    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 892.5k Views 144 Watching
    • tt_suT
      tt_su
      hmm... that bugsplat report didn't tell us anything more than it happened deep into Ruby code. Somewhere in the context menu handler when it create new Command objects. Trail stops with little info there...
      Are you able to reproduce this crash in SU2014? There's a lot of crash fixes from SU2013 to SU2014.
        matt.gordon320
        @Fredo: Thanks Fredo, I appreciate the time you took to investigate. I'll pass on the info of cleaning up the file, though I've come to find that usually falls on deaf ears around here. I'd think the benefits of working cleanly and efficiently would be self evident, but oh well! I don't have to work with it!
        @tt_su: Thanks ThomThom, I'll try to reproduce the error in SU2014. We're working on getting the whole office upgraded, so once we get that, I'll let you know what I find. Just out of curiosity, where does the BugSplat info get stored on a Windows 7 System? I've tried to look just out of curiosity more than anything, but can't ever seem to find it (I also haven't looked that hard).
        • tt_suT
          tt_su
          You won't be able to get any sensible of the temp files it dump. I'm not sure if they remain for any longer than for the files to be submitted. To get real value out of them you really need to be using the BugSplat backend.
            matt.gordon320
            @tt_su said:
            ...To get real value out of them you really need to be using the BugSplat backend.
            πŸ˜† Haha so it's quite beyond me at the moment...thanks!
            • I
              imabzeous
              thank you so much for this amazing plugin.. life saver i must say..
              • N
                numerobis
                one small thing... i think the info about the grid spacing should be mirrored to correspond with the division number above and the arrows.
                http://abload.de/img/grid0ekyg.png
                But once again: fantastic plugin!!! Very helpful! Thanks! πŸ˜„
                • JClementsJ
                  JClements
                  I have a problem with this file (originating from a DWG import).
                  This represents a drying pond.
                  The terrain generated extended outside the top-most contour (each contour is on its own layer).
                  I also tried to manually remove the "apron" but was unsuccessful.
                  Pond B Component.skp
                  • P
                    Panga
                    Toposhaper is really great but not enough powerfull or precise for big landscape datas !
                    I had to find another solution for those big projects
                    http://rendering.ru/ru_en/splineland.html
                    This is the only valuable and reliable solution I found.
                    Fredo, if you could do something like that for future Toposhaper updates... just a dream... πŸ˜‰
                    • fredo6F
                      Panga,
                      This Splineland application looks really great and powerful, at least from the 2 videos posted on the site
                      and it can also handle terrain given by elevation points only
                      This is definitely more adapted for large terrains and professional needs.
                      I had a few evolutions on my roadmap for TopoShaper, but nothing easy or fast to do, though possible.
                      1. Refinement of mesh, by subdivision. This has the drawback to break the quads nature of the generated terrain, but I agree this is required to handle sharp reliefs
                      2. Insertion of roads and platforms may come, but from another plugin (actually derived from VisuHole)
                      3. Building terrains from individual elevation points cloud is also possible, but the calculation is quite long as it requires an optimization algorithm
                      4. Triangular mesh may also be more adapted in many situations. It requires constrained Delaunay triangulation which is beyond the performance of Ruby for large terrains (unless the Sketchup team publishes one in Sketchup, like Triangles).
                      That's anyway low priority because I am not sure that many professional landscaping designers would be using Sketchup and TopoShaper versus dedicated programs line Splineland.
                      • P
                        Panga
                        Hi Fredo,
                        Splineland is as good as those videos shows, very reactive and powerfull for big landscape datas.
                        I fully understand your point of view and I know (unforntunatly) sketchup's limitations that prevent from having such a tool in sketchup. That's why we claim for High-poly support in sketchup for so many years...
                        The good thing is I can import the mesh done with splineland in sketchup, but I'm forced to use 3DSmax...So such a tool in sketchup would be very helpfull...no not very, but very very very very very helpfull !! πŸ˜„
                        So this is more a message to sketchup dev team : you won by the past so many users with landscape capabilities of sketchup, but today landscape datas and project are always more demanding and heavy, so maybe it's time to take it seriously !
                        Regards, and again thanks to Fredo for your wonderfull tools ! You, ruby devs are rocking the sketchup world !
                        Edit : Just in case the sketchup dev team don't know how to improve sktechup terrain tools, come to ask me, I spent so many hours trying to find solutions and I'm using it everyday !!
                        • fredo6F
                          NEW RELEASE: TopoShaper v1.2a - 19 Oct 14
                          This release is required for the support of usernames with non-ascii characters in Sketchup 2014
                          See main post of this thread for Download of TopoShaper.
                          • fredo6F
                            NEW RELEASE: TopoShaper v2.0 - 30 Dec 14
                            This major release introduces a new functionality: generation of Terrain from a Cloud of Points.
                            The terrain is generated by progressive triangulation / interpolation as an adaptive triangular mesh until it is smooth enough, as specified by a smoothing angle. It also allows to define clipping contours for the terrain.
                            [flash=640,480:1lak7gxg]http://www.youtube.com/v/bc1prnzkAXs&hl[/flash:1lak7gxg]
                              Wow! This is great.
                              • JClementsJ
                                JClements
                                Awesome! Thank you.
                                Did you keep track of the number of hours you spent developing this? I'm guessing it was massive.
                                Regards, John
                                • CadFatherC
                                  CadFather
                                  😲 i just have a question... WHO is Fredo6!!! πŸ˜†
                                  this stuff should be in the evening news!
                                  Thanks Fredo
                                  • pbacotP
                                    I just used this on imported contours that I had reworked in CAD beforehand. Toposhaper was the smoothest part of the whole operation. Looking good. If you need another real world case, I can send it. I also made some simple fill outlines from the building and edges from the mesh. Ran Toposhaper to create those as well. Thanks Fredo!
                                      And at the end apply a Color by Z (By Chris Fullmer or Sdmitch) and you will have a perfect tool for Topography! 😎
                                      • cottyC
                                        cotty
                                        Fantastic update, thank you!
                                        my SketchUp gallery
                                        • fredo6F
                                          I am indeed interested by this real world case!
                                          • P
                                            Panga
                                            Fredo, what can I say...and my parents were telling me that Santa dit not exist !! I'll try it right now and give you some feedback, but I'm already give you my BRAVO !
                                            Regards.
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
