    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 311.4k Views 89 Watching
      keithswd
      Thanks Oxer. I have just tried putting the file & folder as you suggest but still get the error. I have double checked that there is no longer a copy in either user Application Support../Sketchup subfolders, or in the system support folder, but up pops the error when I start up.
      The error has changed to the updated path for the script, so maybe something else is wrong:
      Error: #<SyntaxError: /applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:511: Invalid break
      /applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:520: Invalid break>
      Error Loading File compoSprayToolbar.rb
      Error: #<NoMethodError: undefined method compSpray_env' for main:Object> /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/compoSprayToolbar.rb:7:in <top (required)>'
      • soloS Offline
        So, any solution? I tried downloading it with the SCF plugin store but that did not work well, in fact it installs but nothing, no tool bar not in plugin menu, anyone?
        • OxerO Offline
          Oxer
          KeithSWD and Solo, try with this version updated by MTriple, it works fine for me on Mac OS X & SU2014, remember the path on OS X:
          CompoSpray
            keithswd
            Many thanks Oxer (and MTriple) this version is working for me too!
            Glad to have this very useful tool back in operation.
              ruriglen
              The file MTriple uploaded to dropbox is offline, does anyone else has it, that kindly could uploaded again for sharing? Thanks!
                penumbra
                I give up on this plugin. Does not work on 2013 even the Mtriple fix. It won't accept a second point on the shapes (circle, square you name it). The developer has gone MIA...
                • BoxB Offline
                  It does work on 2013 and 2014 with some tweaks.
                  Make sure you have the properties set to what you need and remember it needs a surface to spray on.
                  As for the developer being MIA, Didier has never said he supports this free plugin in perpetuity.
                  • chonC Offline
                    chon
                    Hello,
                    no match for me with CS modified and given by Oxer few posts above. I've tried to install the plugin in "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools" (even then we should'nt use this folder as explained by TIG) and in "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins" but no success.
                    Cherry on the cake, i would like to install this plugin in an additional plugin folder using the Fredo6 tool (doesn't work in this folder neither of course).
                    Any one to help me ?
                    Thanks a lot !! πŸ˜‰
                    • nghminh81N Offline
                      nghminh81
                      Thanks so much Oxer and MTriple. Your file works perfectly with my sketchup 2014!
                      To anyone who using Windows and still can't install it: Please extract files(ComposprayToolbar.rb and 1 folder Compospray) to "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools".
                      DON'T EXTRACT FILES TO "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
                      AND IF THEY WERE THERE (Because you tried to install it) Just DELETE.
                      • V Offline
                        valerostudio
                        Agreed. This works in 2014! Thanks!!!
                        • faBcnF Offline
                          faBcn
                          Hi there,
                          I do not see any window when clicking on Draw / Compo spray (SU 2013)...
                          Any idea ?
                          Thanx
                          • faBcnF Offline
                            faBcn
                            How I manage to make it work on SU 2013, here in Spain (with bloody accents everywhere...)
                            1- Copy/Paste CompoSpray folder + .rb in Plugins file as usual
                            2- Remove all .lingvo but CompoSprayUS.lingvo
                            and it works perfectly ! Nada mΓ‘s....
                            • chonC Offline
                              chon
                              Not for me in France ! 😞
                              Still not working with my config...
                              • V Offline
                                valerostudio
                                Broken again in 2015!!!
                                • soloS Offline
                                  Confirmed
                                    Didier has agreed to allow me to update some of his Plugins that are in in the PluginStore.
                                    I have already done of few of the easier ones... πŸ˜•
                                    I'll try and have a look at this one sometime this year !
                                      I have now updated 'Compo Spray' for Didier - it is now v2014/2015 compatible, and also works from any custom Plugins folder.
                                      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
                                      If you have messed on installing it in Tools etc please remove it manually and get/install the latest version...
                                      • OxerO Offline
                                        Oxer
                                        Thanks TIG, tested in SU2014 & SU2015 on Mac OSX 10.9.5 and the plugin works fine. πŸ‘
                                          Pherim
                                          Thanks for the update!
                                          • CadFatherC Offline
                                            CadFather
                                            Didier, they're coming in faster than i can download them!
                                            Thanks! πŸ‘ πŸ˜„
                                            • 13
                                            • 14
                                            • 7 / 14
