    [Plugin] Lines to tubes
    131 Posts 61 Posters 307.7k Views 61 Watching
      shawnyeh
      hello,
      I got the same situation that can't find lines2tube in tool menu bar in MAC sketchup2014 .
      Is there anyone can help me out ?
      Thanks.
        shawnyeh
        Thanks Dave, it works!!
        • H Offline
          helik
          Thank you very much Dave!
            chris87
            Great plugin !
            Thank you !
              Please get the latest v2014/2015 compatible version from the PluginStore http://sketchucation.com/pluginstore?pln=lines2tubes
                chauhuyphan
                Great plugin! Thanks you !
                • josephkim626J Offline
                  josephkim626
                  As I am often giving precision 4 to give a rectangular look, im just wondering if there would be a way to rotate the profile 45 degrees. Effectively, having a rectangular tubes.
                  • sdmitchS Offline
                    sdmitch
                    Yes, but this particular plugin is scrambled so only the creator can make that change.
                    In the mean time, maybe this will help. You can copy and paste into the Ruby Console to try it out.
                    mod = Sketchup.active_model
                    ent = mod.active_entities
                    sel = mod.selection
                    unless sel.empty?
                      vars=UI.inputbox(["Number of Sides;"," Length of a Side;","Angle of Rotation;"],[4,1,45],"Tube Specifications")
                      if vars
                        n,l,d=vars
                        a=180/n
                        r=l/Math.sin(a.degrees)/2
                        edgs=sel.grep(Sketchup;;Edge)
                        edgs.each{|e|
                          p,v=e.line
                          grp=ent.add_group;ge=grp.entities
                          tube=ge.add_ngon(p,v,r,n)
                          face=ge.add_face(tube)
                          ent.transform_entities(Geom;;Transformation.rotation(p,v,d.degrees),face)
                          face.followme e
                          grp.explode
                    else
                      UI.messagebox "Select Edges"
                    http://sdmitch.blogspot.com/
                    • ntxdaveN Offline
                      ntxdave
                      While I like the plugin and seem some valuable uses, I am having a problem with it.
                      Here is a screen capture of the problem I am having:
                      I tried to be very careful when connecting the three segments (made sure the arch that connected the two straight lines was tangent) but I have many occasions where I will need to draw some pipes with multiple curves.
                      I will assume I am doing something wrong. I have also attached the skp file (I moved the resulting tube so that the original line can be seen).
                      Lines2Pipes.skp
                      Press F1...thank me later
                        driven
                        @nxtdave,
                        download tig_weld and weld your 3 lines first...
                        • ntxdaveN Offline
                          ntxdave
                          @driven said:
                          @nxtdave,
                          Already had weld installed. Just did not use it. When I welded the lines, it worked perfect. Even tried a freehand line and it worked fine as well.
                          Thanks..........I should have thought of that 😳
                          Might be something that should be explored for a future release though. Just out of curiosity, I also have the free version of Profile Builder and it worked fine on the original lines though without using the Weld tool.
                          Just a thought..........
                            josephkim626
                            > sel = mod.selection
                            > unless sel.empty?
                            >   if vars
                            >     n,l,d=vars
                            >     a=180/n
                            >     edgs.each{|e|
                            >       p,v=e.line
                            >       face.followme e
                            >       grp.explode
                            >   end
                            > else
                            > end
                            Thank you so much, this helped for me at least this time.
                            I had to remove "grp.explode" line as I wanted them to be a grouped members.
                            who is the creator of this plugin? I know it has been tossed around couple times.
                            (I will still need an option to use "mm" units, follow welded edges as solid)
                            • sdmitchS Offline
                              sdmitch
                              Didier Bur is the creator of the "Lines2Tubes" plugin.
                                Guilherme Bera
                                I'd like to thank you by this plugin.
                                But it doesn't have a toolbar, and once that the plugin "Toolbar Editor" from Aerilius, induced me to make the workspace more visual. I decided to modify a bunch of scripts just enough to support toolbar, but your script is scrambled, so I can't do it by myself. So I'd be glad if you could modify your plugin just enough to support toolbar.
                                Then a simple way to add the toolbar support is like TIG commented in another topic (bit.ly/29PAk6T😞
                                An example of the menu making command is:
                                unless file_loaded?(__FILE__)
                                >    cmd = UI;;Command.new("SomeCommandName"){ SomeCommand.new() }
                                >    UI.menu("Plugins").add_item(cmd)
                                > ### START - ADD TOOLBAR HERE...
                                > ### END -   ADD TOOLBAR HERE
                                >    file_loaded(__FILE__)
                                > end
                                If it's a 'Tool' the CMD setup is slightly different...
                                An example to use that within a toolbar is this additional code added between the ### markers:
                                cmd.tooltip = "SomeCommandName"
                                > cmd.status_bar_text = "SomeText"
                                > cmd.small_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-24.png')
                                > cmd.large_icon = File.join("SomeCommandFolder/ImagesFolder", 'icon-32.png')
                                > toolbar = UI;;Toolbar.new("SomeCommandName")
                                > toolbar.add_item(cmd)
                                > toolbar.show if toolbar.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                                Note how addition properties are needed for the cmd to be used in a toolbar.
                                The path to the button icons and their names is up to you...
                                PS: If it could be helpful, I attached icons created for the toolbar.
                                  Does it possible to modify the plugin
                                  for have a rotation input?
                                  Now we have this!
                                  As you remark there is an Up Orientation!
                                  Wanted! 🤓
                                    josephkim626
                                    Now we have this!
                                    [attachment=1:1rui9dug]<!-- ia1 -->GIF_tube.gif<!-- ia1 -->[/attachment:1rui9dug]
                                    Wanted! 🤓
                                    [attachment=0:1rui9dug]<!-- ia0 -->squares_w.jpg<!-- ia0 -->[/attachment:1rui9dug]
                                    Sdmitch has his own plugin that does what you are describing.
                                    http://sdmitch.blogspot.co.uk/
                                    find "Edge To Tube"
                                      josephkim626
                                      @pilou said:
                                      Seems bugged! 😉
                                      Or works only for curves ?
                                      Seems working only from polys of 5 segments! 😉
                                      [attachment=1:17is50ip]<!-- ia1 -->GIF_bugged.gif<!-- ia1 -->[/attachment:17is50ip]
                                      Indeed it behaves funny when it is run on rectangles.
                                      But it seems fine for some others.
                                      [attachment=0:17is50ip]<!-- ia0 -->tube.gif<!-- ia0 -->[/attachment:17is50ip]
                                        Seems bugged! 😉
                                          The "Do curve" is somptuous! 👍
                                          (not my video 💚
                                          (currioussly don't works for the rectangles! 😲
                                          Bravo to Sdmitch! 😎
                                          Ps Will be very fine for any "section" 😉
                                          • ntxdaveN Offline
                                            ntxdave
                                            One thing that does not work correctly for me is the Materials parameter. It will only allow me to select a material that has already been used in the model.
                                            Maybe I am doing something wrong................
                                            • 6 / 7
