    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • H
      hkbauing
      a simple question: how to use the lang_de.txt?
      • facerF
        facer
        The UK_pflistAC file does not show list of steel
        SketchupMaker 2014
        W7 operating system
        File location for UK_pflistAC is:
        Documents\Sketchup_Maker_2014\UK_pflistAC
        screen capture of attempted use of steel sections
        • T
          tak2hata
          SketchupMaker 2014
          W7 operating system
          Hi,facer.
          I will test it later.
          Please wait.
          by TAK2HATA
          • T
            tak2hata
            Hi,facer and all.
            I update this to v1.9.6. in 2014.05.25.
            The problem of the read profile in sketchup2014 was fixed.
            And add some improves.
            HKBauing.
            From the menubar ->"plugins"->"building structure tool"->"Change language file"
            Select the lang file.
            and It will complete with restart sketchup.
            Thanks.
            TAK2HATA
            by TAK2HATA
            • JQLJ
              JQL
              Hi Tak2hata,
              I just saw this new version coming up and even if I have no direct need for the plugin it, looks impressive indeed! Congratulations!
              As I was watching the video and I saw that you classify building elements by type and name I remembered the new SU2014 "classifier" feature and I thought that it would be truly useful for your users if your tool would classify strutural elements in a standard BIM way, like IFC using the 2014 "classifier".
              Probably it already does that and I missed that feature, but if it doesn't, with what you have right now, what a monster this might become...
              Congratulations once again and keep up your great work.
              PS: I saw in a post before, you had an accident, I hope your better now...
              www.casca.pt
              Visit us on facebook!
              • sumasterS
                sumaster
                Hello Tak2hata,
                this is your new updated Bs Tools 1.9.6 getting error when opening Show Tools Option and Table Editor in Sketchup 2013 Version 13.0.4812
                Please check below . . . . . . .
                "show webdialog by CODE"
                Error; #<NoMethodError; undefined method `encode' for #<String;0xcd547a4>>
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;518;in `split_csvline'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;480;in `getCSVFile'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;477;in `each_line'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;477;in `getCSVFile'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;326;in `readProfiles'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_class_tool_for_wdlg.rb;580;in `init_webdialog'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_class_tool_for_wdlg.rb;849;in `show_tooldialog'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/main.rb;421;in `call'
                Error; #<NoMethodError; undefined method `encode' for #<String;0xcee32a0>>
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/main.rb;421;in `tst_menu_add'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_class_table_editor.rb;24;in `show_tooldialog'
                (eval);1;in `tst_menu_add'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;518;in `eval'
                C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/building_structure_tool/tst1_mod_common_util.rb;518;in `call'
                Thank you,
                SUmaster
                • T
                  tak2hata
                  I update this to v1.9.7.
                  Fix the encoding code problem.
                  Hi,JQL.
                  I search the Sketchup ruby API,
                  but there are no method for approaching to classifier.
                  I will wait for future release.
                  Thanks.
                  by TAK2HATA
                  • sumasterS
                    sumaster
                    Hello Tak2hata Sir,
                    NOW Its working . . . . . . . Thanks . . . . . 😍
                    Thank you,
                    SUmaster
                    • G
                      goga63
                      Good day !
                      Found bug in versions of Sketchup 2013 and Sketchup2014.
                      in Sketchup 2014 when you open the "Component Options" message on the error.
                      If using the editor Attribute in the Directory "BEAM_SPECS" attribute "PATH" to change the value of " [Point3d(0, 0, 0), Point3d(0, 100, 0)] "
                      to Point3d(0, 0, 0), Point3d(0, 100, 0) " , deleting the characters "[" and "]" ,
                      the error message does not occur.
                      http://ipic.su/img/img7/fs/error.1410935291.jpg
                      • T
                        tak2hata
                        @goga63 said:
                        Good day !
                        Hi,goga63.
                        I understand the problem.
                        I try to fix it.
                        Thanks.
                        by TAK2HATA
                        • T
                          tak2hata
                          Hi,All.
                          I update this to Version2.0.1a in 2014.09.28.
                          Some new function and Improves and Bugfixs.
                          Please watch what's new movie on top of thread.
                          by TAK2HATA
                          • KrisidiousK
                            Krisidious
                            nice improvements... That wall tool looks nice. Can it possibly do curved walls? or transform lines into walls?
                            By: Kristoff Rand
                            • G
                              goga63
                              Thank, tak2hata !!!
                              Excellent !!!
                              but ...now the length of the replaced part is not equal to the length of the deleted...
                              https://www.youtube.com/watch?v=CNm6fd-uhIU%26amp;list=UUYHOlAYFzT2R55uH7KDFIaQ
                              • T
                                tak2hata
                                @goga63 said:
                                Thank, tak2hata !!!
                                Excellent !!!
                                Hi,goga63.
                                Thanks for your testing.
                                But I can not make same scene.
                                Please send me your tested scene file with mwall files.
                                Thanks.
                                by TAK2HATA
                                • T
                                  tak2hata
                                  Hi,All.
                                  It has been a long time. 😉
                                  I re-updated to version2.0.2a.
                                  The problem that goga63 told me is fixed.
                                  But this script is very long.
                                  So I think there will be any other problems.
                                  I will check for more time.
                                  Thanks.
                                  by TAK2HATA
                                  • G
                                    goga63
                                    Yes ! now everything works !!!
                                    ...but if I find bugs ...
                                    ...I'll be back ...
                                    • G
                                      goga63
                                      ... using the new features of the plugin ...
                                      [flash=425,344:19h84au5]http://www.youtube.com/v/osD9DL--Wu0&hl=en&fs=1&rel=0[/flash:19h84au5]
                                      • B
                                        bohdeechozo
                                        Can anyone help me with ese kind of structure? Would beams with measures 100x50x2,5mm. I am not able to produce with the application. Thank you.
                                        • C
                                          cadmunkey
                                          Havent used this in a while. Can someone remind me how to create a slab. Do I select a face and then apply all, or select outer lines and draw by clicks? Nothing seems to work for me and I must be doing something wrong as all the other items work fine.
                                          Edit: figured it out, click face then draw by clicks. Doh!
                                          • C
                                            cadmunkey
                                            Using the new SHAPE class, does the ALIGN function not work with this? No matter how I draw my shape it draws it with a justification of bottom right. Any workaround?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
