    [Plugin] Edges/Construction Lines Converter V1.3
    25 Posts 13 Posters 29.2k Views 13 Watching
    • mitcorbM Offline
      mitcorb
      Hi, Michael:
      Thanks for sharing this tool.
        jorge2011
        EXCELLENT PLUGIN.
        a query.?
        is possible convert smooth lines to construction lines?
        is possible the option of adding construction points at the ends of the lines?
        You can auto-detect lines with the mouse when I pass over a line?
        thank you very much
        • guanjinG Offline
          guanjin
          Right-click to select the color point of the blank, invalid
          • guanjinG Offline
            guanjin
            Right-click to select the color, no response
              Michaelv
              @jorge2011 said:
              EXCELLENT PLUGIN.
              a query.?
              thank you very much
              Smooth line, well I assume that if you view hidden, you can pick them and convert, I'll try.
              Cpoints, done already, use alt
              auto detect, well that would be nice, I don't know how to do yet 😄
              I presume what you mean is highlighting the line as you go over, before clicking to pick it.
              I'll look into it, but I'm working on 1.3 for much better integration too.
              As for no color, I don't know I will look, but mine works, so not sure why.
                Michaelv
                It only works when you are in the color change mode (see status line at bottom, and change mode with command key).
                Works all the time now (in version 1.3)
                  jorge2011
                  thank you very much for this update.
                  "auto detect, well that would be nice, I don't know how to do yet 😄
                  I presume what you mean is highlighting the line as you go over, before clicking to pick it."
                  YES 😄
                  • jeff hammondJ Offline
                    neat. thank you!
                    • Clayton49C Offline
                      Clayton49
                      Hi All,
                      Can anyone confirm if this PLUG-IN works with SU Pro-2014.
                      Over & out,
                      Clayton.
                      Over & out,
                      Clayton.
                      %(#008000)[Trotman & Taylor
                      Architectural Consultants]
                        Works perfectly with the 2014 Make (PC), so I suppose that is the same for the Pro! 💚
                          @clayton49 said:
                          Hi All,
                          Over & out,
                          Clayton.
                          What happens when you try it?
                          • greenskpG Offline
                            greenskp
                            Thank you!
                            Works great! SketchUp 2015!
                            • F Offline
                              function
                              bug on console load 2016
                              C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;39; warning; class variable access from toplevel
                              C;/Users/user01/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/xLinem.rb;40; warning; class variable access from toplevel
                                How did you install it? I just installed it in SU2016 using the Extension Store and it works just fine.
                                • F Offline
                                  function
                                  strange, I always use thomthom's drag and drop - is it possible something else could cause an error like that?
                                    What do you mean you use ThomThom's drag and drop?
                                    I expect you've got the thing installed incorrectly or it would work.
                                    • F Offline
                                      function
                                      thomthom's drop zone installer. still gives me error, also using eneroth's console opener on start, not sure if that has something to do with it
                                        If you've got a bad installation of it, installing it again won't clean it up. At this point you should go to the Plugins folder and remove all traces of this plugin. Then either download the RBZ file and installed it with Install Extension in Preferences>Extensions or navigate to it in the Sketchucation Extension Store and install it with the Install button. Both of those options are sure to install it correctly.
                                        • SketcheldarS Offline
                                          Sketcheldar
                                          Thanks for the plugin!!!, it doesn’t work in sketchup 2024, you can fix it
                                            Sketcheldar
                                            #Corrected code for plugin to work in SU 2024
                                              @@colorx = "Black"
                                              @@stipplex = "_"
                                              def initialize
                                                @endpoints = false
                                                @change = false
                                                @colorlist = String.new
                                                colorlist = Sketchup::Color.names
                                                l = colorlist.size
                                                l = l - 1
                                                for e in 0..l do
                                                  @colorlist = @colorlist + colorlist[e].to_s + "|" if e != l
                                                  @colorlist = @colorlist + colorlist[e].to_s if e == l
                                                cflag = false
                                              def activate
                                                @model = Sketchup.active_model
                                                @ents = @model.active_entities
                                                @sel = @model.selection
                                                @lines = []
                                                show_status
                                                conversion
                                              def show_status
                                                statustext = "Edges into \"" + @@stipplex + "\" construction lines and cline to " + @@colorx + " edges (Command)" if !@change
                                                statustext = "Construction lines into \"" + @@stipplex + "\" clines and edges into " + @@colorx + " edges (Command)" if @change
                                                statusoption = "; Draw end points (Alt)" if @endpoints
                                                statusoption = "; Endpoints not drawn (Alt)" if !@endpoints
                                                status_label = statustext + statusoption
                                                Sketchup.set_status_text(status_label, SB_PROMPT)
                                              def conversion
                                                @model.start_operation "Line Conversion"
                                                view = @model.active_view
                                                if !@change
                                                  for e in @sel
                                                    if e.class == Sketchup::Edge
                                                      lstart = e.start.position
                                                      lend = e.end.position
                                                      if @endpoints
                                                        @ents.add_cpoint lstart
                                                        @ents.add_cpoint lend
                                                      @ents.add_cline(lstart, lend, @@stipplex)
                                                      @lines.push(e)
                                                    elsif e.class == Sketchup::ConstructionLine
                                                      if e.start && e.end
                                                        if @endpoints
                                                        @ents.add_edges(lstart, lend)
                                                        @ents[-1].material = @@colorx.to_s
                                                        @ents[-1].find_faces
                                                        @lines.push(e)
                                                    end # e.class
                                                  end # for e
                                                  if !@lines.empty?
                                                    @lines.each do |e|
                                                      e.erase! if e.valid?
                                                elsif @change
                                                  for e in @sel
                                                      e.stipple = @@stipplex
                                                      if e.start && e.end
                                                        if @endpoints
                                                    elsif e.class == Sketchup::Edge
                                                      if @endpoints
                                                      e.material = @@colorx.to_s
                                                    end # e.class
                                                    view.invalidate
                                                  end # for e
                                                end # @change
                                                @sel.clear
                                                @model.commit_operation
                                              def self.xLine_validate_selection_edge
                                                Sketchup.active_model.selection.each {|e| return true if e.class == Sketchup::Edge}
                                                return nil
                                              def self.xLine_validate_selection_xline
                                                Sketchup.active_model.selection.each {|e| return true if (e.class == Sketchup::ConstructionLine && e.start && e.end)}
                                                return nil
                                              def onKeyDown(key, repeat, flags, view)
                                                if key == VK_COMMAND  ### Cmd toggles stipples and change
                                                  @change = !@change
                                                if key == VK_ALT ### Alt toggles end points
                                                  @endpoints = !@endpoints
                                                show_status
                                              def onLButtonDown(flags, x, y, view)
                                                ph = view.pick_helper
                                                ph.do_pick(x, y)
                                                best = ph.best_picked
                                                @sel.add(best) if best
                                                conversion
                                              def onRButtonDown(flags, x, y, view)
                                                cflag = true if @@colorx == "Black"
                                                list = ["-|.|-.-|_", @colorlist]
                                                prompt = ["XLine Stipple: ", "Color: "]
                                                values = [@@stipplex, @@colorx]
                                                result = inputbox(prompt, values, list, "Change Parameters")
                                                if result
                                                  @@stipplex = result[0].to_s
                                                  @@colorx = result[1].to_s
                                                  if cflag && @model.rendering_options["EdgeColorMode"] != 0
                                                    choice = UI.messagebox "The edges color will only be visible if you switch to \"display color by material\". Do you want to do this at this time?", MB_YESNOCANCEL
                                                    case choice
                                                    when 6
                                                      @model.rendering_options["EdgeColorMode"] = 0 # sets up styles for Color By material
                                                      cflag = false
                                                    when 7
                                                      cflag = false
                                                  end # if cflag
                                                end # if result
                                                show_status
                                                conversion
                                              def deactivate(view)
                                                Sketchup.set_status_text("", SB_PROMPT)
                                                Sketchup.set_status_text("", SB_VCB_LABEL)
                                                Sketchup.set_status_text("", SB_VCB_VALUE)
                                            if !file_loaded?("XLinem.rb")
                                              UI.add_context_menu_handler do |menu|
                                                if XLinemTool.xLine_validate_selection_edge
                                                  menu.add_separator
                                                  menu.add_item("Convert to XLine") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                                elsif XLinemTool.xLine_validate_selection_xline
                                                  menu.add_separator
                                                  menu.add_item("Convert to Edge") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                            unless file_loaded?(__FILE__)
                                              cmd = UI::Command.new("xlinem Convert") {Sketchup.active_model.select_tool(XLinemTool.new)}
                                              cmd.small_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_SM.png")
                                              cmd.large_icon = File.join(File.dirname(__FILE__), "Xlinem", "Xline_LG.png")
                                              cmd.tooltip = "Construction Line Conversion"
                                              tb = UI.toolbar("Line Conversion") # Fixed string termination
                                              tb.add_item(cmd)
                                              tb.restore
                                            end```
                                            TIGT F 2 Replies Last reply Reply Quote 1
