    [Plugin] Edges/Construction Lines Converter V1.3
    25 Posts 13 Posters 29.2k Views 13 Watching
      jorge2011
      EXCELLENT PLUGIN.
      a query.?
      is possible convert smooth lines to construction lines?
      is possible the option of adding construction points at the ends of the lines?
      You can auto-detect lines with the mouse when I pass over a line?
      thank you very much
      • guanjinG Offline
        guanjin
        Right-click to select the color point of the blank, invalid
        • guanjinG Offline
          guanjin
          Right-click to select the color, no response
            Michaelv
            @jorge2011 said:
            EXCELLENT PLUGIN.
            a query.?
            thank you very much
            Smooth line, well I assume that if you view hidden, you can pick them and convert, I'll try.
            Cpoints, done already, use alt
            auto detect, well that would be nice, I don't know how to do yet πŸ˜„
            I presume what you mean is highlighting the line as you go over, before clicking to pick it.
            I'll look into it, but I'm working on 1.3 for much better integration too.
            As for no color, I don't know I will look, but mine works, so not sure why.
              Michaelv
              It only works when you are in the color change mode (see status line at bottom, and change mode with command key).
              Works all the time now (in version 1.3)
                jorge2011
                thank you very much for this update.
                "auto detect, well that would be nice, I don't know how to do yet πŸ˜„
                I presume what you mean is highlighting the line as you go over, before clicking to pick it."
                YES πŸ˜„
                • jeff hammondJ Offline
                  neat. thank you!
                  • Clayton49C Offline
                    Clayton49
                    Hi All,
                    Can anyone confirm if this PLUG-IN works with SU Pro-2014.
                    Over & out,
                    Clayton.
                    Over & out,
                    Clayton.
                    %(#008000)[Trotman & Taylor
                    Architectural Consultants]
                      Works perfectly with the 2014 Make (PC), so I suppose that is the same for the Pro! πŸ’š
                        @clayton49 said:
                        Hi All,
                        Over & out,
                        Clayton.
                        What happens when you try it?
                        • greenskpG Offline
                          greenskp
                          Thank you!
                          Works great! SketchUp 2015!
                          • F Offline
                            function
                            bug on console load 2016
                            C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;39; warning; class variable access from toplevel
                            C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;40; warning; class variable access from toplevel
                              How did you install it? I just installed it in SU2016 using the Extension Store and it works just fine.
                              • F Offline
                                function
                                strange, I always use thomthom's drag and drop - is it possible something else could cause an error like that?
                                  What do you mean you use ThomThom's drag and drop?
                                  I expect you've got the thing installed incorrectly or it would work.
                                  • F Offline
                                    function
                                    thomthom's drop zone installer. still gives me error, also using eneroth's console opener on start, not sure if that has something to do with it
                                      If you've got a bad installation of it, installing it again won't clean it up. At this point you should go to the Plugins folder and remove all traces of this plugin. Then either download the RBZ file and installed it with Install Extension in Preferences>Extensions or navigate to it in the Sketchucation Extension Store and install it with the Install button. Both of those options are sure to install it correctly.
                                      • SketcheldarS Offline
                                        Sketcheldar
                                        Thanks for the plugin!!!, it doesn’t work in sketchup 2024, you can fix it
                                          Sketcheldar
                                          #Corrected code for plugin to work in SU 2024
                                            @@colorx = "Black"
                                            @@stipplex = "_"
                                            def initialize
                                              @endpoints = false
                                              @change = false
                                              @colorlist = String.new
                                              colorlist = Sketchup::Color.names
                                              l = colorlist.size
                                              l = l - 1
                                              for e in 0..l do
                                                @colorlist = @colorlist + colorlist[e].to_s + "|" if e != l
                                                @colorlist = @colorlist + colorlist[e].to_s if e == l
                                              cflag = false
                                            def activate
                                              @model = Sketchup.active_model
                                              @ents = @model.active_entities
                                              @sel = @model.selection
                                              @lines = []
                                              show_status
                                              conversion
                                            def show_status
                                              statustext = "Edges into \"" + @@stipplex + "\" construction lines and cline to " + @@colorx + " edges (Command)" if !@change
                                              statustext = "Construction lines into \"" + @@stipplex + "\" clines and edges into " + @@colorx + " edges (Command)" if @change
                                              statusoption = "; Draw end points (Alt)" if @endpoints
                                              statusoption = "; Endpoints not drawn (Alt)" if !@endpoints
                                              status_label = statustext + statusoption
                                              Sketchup.set_status_text(status_label, SB_PROMPT)
                                            def conversion
                                              @model.start_operation "Line Conversion"
                                              view = @model.active_view
                                              if !@change
                                                for e in @sel
                                                  if e.class == Sketchup::Edge
                                                    lstart = e.start.position
                                                    lend = e.end.position
                                                    if @endpoints
                                                      @ents.add_cpoint lstart
                                                      @ents.add_cpoint lend
                                                    @ents.add_cline(lstart, lend, @@stipplex)
                                                    @lines.push(e)
                                                  elsif e.class == Sketchup::ConstructionLine
                                                    if e.start && e.end
                                                      if @endpoints
                                                      @ents.add_edges(lstart, lend)
                                                      @ents[-1].material = @@colorx.to_s
                                                      @ents[-1].find_faces
                                                      @lines.push(e)
                                                  end # e.class
                                                end # for e
                                                if !@lines.empty?
                                                  @lines.each do |e|
                                                    e.erase! if e.valid?
                                              elsif @change
                                                for e in @sel
                                                    e.stipple = @@stipplex
                                                    if e.start && e.end
                                                      if @endpoints
                                                  elsif e.class == Sketchup::Edge
                                                    if @endpoints
                                                    e.material = @@colorx.to_s
                                                  end # e.class
                                                  view.invalidate
                                                end # for e
                                              end # @change
                                              @sel.clear
                                              @model.commit_operation
                                            def self.xLine_validate_selection_edge
                                              Sketchup.active_model.selection.each {|e| return true if e.class == Sketchup::Edge}
                                              return nil
                                            def self.xLine_validate_selection_xline
                                              Sketchup.active_model.selection.each {|e| return true if (e.class == Sketchup::ConstructionLine && e.start && e.end)}
                                              return nil
                                            def onKeyDown(key, repeat, flags, view)
                                              if key == VK_COMMAND  ### Cmd toggles stipples and change
                                                @change = !@change
                                              if key == VK_ALT ### Alt toggles end points
                                                @endpoints = !@endpoints
                                              show_status
                                            def onLButtonDown(flags, x, y, view)
                                              ph = view.pick_helper
                                              ph.do_pick(x, y)
                                              best = ph.best_picked
                                              @sel.add(best) if best
                                              conversion
                                            def onRButtonDown(flags, x, y, view)
                                              cflag = true if @@colorx == "Black"
                                              list = ["-|.|-.-|_", @colorlist]
                                              prompt = ["XLine Stipple: ", "Color: "]
                                              values = [@@stipplex, @@colorx]
                                              result = inputbox(prompt, values, list, "Change Parameters")
                                              if result
                                                @@stipplex = result[0].to_s
                                                @@colorx = result[1].to_s
                                                if cflag && @model.rendering_options["EdgeColorMode"] != 0
                                                  choice = UI.messagebox "The edges color will only be visible if you switch to \"display color by material\". Do you want to do this at this time?", MB_YESNOCANCEL
                                                  case choice
                                                  when 6
                                                    @model.rendering_options["EdgeColorMode"] = 0 # sets up styles for Color By material
                                                    cflag = false
                                                  when 7
                                                    cflag = false
                                                end # if cflag
                                              end # if result
                                              show_status
                                              conversion
                                            def deactivate(view)
                                              Sketchup.set_status_text("", SB_PROMPT)
                                              Sketchup.set_status_text("", SB_VCB_LABEL)
                                              Sketchup.set_status_text("", SB_VCB_VALUE)
                                          if !file_loaded?("XLinem.rb")
                                            UI.add_context_menu_handler do |menu|
                                              if XLinemTool.xLine_validate_selection_edge
                                                menu.add_separator
                                                menu.add_item("Convert to XLine") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                              elsif XLinemTool.xLine_validate_selection_xline
                                                menu.add_separator
                                                menu.add_item("Convert to Edge") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                          unless file_loaded?(__FILE__)
                                            cmd = UI::Command.new("xlinem Convert") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                            cmd.small_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_SM.png")
                                            cmd.large_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_LG.png")
                                            cmd.tooltip = "Construction Line Conversion"
                                            tb = UI.toolbar("Line Conversion") # Fixed string termination
                                            tb.add_item(cmd)
                                            tb.restore
                                          end```
                                          TIGT F 2 Replies Last reply Reply Quote 1
                                            TIG Moderator @Sketcheldar
                                            @Sketcheldar
                                            Because you haven't formatted your code properly it's unusable.
                                            Use the </> button to add the correct 'Code' formatting...
                                            Which is three ` at the start & end of your code, on a separate line.
