    [Plugin] Edges/Construction Lines Converter V1.3
    25 Posts 13 Posters 28.9k Views 13 Watching
    • Clayton49C Offline
      Clayton49
      Hi All,
      Can anyone confirm if this PLUG-IN works with SU Pro-2014.
      Over & out,
      Clayton.
      Over & out,
      Clayton.
      %(#008000)[Trotman & Taylor
      Architectural Consultants]
        Works perfectly with the 2014 Make (PC), so I suppose that is the same for the Pro! đź’š
          @clayton49 said:
          Hi All,
          Over & out,
          Clayton.
          What happens when you try it?
          • greenskpG Offline
            greenskp
            Thank you!
            Works great! SketchUp 2015!
            • F Offline
              function
              bug on console load 2016
              C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;39; warning; class variable access from toplevel
              C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;40; warning; class variable access from toplevel
                How did you install it? I just installed it in SU2016 using the Extension Store and it works just fine.
                • F Offline
                  function
                  strange, I always use thomthom's drag and drop - is it possible something else could cause an error like that?
                    What do you mean you use ThomThom's drag and drop?
                    I expect you've got the thing installed incorrectly or it would work.
                    • F Offline
                      function
                      thomthom's drop zone installer. still gives me error, also using eneroth's console opener on start, not sure if that has something to do with it
                        If you've got a bad installation of it, installing it again won't clean it up. At this point you should go to the Plugins folder and remove all traces of this plugin. Then either download the RBZ file and installed it with Install Extension in Preferences>Extensions or navigate to it in the Sketchucation Extension Store and install it with the Install button. Both of those options are sure to install it correctly.
                        • SketcheldarS Offline
                          Sketcheldar
                          Thanks for the plugin!!!, it doesn’t work in sketchup 2024, you can fix it
                            Sketcheldar
                            #Corrected code for plugin to work in SU 2024
                              @@colorx = "Black"
                              @@stipplex = "_"
                              def initialize
                                @endpoints = false
                                @change = false
                                @colorlist = String.new
                                colorlist = Sketchup::Color.names
                                l = colorlist.size
                                l = l - 1
                                for e in 0..l do
                                  @colorlist = @colorlist + colorlist[e].to_s + "|" if e != l
                                  @colorlist = @colorlist + colorlist[e].to_s if e == l
                                cflag = false
                              def activate
                                @model = Sketchup.active_model
                                @ents = @model.active_entities
                                @sel = @model.selection
                                @lines = []
                                show_status
                                conversion
                              def show_status
                                statustext = "Edges into \"" + @@stipplex + "\" construction lines and cline to " + @@colorx + " edges (Command)" if !@change
                                statustext = "Construction lines into \"" + @@stipplex + "\" clines and edges into " + @@colorx + " edges (Command)" if @change
                                statusoption = "; Draw end points (Alt)" if @endpoints
                                statusoption = "; Endpoints not drawn (Alt)" if !@endpoints
                                status_label = statustext + statusoption
                                Sketchup.set_status_text(status_label, SB_PROMPT)
                              def conversion
                                @model.start_operation "Line Conversion"
                                view = @model.active_view
                                if !@change
                                  for e in @sel
                                    if e.class == Sketchup::Edge
                                      lstart = e.start.position
                                      lend = e.end.position
                                      if @endpoints
                                        @ents.add_cpoint lstart
                                        @ents.add_cpoint lend
                                      @ents.add_cline(lstart, lend, @@stipplex)
                                      @lines.push(e)
                                    elsif e.class == Sketchup::ConstructionLine
                                      if e.start && e.end
                                        if @endpoints
                                        @ents.add_edges(lstart, lend)
                                        @ents[-1].material = @@colorx.to_s
                                        @ents[-1].find_faces
                                        @lines.push(e)
                                    end # e.class
                                  end # for e
                                  if !@lines.empty?
                                    @lines.each do |e|
                                      e.erase! if e.valid?
                                elsif @change
                                  for e in @sel
                                      e.stipple = @@stipplex
                                      if e.start && e.end
                                        if @endpoints
                                    elsif e.class == Sketchup::Edge
                                      if @endpoints
                                      e.material = @@colorx.to_s
                                    end # e.class
                                    view.invalidate
                                  end # for e
                                end # @change
                                @sel.clear
                                @model.commit_operation
                              def self.xLine_validate_selection_edge
                                Sketchup.active_model.selection.each {|e| return true if e.class == Sketchup::Edge}
                                return nil
                              def self.xLine_validate_selection_xline
                                Sketchup.active_model.selection.each {|e| return true if (e.class == Sketchup::ConstructionLine && e.start && e.end)}
                                return nil
                              def onKeyDown(key, repeat, flags, view)
                                if key == VK_COMMAND  ### Cmd toggles stipples and change
                                  @change = !@change
                                if key == VK_ALT ### Alt toggles end points
                                  @endpoints = !@endpoints
                                show_status
                              def onLButtonDown(flags, x, y, view)
                                ph = view.pick_helper
                                ph.do_pick(x, y)
                                best = ph.best_picked
                                @sel.add(best) if best
                                conversion
                              def onRButtonDown(flags, x, y, view)
                                cflag = true if @@colorx == "Black"
                                list = ["-|.|-.-|_", @colorlist]
                                prompt = ["XLine Stipple: ", "Color: "]
                                values = [@@stipplex, @@colorx]
                                result = inputbox(prompt, values, list, "Change Parameters")
                                if result
                                  @@stipplex = result[0].to_s
                                  @@colorx = result[1].to_s
                                  if cflag && @model.rendering_options["EdgeColorMode"] != 0
                                    choice = UI.messagebox "The edges color will only be visible if you switch to \"display color by material\". Do you want to do this at this time?", MB_YESNOCANCEL
                                    case choice
                                    when 6
                                      @model.rendering_options["EdgeColorMode"] = 0 # sets up styles for Color By material
                                      cflag = false
                                    when 7
                                      cflag = false
                                  end # if cflag
                                end # if result
                                show_status
                                conversion
                              def deactivate(view)
                                Sketchup.set_status_text("", SB_PROMPT)
                                Sketchup.set_status_text("", SB_VCB_LABEL)
                                Sketchup.set_status_text("", SB_VCB_VALUE)
                            if !file_loaded?("XLinem.rb")
                              UI.add_context_menu_handler do |menu|
                                if XLinemTool.xLine_validate_selection_edge
                                  menu.add_separator
                                  menu.add_item("Convert to XLine") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                elsif XLinemTool.xLine_validate_selection_xline
                                  menu.add_separator
                                  menu.add_item("Convert to Edge") {Sketchup.active_model.select_tool(XLinemTool.new)}
                            unless file_loaded?(__FILE__)
                              cmd = UI::Command.new("xlinem Convert") {Sketchup.active_model.select_tool(XLinemTool.new)}
                              cmd.small_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_SM.png")
                              cmd.large_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_LG.png")
                              cmd.tooltip = "Construction Line Conversion"
                              tb = UI.toolbar("Line Conversion") # Fixed string termination
                              tb.add_item(cmd)
                              tb.restore
                            end```
                            TIGT F 2 Replies Last reply Reply Quote 1
                            • TIGT Online
                              TIG Moderator @Sketcheldar
                              @Sketcheldar
                              Because you haven't formatted your code properly it's unusable.
                              Use the </> button to add the correct 'Code' formatting...
                              Which is three ` at the start & end of your code, on a separate line.
                              • F Offline
                                FlorinAp @Sketcheldar
                                @Sketcheldar Something is wrong with this code...!!??
                                TIGT 1 Reply Last reply Reply Quote 0
                                • TIGT Online
                                  TIG Moderator @FlorinAp
                                  @FlorinAp
                                  That code has never worked.
                                  The code as presented applies to a Class [XLinemTool] which should be inside a Module.
                                  No Class is defined.
                                  There's no RB file to set up the extension as SketchUp loads, and the image PNGs are not in a folder with the main code.
                                  There's also three trailing ` characters.
                                  If the missing parts were supplied and the whole lot then packaged in an RBZ file, life would be much easier for every one...
                                  F 1 Reply Last reply Reply Quote 0
                                  • F Offline
                                    FlorinAp @TIG
                                    @TIG Maybe somebody can do something about it, because right now we have no option to convert construction lines to edges (the reverse it is possible, at least with Curvizard).
                                    I know only one option (DBur Guide Tools) but it can do only one line at a time....
