    [Plugin] Edges/Construction Lines Converter V1.3
    25 Posts 13 Posters 29.2k Views 13 Watching
    • jeff hammondJ Offline
      neat. thank you!
      • Clayton49C Offline
        Clayton49
        Hi All,
        Can anyone confirm if this PLUG-IN works with SU Pro-2014.
        Over & out,
        Clayton.
        Over & out,
        Clayton.
        %(#008000)[Trotman & Taylor
        Architectural Consultants]
          Works perfectly with the 2014 Make (PC), so I suppose that is the same for the Pro! đź’š
            @clayton49 said:
            Hi All,
            Over & out,
            Clayton.
            What happens when you try it?
            • greenskpG Offline
              greenskp
              Thank you!
              Works great! SketchUp 2015!
              • F Offline
                function
                bug on console load 2016
                C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;39; warning; class variable access from toplevel
                C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;40; warning; class variable access from toplevel
                  How did you install it? I just installed it in SU2016 using the Extension Store and it works just fine.
                  • F Offline
                    function
                    strange, I always use thomthom's drag and drop - is it possible something else could cause an error like that?
                      What do you mean you use ThomThom's drag and drop?
                      I expect you've got the thing installed incorrectly or it would work.
                      • F Offline
                        function
                        thomthom's drop zone installer. still gives me error, also using eneroth's console opener on start, not sure if that has something to do with it
                          If you've got a bad installation of it, installing it again won't clean it up. At this point you should go to the Plugins folder and remove all traces of this plugin. Then either download the RBZ file and installed it with Install Extension in Preferences>Extensions or navigate to it in the Sketchucation Extension Store and install it with the Install button. Both of those options are sure to install it correctly.
                          • SketcheldarS Offline
                            Sketcheldar
                            Thanks for the plugin!!!, it doesn’t work in sketchup 2024, you can fix it
                              Sketcheldar
                              #Corrected code for plugin to work in SU 2024
                                @@colorx = "Black"
                                @@stipplex = "_"
                                def initialize
                                  @endpoints = false
                                  @change = false
                                  @colorlist = String.new
                                  colorlist = Sketchup::Color.names
                                  l = colorlist.size
                                  l = l - 1
                                  for e in 0..l do
                                    @colorlist = @colorlist + colorlist[e].to_s + "|" if e != l
                                    @colorlist = @colorlist + colorlist[e].to_s if e == l
                                  cflag = false
                                def activate
                                  @model = Sketchup.active_model
                                  @ents = @model.active_entities
                                  @sel = @model.selection
                                  @lines = []
                                  show_status
                                  conversion
                                def show_status
                                  statustext = "Edges into \"" + @@stipplex + "\" construction lines and cline to " + @@colorx + " edges (Command)" if !@change
                                  statustext = "Construction lines into \"" + @@stipplex + "\" clines and edges into " + @@colorx + " edges (Command)" if @change
                                  statusoption = "; Draw end points (Alt)" if @endpoints
                                  statusoption = "; Endpoints not drawn (Alt)" if !@endpoints
                                  status_label = statustext + statusoption
                                  Sketchup.set_status_text(status_label, SB_PROMPT)
                                def conversion
                                  @model.start_operation "Line Conversion"
                                  view = @model.active_view
                                  if !@change
                                    for e in @sel
                                      if e.class == Sketchup::Edge
                                        lstart = e.start.position
                                        lend = e.end.position
                                        if @endpoints
                                          @ents.add_cpoint lstart
                                          @ents.add_cpoint lend
                                        @ents.add_cline(lstart, lend, @@stipplex)
                                        @lines.push(e)
                                      elsif e.class == Sketchup::ConstructionLine
                                        if e.start && e.end
                                          if @endpoints
                                          @ents.add_edges(lstart, lend)
                                          @ents[-1].material = @@colorx.to_s
                                          @ents[-1].find_faces
                                          @lines.push(e)
                                      end # e.class
                                    end # for e
                                    if !@lines.empty?
                                      @lines.each do |e|
                                        e.erase! if e.valid?
                                  elsif @change
                                    for e in @sel
                                        e.stipple = @@stipplex
                                        if e.start && e.end
                                          if @endpoints
                                      elsif e.class == Sketchup::Edge
                                        if @endpoints
                                        e.material = @@colorx.to_s
                                      end # e.class
                                      view.invalidate
                                    end # for e
                                  end # @change
                                  @sel.clear
                                  @model.commit_operation
                                def self.xLine_validate_selection_edge
                                  Sketchup.active_model.selection.each {|e| return true if e.class == Sketchup::Edge}
                                  return nil
                                def self.xLine_validate_selection_xline
                                  Sketchup.active_model.selection.each {|e| return true if (e.class == Sketchup::ConstructionLine && e.start && e.end)}
                                  return nil
                                def onKeyDown(key, repeat, flags, view)
                                  if key == VK_COMMAND  ### Cmd toggles stipples and change
                                    @change = !@change
                                  if key == VK_ALT ### Alt toggles end points
                                    @endpoints = !@endpoints
                                  show_status
                                def onLButtonDown(flags, x, y, view)
                                  ph = view.pick_helper
                                  ph.do_pick(x, y)
                                  best = ph.best_picked
                                  @sel.add(best) if best
                                  conversion
                                def onRButtonDown(flags, x, y, view)
                                  cflag = true if @@colorx == "Black"
                                  list = ["-|.|-.-|_", @colorlist]
                                  prompt = ["XLine Stipple: ", "Color: "]
                                  values = [@@stipplex, @@colorx]
                                  result = inputbox(prompt, values, list, "Change Parameters")
                                  if result
                                    @@stipplex = result[0].to_s
                                    @@colorx = result[1].to_s
                                    if cflag && @model.rendering_options["EdgeColorMode"] != 0
                                      choice = UI.messagebox "The edges color will only be visible if you switch to \"display color by material\". Do you want to do this at this time?", MB_YESNOCANCEL
                                      case choice
                                      when 6
                                        @model.rendering_options["EdgeColorMode"] = 0 # sets up styles for Color By material
                                        cflag = false
                                      when 7
                                        cflag = false
                                    end # if cflag
                                  end # if result
                                  show_status
                                  conversion
                                def deactivate(view)
                                  Sketchup.set_status_text("", SB_PROMPT)
                                  Sketchup.set_status_text("", SB_VCB_LABEL)
                                  Sketchup.set_status_text("", SB_VCB_VALUE)
                              if !file_loaded?("XLinem.rb")
                                UI.add_context_menu_handler do |menu|
                                  if XLinemTool.xLine_validate_selection_edge
                                    menu.add_separator
                                    menu.add_item("Convert to XLine") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                  elsif XLinemTool.xLine_validate_selection_xline
                                    menu.add_separator
                                    menu.add_item("Convert to Edge") {Sketchup.active_model.select_tool(XLinemTool.new)}
                              unless file_loaded?(__FILE__)
                                cmd = UI::Command.new("xlinem Convert") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                cmd.small_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_SM.png")
                                cmd.large_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_LG.png")
                                cmd.tooltip = "Construction Line Conversion"
                                tb = UI.toolbar("Line Conversion") # Fixed string termination
                                tb.add_item(cmd)
                                tb.restore
                              end```
                              TIGT F 2 Replies Last reply Reply Quote 1
                                TIG Moderator @Sketcheldar
                                @Sketcheldar
                                Because you haven't formatted your code properly it's unusable.
                                Use the </> button to add the correct 'Code' formatting...
                                Which is three ` at the start & end of your code, on a separate line.
                                • F Offline
                                  FlorinAp @Sketcheldar
                                  @Sketcheldar Something is wrong with this code...!!??
                                  TIGT 1 Reply Last reply Reply Quote 0
                                    TIG Moderator @FlorinAp
                                    @FlorinAp
                                    That code has never worked.
                                    The code as presented applies to a Class [XLinemTool] which should be inside a Module.
                                    No Class is defined.
                                    There's no RB file to set up the extension as SketchUp loads, and the image PNGs are not in a folder with the main code.
                                    There's also three trailing ` characters.
                                    If the missing parts were supplied and the whole lot then packaged in an RBZ file, life would be much easier for every one...
                                    F 1 Reply Last reply Reply Quote 0
                                    • F Offline
                                      FlorinAp @TIG
                                      @TIG Maybe somebody can do something about it, because right now we have no option to convert construction lines to edges (the reverse it is possible, at least with Curvizard).
                                      I know only one option (DBur Guide Tools) but it can do only one line at a time....
