    [Plugin] Lines to tubes
    131 Posts 61 Posters 312.2k Views 61 Watching
      How are you trying to install it ?
      My PipeAlongPath is v2014 compatible and will install OK from the PluginsStore dialog's AutoInstall or when downloaded and installed from the equivalent rbz from the PluginStore pages...
      The v2014 compatibility of Lines2Tubes has been discussed in this and other threads.
      There might be a 'compatible version' if you do a little searching...
      A simple tweak might even fix it... pending the author getting his proverbial out of his proverbial πŸ˜’
      See earlier posts in this thread πŸ˜’
      • F
        finhario
        @ckho1985 said:
        @tig said:
        Didier needs to rework his rb file for v2014 compatibility and republish it...
        BUT you can do it temporarily for your own use, even though his script is 'packed'.
        Open the file lines2tubes.rb in Notepad, and go to the end:
        Change
        ...}.unpack("m")**.to_s**
        to read
        ...}.unpack("m")**[0]**
        Save the changes.
        Restart SketchUp.
        The script will then load and work in v2014 !
        This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
        These edited scripts will also load and work in earlier SketchUp versions too... πŸ€“
        Working in Mac… not sure what to do 😞
        i do all the steps but still it's not working 😞 please help
          @Mario
          What have you done exactly ?
          The attached version should work on MAC or PC...
          I have tested it on both platforms, and it works fine for me !
          Compare it to your own effort ??
          Remember that the menu item is under Tools NOT Plugins !
          πŸ˜•
          lines2tubes.rb
          • RefkaR
            Refka
            πŸ˜•
            Thanks a lot TIG very useful.. 😍
            • soloS
              Where is this tool hiding?, it's not in plugins, not on right click and not in tools.
              • sdmitchS
                sdmitch
                It should be on the Tools menu as "Convert arcs,circles,curves,lines to cylinders".
                http://sdmitch.blogspot.com/
                • soloS
                  That's how it is in SU 2013, but not 2014, strange it's in plugin folder and all but not showing up.
                    Pete, which file did you download? I downloaded Didier's and it didn't work for me but when I downloaded and installed TIG's version and restarted SketchUp, it did. I converted TIG's version to .rbz (which I am attaching) to make it quick to install. I still had to close and restart SU to get it to show in the Tools menu.
                    lines2tubes2.rbz
                    • soloS
                      That worked, thanks Dave.
                      I have a few plugins just like this that did not install in SU 2014, I now have a trick.
                        shawnyeh
                        hello,
                        I got the same situation that can't find lines2tube in tool menu bar in MAC sketchup2014 .
                        Is there anyone can help me out ?
                        Thanks.
                          shawnyeh
                          Thanks Dave, it works!!
                          • H
                            helik
                            Thank you very much Dave!
                            • C
                              chris87
                              Great plugin !
                              Thank you !
                                Please get the latest v2014/2015 compatible version from the PluginStore http://sketchucation.com/pluginstore?pln=lines2tubes
                                • C
                                  chauhuyphan
                                  Great plugin! Thanks you !
                                  • josephkim626J
                                    josephkim626
                                    As I am often giving precision 4 to give a rectangular look, im just wondering if there would be a way to rotate the profile 45 degrees. Effectively, having a rectangular tubes.
                                    • sdmitchS
                                      sdmitch
                                      Yes, but this particular plugin is scrambled so only the creator can make that change.
                                      In the mean time, maybe this will help. You can copy and paste into the Ruby Console to try it out.
                                      mod = Sketchup.active_model
                                      ent = mod.active_entities
                                      sel = mod.selection
                                      unless sel.empty?
                                        vars=UI.inputbox(["Number of Sides;"," Length of a Side;","Angle of Rotation;"],[4,1,45],"Tube Specifications")
                                        if vars
                                          n,l,d=vars
                                          a=180/n
                                          r=l/Math.sin(a.degrees)/2
                                          edgs=sel.grep(Sketchup;;Edge)
                                          edgs.each{|e|
                                            p,v=e.line
                                            grp=ent.add_group;ge=grp.entities
                                            tube=ge.add_ngon(p,v,r,n)
                                            face=ge.add_face(tube)
                                            ent.transform_entities(Geom;;Transformation.rotation(p,v,d.degrees),face)
                                            face.followme e
                                            grp.explode
                                      else
                                        UI.messagebox "Select Edges"
                                      • ntxdaveN
                                        ntxdave
                                        While I like the plugin and seem some valuable uses, I am having a problem with it.
                                        Here is a screen capture of the problem I am having:
                                        I tried to be very careful when connecting the three segments (made sure the arch that connected the two straight lines was tangent) but I have many occasions where I will need to draw some pipes with multiple curves.
                                        I will assume I am doing something wrong. I have also attached the skp file (I moved the resulting tube so that the original line can be seen).
                                        Lines2Pipes.skp
                                        Press F1...thank me later
                                          driven
                                          @nxtdave,
                                          download tig_weld and weld your 3 lines first...
                                          • ntxdaveN
                                            ntxdave
                                            @driven said:
                                            @nxtdave,
                                            Already had weld installed. Just did not use it. When I welded the lines, it worked perfect. Even tried a freehand line and it worked fine as well.
                                            πŸ‘
                                            Thanks..........I should have thought of that 😳
                                            Might be something that should be explored for a future release though. Just out of curiosity, I also have the free version of Profile Builder and it worked fine on the original lines though without using the Weld tool.
                                            Just a thought..........
                                            • 5 / 7
