[Plugin Library] LibFredo6 - v15.4a - 13 May 25
2.1k Posts 566 Posters 2.8m Views 568 Watching
  • F Offline
    Thanks.
    Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
    • E Offline
      eozel
      @fredo6 said:
      Thanks.
      • F Offline
        Eozel,
        I think I found the problem.
        To be sure, could you copy the attached file into the Fredo6!_LibFredo6 subfolder and restart SU
        Lib6Core.rb
        Thanks in advance
        • E Offline
          eozel
          @fredo6 said:
          Eozel,
          [attachment=2:3s9bb5jv]<!-- ia2 -->Lib6Core.rb<!-- ia2 -->[/attachment:3s9bb5jv]
          Thanks in advance
          Fredotools now can ben seen in tools menu:)).
          After than i install roundcorner it is working too but when opening the SU it give error below.
          Then i install Su draw parametric shape 2.27 but it gives error too which is given below. Error Loading File C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb
          Error: cannot load such file -- C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
          C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb:8:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in register_extension'
          C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in <module:Shapes>' C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:12:in module:JWM'
          C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:11:in `<top (required)>'
          Curviloft gives errors too.
          • F Offline
            Eozel,
            Thanks very much. We are progressing
            1. for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
            2. For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
              Fredo6_RoundCorner.rbFredo6_Curviloft.rb
            3. For Curviloft, there may be an additional problem.
            Anyway, once this is solved, I will republish the scripts.
            Thanks again
            • E Offline
              eozel
              @fredo6 said:
              Eozel,
                [attachment=2:36qnwv6n]<!-- ia2 -->Fredo6_RoundCorner.rb<!-- ia2 -->[/attachment:36qnwv6n][attachment=1:36qnwv6n]<!-- ia1 -->Fredo6_Curviloft.rb<!-- ia1 -->[/attachment:36qnwv6n]
              Thanks again
              Curviloft gives following error after i replaced the Fredo6_Curviloft.rb. Round cornet works with no problem.
              • F Offline
                Eozel,
                Thanks.
                For Curviloft, It may be due to a problem of installation in the Fredo6_Curviloft subfolder. Can you check that you have the following footprint.
                Also, can you check the Trace Log as it should indicate an error on loading the bootstrap_Curviloft.rb file
                • E Offline
                  eozel
                  @fredo6 said:
                  Eozel,
                  Thanks.
                  [attachment=1:1fbh2u6z]<!-- ia1 -->Curviloft 1.png<!-- ia1 -->[/attachment:1fbh2u6z]
                  1413537183.466945;Fredo6_!LibFredo6.rb:71: in `log'
                  DATE / TIME: 2014-10-17 12:13:03 +0300
                  SKETCHUP VERSION: 14.1.1282
                  RUBY_PLATFORM: i386-mingw32
                  LOG FILE: LibFredo6Trace_14_1413537183465.txt
                  1413537183.465944;Fredo6_!LibFredo6.rb:113: in `startup'
                  LibFredo6: Starting up Fredo6_!LibFredo6.rb
                  1413537183.5357492;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                  Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
                  1413537183.5638778;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                  Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
                  1413537183.589764;Fredo6_!LibFredo6.rb:173: in `startup'
                  LibFredo6: Beginning of loading Cycle***+
                  1413537183.646673;Fredo6_!LibFredo6.rb:180: in `startup'
                  LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
                  1413537183.840369;Lib6Core.rb:992: in `load_full_rubies'
                  LibFredo6 6.2a: Ruby files loaded [96 ms]
                  1413537183.888124;Lib6Core.rb:921: in `effective_load_part2'
                  LibFredo6 6.2a: Startup (creating menus and icons) [24 ms]
                  1413537184.057875;Lib6Core.rb:992: in `load_full_rubies'
                  Curviloft 1.3a: Ruby files loaded [71 ms]
                  1413537184.080328;Lib6Core.rb:913: in rescue in block in effective_load_part2' ?Curviloft 1.3a: Error starting up plugin (creating menus and icons) undefined method startup' for F6_Curviloft:Module [in Lib6Core.rb - #`block in effective_load_part2(): line 909]
                  1413537185.629963;Lib6Core.rb:992: in `load_full_rubies'
                  FredoTools 2.1a: Ruby files loaded [33 ms]
                  1413537185.659319;Lib6Plugin.rb:150: in `load_body'
                  Lib6Material.rb: Loading body code from body_Lib6Material.rb [3 ms]
                  1413537185.7227268;Lib6Core.rb:921: in `effective_load_part2'
                  FredoTools 2.1a: Startup (creating menus and icons) [67 ms]
                  1413537185.820959;Lib6Core.rb:963: in `load_bootstrap_rubies'
                  RoundCorner 2.6a: Bootstrap Ruby files loaded [3 ms]
                  1413537185.8898308;Lib6Core.rb:921: in `effective_load_part2'
                  RoundCorner 2.6a: Startup (creating menus and icons) [42 ms]
                  1413537185.916391;Fredo6_!LibFredo6.rb:189: in `startup'
                  LibFredo6: End of loading Cycle***-
                  1413537200.377671;Lib6Plugin.rb:150: in `load_body'
                  Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [28 ms]
                  1413537200.46688;Lib6Core.rb:85: in `use_single_library'
                  Lib6G6.rb: Loading body code from body_Lib6G6.rb [68 ms]
                  1413537200.5250602;Lib6Core.rb:85: in `use_single_library'
                  Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [34 ms]
                  1413537200.5839438;Lib6Core.rb:85: in `use_single_library'
                  Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [35 ms]
                  1413537200.637125;Lib6Core.rb:85: in `use_single_library'
                  Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
                  1413537200.757068;Lib6Core.rb:85: in `use_single_library'
                  Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [100 ms]
                  1413537200.841938;Lib6Core.rb:85: in `use_single_library'
                  Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [60 ms]
                  1413537200.901935;Lib6Core.rb:85: in `use_single_library'
                  Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [36 ms]
                  1413537200.941764;Lib6Core.rb:85: in `use_single_library'
                  Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [18 ms]
                  1413537201.013798;Lib6Core.rb:85: in `use_single_library'
                  Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [48 ms]
                  1413537201.0753632;Lib6Core.rb:85: in `use_single_library'
                  Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [34 ms]
                  1413537201.117089;Lib6Plugin.rb:150: in `load_body'
                  Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [19 ms]
                  1413537201.184042;Lib6Plugin.rb:150: in `load_body'
                  Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [43 ms]
                  1413537201.233104;Lib6Plugin.rb:150: in `load_body'
                  Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [20 ms]
                  • F Offline
                    Eozel,
                    It seems Ruby 2.0 is a disaster when the path contains non-ascii charcaters and many functions are impacted.
                    If you know how to do it, could you edit the file Curviloft.plugin which is in Fredo6_Curviloft subfolder and at the end remove the line "BOOTSTRAP = bootstrap_Curviloft"
                    • F Offline
                      NEW RELEASE: LibFredo6 v6.3a - 19 Oct 14
                      LibFredo6 6.3a is a release mainly for supporting username with non-ascii characters in SU14.
                      If this is your case, you will need also to upgrade all my scripts which I am republishing.
                      Note that non-ascii usernames are normally supported since Sketchup 2014, but there were bugs in Ruby 2.0.
                      See main post of this thread for Download of LibFredo6.
                      • E Offline
                        eozel
                        @fredo6 said:
                        Eozel,
                        Thanks for your all supports, with removing of the line, Curviloft works fine.
                        Fredotoposhape gives error when SU start "You must install Libfredo 6 version 5.2 or higher to run fredo6_toposhaper".
                        Also, Have you got any shape plugin which works fine?
                        • F Offline
                          Eozel,
                          I re-released all my plugins for non-ascii usernames.
                          Please upgrade to LibFredo6 6.3 and latest versions of my plugins. I hope it will work for you now.
                          • V Offline
                            vivo44
                            Hello Fredo,
                            Je viens d'installer SKP14 ainsi que tous mes plugins via le menu Extensions de SKP (le SCF me dit qu'il ne sait pas unziper..)
                            J'ai toujours un message d'erreur au lancement de SKP:
                            "Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
                            C:/Users/vivien.serveau/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'"
                            Qu'est-ce que j'ai fait de mal?? 😞
                            Merci pour ton aide! Et bravo pour ton travail!
                            • F Offline
                              Il semblerait qu'il reste des vieux fichiers (pas au format UTF8) dans la directory Plugins. Peux tu faire le menage ou montrer la liste des fichiers / directories dans le repertoire Plugins de Sketchup
                              • V Offline
                                vivo44
                                Ok voici la liste, je traine des pluggins depuis 6 ans donc c'est possible...mais je ne comprends pas lesquels!
                                • F Offline
                                  Just remove
                                  • LibTraductor.rb (i guess this is the one causing the issue, as it must be old)
                                  • RDE_dir
                                  • SUCLOCK_Dir_11
                                  • ROUNDCORNER_dir_23
                                  • E Offline
                                    el_apprentice
                                    @fred06
                                    Hi! Good day..
                                    Where exactly I can download the LibFredo6 - v6.3a in this thread?
                                    Leiy
                                      @el_apprentice said:
                                      @fred06
                                      Hi! Good day..
                                      Leiy
                                      Go to the first post on the first page--always a good place to start. It's very clearly spelled out with the link given in the text below the yellow Download image.
                                      • V Offline
                                        vivo44
                                        @fredo6 said:
                                        Just remove
                                        • RDE_dir
                                        • SUCLOCK_Dir_11
                                        Great! I work properly now!
                                        Thank you very much for your time.
                                        A+
                                          kristianmorse
                                          where's the download link for 6.3?
                                          • 42
                                          • 43
                                          • 44
                                          • 45
                                          • 46
                                          • 106
                                          • 107
                                          • 44 / 107
