty
      @srx said:
      If only you could add option for making 6 SU scenes based on the output pano01, pano02...so we can render them and replace SU output.
      Like this one?
      http://www.smustard.com/script/CubicPanoOut
      or this?
      http://sketchucation.com/pluginstore?pln=RND_PanoScene_v1.0.0
      my SketchUp gallery
      • srxS Offline
        srx
        @cotty said:
        Like this one?
        or this?
        O know, I know, but...
        1. This plugin has webGL output!
        2. I don't know if the others would match.
        3. All in one pack is the best.
        www.saurus.rs
        • srxS Offline
          srx
          I tried to create scenes with CubicPanoOut plugin, renamed and replaced images in html folder, and they don't match. Would be great to have this option. The easy way of making rendered WEB panoramas. πŸ˜„
          www.saurus.rs
          • cottyC Offline
            cotty
            This should work (did you turn on shadows?), I've tried this workflow long time ago with Indigo: http://www.indigorenderer.com/forum/viewtopic.php?f=19%26amp;t=10942
            my SketchUp gallery
            • rami_lpmR Offline
              rami_lpm
              I added the menu entry. It saves the scenes and shows in the console each scene's filename.
              I haven't found a way to allow undoing, so be careful.
              • rami_lpmR Offline
                rami_lpm
                Adding the option to make the scenes shouldn't be such a problem. I'll get on it.
                I wasn't aware of Renderiza PanoScene.
                It's strange that the output from cubicpanoout doesn't work with my html. Its basically the same concept and output.
                (edit: on second thought no, it is not. I had to change the scenes order and rotation to make work easier with WebGL )
                • srxS Offline
                  srx
                  It works! I checked with Thea render. All I had to do was to adjust the resolution to 2048x2048. Making WEB panorama in a few minutes (+ rendering time). Thank you for making this possible. 😍
                  www.saurus.rs
                  • rami_lpmR Offline
                    rami_lpm
                    Good. I'll get a renderer and take a look.
                    • srxS Offline
                      srx
                      Here is my try.
                      6 preview images rendered in Thea4SU, Presto engine, 1 minute each, 6 minutes all.
                      All in all from model to web panorama in 10 minutes!
                      I made a mistake of adding vignetting which is seen in panorama...Other then that very good result.
                      404 Not Found
                      (www.saurus.rs)
                      Thanks again. πŸ‘
                      www.saurus.rs
                        gashtan
                        I have som problem with this plugin...need I install Three.js too? If I install plugin, ruby window write me an error
                        Error Loading File RamTools_Panorama.rb
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; odd number list for Hash
                        						@options = { title; "RamTools Panorama Output", r...
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '}'
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ',', expecting kEND
                        ...e; "RamTools Panorama Output", renderer; "Canvas", askFolder...
                        ...a Output", renderer; "Canvas", askFolder; "No", fov; "55", p...
                        ...er; "Canvas", askFolder; "No", fov; "55", path; "Ask", compV...
                        ...", askFolder; "No", fov; "55", path; "Ask", compVal; "0.6", ...
                        ... "No", fov; "55", path; "Ask", compVal; "0.6", isDebug; fals...
                        ..., path; "Ask", compVal; "0.6", isDebug; false, tTag; true, i...
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to false
                        ...ompVal; "0.6", isDebug; false, tTag; true, imgRes; "2048", o...
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting '='
                        ...; "0.6", isDebug; false, tTag; true, imgRes; "2048", ownTemp...
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; Can't assign to true
                        ...", isDebug; false, tTag; true, imgRes; "2048", ownTemplate; ...
                        ...ug; false, tTag; true, imgRes; "2048", ownTemplate; false, i...
                        ...e, tTag; true, imgRes; "2048", ownTemplate; false, invContro...
                        ...s; "2048", ownTemplate; false, invControls; "No", fnHtml; "t...
                        ...nTemplate; false, invControls; "No", fnHtml; "template2.html...
                        ...ate; false, invControls; "No", fnHtml; "template2.html", fnC...
                        ...No", fnHtml; "template2.html", fnCss;"template2.css", fnJs; ...
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected ';', expecting kEND
                        ..., fnCss;"template2.css", fnJs; "template2.js" }
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;137; syntax error, unexpected '}', expecting kEND
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ',', expecting '='
                        ...name="pano", html_template_fn,css_filename, js_template_fn)
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;423; syntax error, unexpected ')', expecting '='
                        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb;703; syntax error, unexpected $end, expecting kEND
                        file_loaded( __FILE__ )
                        Is it compatibile with SU8 anyway? Thanks for your answer.
                        • rami_lpmR Offline
                          rami_lpm
                          I think not, sorry. They changed the ruby version for sketchup 2014. I think it has to do with that. I'll see if I can fix it.
                            driven
                            hi,
                            very interesting...
                            I thought maybe you could ask to change perspective...
                                  #test perspective, if parallel, ask to change now, or return
                                  if !cam.perspective? then
                                   result = UI.messagebox('Camera must be perspective, not parallel, change now?', MB_YESNO)
                                     if result == IDYES
                                       cam.perspective = true
                                     else
                                      return
                            I'll have a closer look if i get a chance...
                            • rami_lpmR Offline
                              rami_lpm
                              I'm not sure. Most panoramas require a carefully placed camera.
                              If I switch automatically from a parallel camera, I don't know if the panorama will be useful. Remember that writing the images can take several minutes.
                              Thanks for the advice anyway.
                                T774AM12RUS
                                Hello
                                I have an error window on start:
                                C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ',', expecting '='
                                C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:424: syntax error, unexpected ')', expecting '='
                                C:/Program Files/Google/Google SketchUp 8/Plugins/RamTools_Panorama.rb:703: syntax error, unexpected kEND, expecting $end
                                end #module pano
                                • rami_lpmR Offline
                                  rami_lpm
                                  Yes, that's because v0.3 didn't support SU8. The newest version(0.31) should work fine.
                                  • erikBE Offline
                                    erikB
                                    srx,
                                    would you mind posting a step by step description how you used this plugin and su4thea to create your rendered panos ?
                                    erikB
                                    • srxS Offline
                                      srx
                                      @erikb said:
                                      srx,
                                      erikB
                                      Nothing serious...
                                      1 Make WEBGL panorama with plugin. It will create images named pano001, pano002 etc in the folder panorama. Check if it works.
                                      2 Use "Save current camera scenes" option of the plugin to create SketchUp scenes.
                                      3 Render those scenes with SU4Thea(do not use Vigneting) and save each rendered scene over the matching pano001,... from the step 1
                                      That's all.
                                      www.saurus.rs
                                      • erikBE Offline
                                        erikB
                                        srx,
                                        Sorry to bother you again, but what I could not figure out is still unclear. Where is the option to "save current camera scenes" of the plugin ?
                                        PS.
                                        erikB
                                        Win 7 64
                                          In SU place the camera where you would like the panorama to be generated from.
                                          Create a scene
                                          Now under Plugins > Panorama > Save Current Camera Scenes
                                          This will generate the cubic scenes from that scene. The scenes name will be prefixed and suffixed with p[scene_name]_# eg Scene 1 will have 6 new scenes added called Scene 1_1, Scene 1_2 etc.....
                                          Use these scenes in Thea
                                          • erikBE Offline
                                            erikB
                                            thank you,
                                            Just found it myself. Lesson 1: "read" the comments from the maker. I was only working with the icons toolbar and could not understand why I couldn't find it. 😳
                                            anyway thanks Rich
                                            • 1 / 4
