    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 783.6k Views 121 Watching
    • fredo6F Offline
      NEW RELEASE: FredoTools v2.0b - 07 Jul 14
      FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin)
      • guanjinG Offline
        guanjin
        Since the beginning of language files 2.0A, there has been a lot of abandoned character, can not be cleared, it can not be translated
        • fredo6F Offline
          What do you mean exactly?
          • leolouieL Offline
            leolouie
            I have been updating all my plugins to 2014, but have been stuck on some error messages. Is there an old file in conflict or is there something in the coding:
            Error Loading File Fredo6_!LibFredo6.rb
            Error: #<ArgumentError: invalid byte sequence in UTF-8>
            C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
            C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
            C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
            C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in block in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in each'
            C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
            C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:186:in startup' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:307:in module:LibFredo6'
            C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
              Have you updated the actual LibFredo version?
              Looks like something in the 'set' is NOT updated to me 😕
              • leolouieL Offline
                leolouie
                I removed all Fred06 plugins and restarted SU14. I did not get any errors. The I installed LibFredo6 and the errors came back.
                • fredo6F Offline
                  The best is to show the file list in your Plugins directory. There is definitely an old file, non converted to UTF8.
                  • leolouieL Offline
                    leolouie
                    I added back all your plugins and now there are no errors. Does FredoTools return an error message when it finds no plugins to manage?
                      pipinek
                      Greetings,
                      I am not able to mange to get the illustrated Fredo6 Tools icon toolbar appeared as shown on this page.
                      When I call a Fredo6 Tools toolbar I have got only the first icon in the toolbar, ie lancher one.
                      Any helpful suggestion will be deeply appreciated.
                      • fredo6F Offline
                        @pipinek said:
                        Greetings,
                        Go to the Default Parameters dialog (or click on yellow wrench) and enable the icons you wish. You can also read the main post.
                        • fredo6F Offline
                          NEW RELEASE: FredoTools v2.1a - 12 Oct 14
                          FredoTools 2.1a is a release for:
                          EdgeInspector v1.2: more accurate and relevant detection of fixing for Tiny Edges, Lost Junctions and Tiny Gaps
                          DrawAlong 1.2 v1.2: fixes for inferences on construction points and drawing construction points (avoid doubling)
                          • guanjinG Offline
                            guanjin
                            Show incomplete, occasionally show
                            • fredo6F Offline
                              NEW RELEASE: FredoTools v2.2a - 19 Oct 14
                              FredoTools 2.2a is required for the support of usernames with non-ascii characters in Sketchup 2014
                              • guanjinG Offline
                                guanjin
                                When I first opened sketchup, click Edge Inspector icon, a pop-up dialog box blank and click on the other icon again, and then click will display correctly。
                                • fredo6F Offline
                                  guanjin,
                                  Can you open the Ruby console and see if there are errors displayed.
                                  Do you get this problem with the English version or the Chinese version
                                  • guanjinG Offline
                                    guanjin
                                    @fredo6 said:
                                    guanjin,
                                    Without prompting any errors.
                                    There are Chinese characters display dislocation, English normal
                                    This problem has continued for several versions of this
                                    Earlier versions without problems
                                    Thank you fredo6
                                    guanjin
                                    • fredo6F Offline
                                      @guanjin
                                      I can have a look.
                                      But could you send me the FredoTools_ZH.lang file that you use. Currently, I don't have one updated for EdgeInspector.
                                      • fredo6F Offline
                                        @guanjin,
                                        If you wish to make a test, could you replace the following attached files in the Fredo6_!LibFredo6 subfolder
                                        body_Lib6G6.rbbody_Lib6Palette.rb
                                        This should normally take into account the natural width of Chinese characters
                                        Thanks for your feedback
                                          thevzitor
                                          Hello to all,
                                          I don't know where to post this problem but as it is related to downloading FredoTools, I post it here.
                                          It's probably a SketchUcation script problem, I cannot download the extension. Same problem with others extensions.
                                          Clicking the download link gives me a blank window and nothing happens. (screenshot enclosed)
                                          Is there any other place where to download it?
                                          Otherwise I installed LibFredo through the Extension warehouse in SU, restarted SU and still got the same old library... A bit annoying.
                                          Otherwise a big thank to Fredo for his extensions !
                                          All the best
                                            That 'Download' is just an image to show the relevant text below it, that's why it opens as an image.
                                            It is NOT a link.
                                            Most Plugins are available from the SketchUcation PluginStore.
                                            The FredoTools is here: http://sketchucation.com/pluginstore?pln=FredoTools
                                            Clicking that red 'Download' button gets you the RBZ archive.
                                            You can then use the Preferences > Extensions > Install... button to auto-install it into your Plugins folder.
                                            If you get/install the SketchUcation Toolset currently v2.6.1 [install it from its RBZ, downloadable from the Resources menu http://sketchucation.com/resources/plugin-store-download ] you'll then get a PLugins > SketchUcation submenu and SketchUcation toolbar, all within SketchUp itself.
                                            This toolset has many useful items - the relevant one in this case is the PluginStore dialog.
                                            Its dialog interface is similar to the SketchUcation PluginStore, but in this case the 'Download' button is replaced with a red 'AutoInstall' button.
                                            So simply find the required Plugins and click its AutoInstall button.
                                            It is automatically downloaded and installed for you in one step.
                                            There are other tabbed options to Update and make Bundles to use across SUp-versions or different computers etc... Save those till you get proficient in AutoInstalling... 😉
                                            Why make life more complex than it needs to be ?
                                            • 11
                                            • 23
                                            • 24
                                            • 9 / 24
